AMD Suggests Possible Fixes for Ryzen USB Connectivity Issues
atarione
not going to lie... I'm sort of annoyed with AMD about this... and basically having to disable a highlight feature of my ryzen motherboard (gen 4) to "work around" the issue..
It might?? be less annoying if this wasn't the first AMD system I have had since about 2006~ and now there is this problem with it...
fightingfi
Can you disable nvidia it sounds like it is them if you have to turn off pcie 4
