AMD showcasing 12 and 16 core parts
Discussion in 'AMD Processors' started by tangoseal, May 11, 2019.
  1. tangoseal
    tangoseal [H]ardness Supreme
    7,613
    Dec 18, 2010
  2. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    6,789
    Jul 29, 2009
    It does sound like the best option without getting a new motherboard :).
    But what would be the best time to buy those 12 cores. Those are all a pair of 6 core chiplets ? Or would there be 8+4 as well ?
    Wondering if there would be an advantage waiting with purchasing those 12 core parts to get better binned versions .....
  3. Brackle
    Brackle Old Timer
    7,233
    Jun 19, 2003
    Maybe, I mean i know they say 5ghz on boost, but is that 1 core? Or on all 12 cores. I do plan to upgrade to Ryzen 3000, but I would wait for reviews....I would say wait for Kyle's review like I always do but /cry no more.
    I am hoping my motherboard will work with it properly.
  4. DogsofJune
    DogsofJune 2[H]4U
    2,753
    Nov 7, 2008
    Waiting on reviews, but that 3700x does look enticing.
  5. _mockingbird
    _mockingbird Gawd
    992
    Feb 20, 2017
    This is nothing but the same rumors from last year.
    DooKey likes this.
  6. lightsout
    lightsout Gawd
    958
    Mar 15, 2014
    After the pricing on VII (I know it's two different things but still) I'm hesitant to trust this price. But man I agree the 12 core looks great. Hoping for close to 5ghz on all cores.
  7. kirbyrj
    kirbyrj [H]ard as it Gets
    24,514
    Feb 1, 2005
    Except at this point the rumor hasn't changed much and we're about 3 weeks from Computex.
    There's a big difference between a random guy on a website saying something 5 months ago and actual AMD showing actual chips to actual OEMs...
  8. kirbyrj
    24,514
    Feb 1, 2005
    The Radeon VII is priced the way it is because of the BOM.
  9. Pieter3dnow
    6,789
    Jul 29, 2009
    Look at Threadripper then look at the cooling it needs and how much of a difference the whole heat spreader surface takes vs water cooling on just part of the heat spreader surface. It will take some very top binned chip and nothing short of a miracle cooling solution on AM4 to get all cores on 5ghz (less surface to cool). Even if the TDP is lower then on Threadripper it still may not be that easy
    If AMD is as good on this process as they were on Zen+ (14+nm) then you might question how much more are you going to get by overclocking vs default AMD motherboard/cpu boosting.
  10. lightsout
    lightsout Gawd
    958
    Mar 15, 2014
    BOM?
    I didn't mean OC, I have found that pointless with Ryzen, I meant stock/boost clocks. We shall see how things play out. I would be fine with 4.5+, hopefully its in that area.
  11. _mockingbird
    _mockingbird Gawd
    992
    Feb 20, 2017
    so said the same guy who started the rumors
  12. Algrim
    Algrim [H]ard|Gawd
    1,514
    Jun 1, 2016
    Once I'm ready to ditch my current rig in sig, I'm considering the 12c/24t Ryzen or Threadripper.
  13. mvmiller12
    mvmiller12 Gawd
    862
    Aug 7, 2011
    BOM=Bill Of Materials (or, "how much the parts used in this thing cost")
    GoldenTiger, Pieter3dnow and kirbyrj like this.
  14. lightsout
    lightsout Gawd
    958
    Mar 15, 2014
    Ok, yeah I hear that those aren't cheap to produce. Seems like they just need to ditch the whole HBM thing. Definitely isn't giving them some huge gain over nvidia. Not sure how tied into the architecture it is.
  15. kirbyrj
    24,514
    Feb 1, 2005
    I'd like to think that they could have produced a $499 variant with only 8GB of HBM2 memory, but they didn't. Ideally, the Radeon VII would have been closer to $599 and an 8GB version at $499.
  16. Azrak
    Azrak Gawd
    832
    Oct 4, 2015
    Where is the 105W 8 core? I would expect that to have the fastest clocks. Maybe that will come out at the end of the year, after Intel releases something?
  17. tangoseal
    7,613
    Dec 18, 2010
    I'm not waiting on Kyle's review. I'll review it for my self. Microcenter return policy is grade A++++
    Brackle likes this.
  18. tangoseal
    7,613
    Dec 18, 2010
    These are not rumors honestly at this point. AMD has been purposefully leaking info to these OEMs in order to start the marketing awareness. They all play this game. I'm almost certain based on AMDs record of how they do stuff that these chip frequencies are legit. 5ghz 12 core. It's probably single or dual core at that speed and 4.2 to 4.4 all core using PBO2.
    My threadripper will hit 4.2 all core on it's own and 4.4 single.
    mikeo likes this.
  19. Burzum
    Burzum n00b
    29
    Dec 15, 2013
    The 12 and 16-core rumors are coming from basically three different people at this point. There's AdoredTV who has been talking about this stuff for a long time, APISAK who found the 16-core CPU show up in a benchmark result and then RedGamingTech who is the source of the 12-core 5GHz rumor. The only one of those sources I really trust is APISAK but these rumors are definitely coming from multiple different sources at this point.
    mikeo likes this.
  20. Pieter3dnow
    6,789
    Jul 29, 2009
    Since that was not possible on the original Instinct product and the only reason why they settled on a professional only die shrink for that market a 8 gb version was never an option. If you checked rumoured Navi release line up you should understand that Radeon VII (die shrink of Instinct 25) was never an option to be released outside of the professional market. The poor cooling solution the problem with launch drivers echo this ....
  21. kirbyrj
    24,514
    Feb 1, 2005
    I'm aware of the issues. It's more wishful thinking on my part. Obviously it doesn't make sense to re-engineer a niche product as you have a professional product you can tweak already designed and in the product stream.
