AMD Ryzen 9 3950X Overclocked To 5 GHz Across All 16 Cores On LN2
Discussion in 'HardForum Tech News' started by Rockenrooster, Jun 11, 2019.
Thread Status:
Not open for further replies.
  1. Dan_D
    Dan_D [H]ard as it Gets
    54,206
    Feb 9, 2002
    Waterclock, thermal armor (includes steel back plate), onboard controls, LiveDash 1.3" OLED, water flow headers, and more importantly, an expensive VRM configuration. It's a 16-phase system using 60AMP IR3555's. It specifically shows on ASUS' product that there is no phase doubler either. Meaning, its a very expensive configuration. The chokes are more expensive as are the 10k rated capacitors. All of that stuff adds to the cost. You also have an IC which allows flashing the BIOS without having a CPU installed. The list of reasons why this thing is so expensive really goes on and on. Things like the water flow sensors and LiveDash OLED require additional IC's on the PCB to make them work.
    Then you have PCIe 4.0 support and the X570 chipset itself. Implementation is supposedly considerably more expensive than the last generation was.
    AlphaQup, Darth Kyrie, N4CR and 2 others like this.
  2. primetime
    primetime [H]ardness Supreme
    5,735
    Aug 17, 2005
    Thanks for the info guys.....Honesty I have always felt like the motherboard should be the smartest investment even over the power supply. (cause the board is more of a pain to change) I usually invest 300-400 for my boards and even with the increase of price im sure the next Hero will still be in that price range. Ill probably just stay with my current board since since all the new cpus are backwards comparable. If i could preorder the 3900x now i probably would. If anything i might invest in a better cpu cooler like what ever is the biggest and best AIO cooler that would fit well in my case.
  3. RanceJustice
    RanceJustice [H]ardness Supreme
    5,980
    Jun 9, 2003
    I wonder if they're holding a Crosshair VIII "Extreme" model back for release alongside the 3950X part? I've had fantastic success with Asus boards over the years, with ROG often being the top choice (and at the time, offering a better showing compared to MSI / Gigabyte etc.. own luxury lines) both in builds for myself and others. For ATX boards (Impact for instance is the ROG suffix for mITX or similar SFF), the "Hero" type boards seem to have some of the highest end features for the best value I've found to date, with "Formula" being a moderate step up from that in price and niche features. Last i recall though, the top of the line was typically "Extreme", so its absence is noted unless I'm missing something. Then again, the last AMD "Extreme" board I can see on the site was the Crosshair VI Extreme, so there doesn't seem to be one for the VII'th generation. Maybe they've done away with it?
  4. odditory
    odditory [H]ardness Supreme
    5,432
    Dec 23, 2007
    It certainly was when I was looking at Z390 boards for my 9900k. Trouble is, the power delivery is really the main standout quality - BIOS and other things are lacking in typical Gigabyte fashion.
    kirbyrj likes this.
  5. juanrga
    juanrga Pro-Intel / Anti-AMD Just FYI
    2,540
    Feb 22, 2017
    Wow! Three records of several dozens! Cinebench, which is a favorable test for AMD muarch and Geekbench 4, a toy bench, where the new 3950X got a whole 7% higher score than a 7000-series Intel CPU!
    And R9 using a new motherboard and pushing memory to 4533 MHz, whereas other records are on older boards and memory at 2700 MHz or less.
    No one would be surprised. We have known for years that TSMC 7HPC is designed for clocks around 4.5GHz. Just as we knew that Glofo 14LPP would hit a wall around 4GHz.
  6. juanrga
    2,540
    Feb 22, 2017
    There is a difference. 15% higher base clock applies to all situations, whereas IPC depends on the code: it is not 15% across all applications.
    The screeenshot shows this isn't an ES.
  7. Rockenrooster
    Rockenrooster Limp Gawd
    301
    Apr 11, 2017
    Remember this is comparing a mainstream socket to a HEDT socket.
    The mainstream CPU is faster than than the HEDT one.
    It will probably compete very well with Intel's flashship HEDT CPU, the 9980xe.
    I'd say that is pretty impressive whatever the bench.
    But I know I won't be winning this argument....I mean you are juanrga..........
    You're right!!!
    Zen 2 has double the FPU. So Zen 2 + clocks should be 2x faster then Zen at FPU intensive tasks!!!!!!!!!!!! 15% at all else.
    THanks for pointing that out I almost forgot about Zen 2's FPU capabilities!!!!!!
    GoodBoy likes this.
  8. juanrga
    2,540
    Feb 22, 2017
    $749 isn't mainstream independently of the socket used.
    Zen2 has 256bit SIMD units. So it will produce 2x peak performance only on code compiled for 256bit, not on any code. Moreover, AVX islands are surrounded by x86 code. So the real performance increase will be less than 2x. It will be also interesting to see how memory bottlenecks Zen2 in scientific applications, because the BW/FP ratio is worse than for other designs.
  9. Verado
    Verado Limp Gawd
    186
    May 16, 2017
    Mainstream platform.
  10. Rockenrooster
    301
    Apr 11, 2017
    Wow you're an Intel guy and arguing about price!?!?!! LOL!
  11. Gideon
    Gideon 2[H]4U
    2,238
    Apr 13, 2006
    He will tell you how great Intel is at anytime, tho mostly when AMD is shown in a good light.
    Darth Kyrie, Verado, N4CR and 4 others like this.
  12. JosiahBradley
    JosiahBradley [H]ard|Gawd
    1,724
    Mar 19, 2006
    While it may seem sad that 5ghz on all cores requires LN2, I'm much more interested in how many cores I can hit 5ghz on water. If that turns out to be 4 cores, I'm still all in. That gives me 16 cores to play with when compiling and multitasking and 4+ cores in demanding games. Now that games actually take advantage of anywhere from 4-8 cores I see the trend upwards starting to happen for multi-threading finally, so 16 cores may not be so absurd in the near to mid-term future. However I'm still going with the best water-cooling overclocker so maybe that'll be the 12 core. We'll just have to wait and see.
    mikeo likes this.
  13. mikeo
    mikeo Limp Gawd
    422
    May 17, 2006
    With the rumors for the next threadripper being q4 this year, I'll probably go with the 16 or 32 core threadshredder, hopefully the lower core count threadrippers OC as well as that 3950x.
  14. Derangel
    Derangel [H]ard as it Gets
    17,610
    Jan 31, 2008
    The dude's a blind fanboy. You won't get anything but fanboy bullshit out of him. Don't even bother.
    Darth Kyrie, Verado, schmide and 2 others like this.
  15. cageymaru
    cageymaru [H]ard as it Gets
    19,803
    Apr 10, 2003
  16. BrotherMichigan
    BrotherMichigan [H]Lite
    115
    Apr 8, 2016
    All of that and Intel still had the world records with those chips. Until the 3950X came along, that is.
    Yeah, because NOBODY in the XOC community was trying to break those records. They just looked at them and said, "Yep! That's good for another few years!"
    juanrga, you're in for a rough couple of quarters my friend.
  17. Dayaks
    Dayaks [H]ardness Supreme
    6,927
    Feb 22, 2012
    Yeah.. just wait for that 64 core thread ripper lol.
    Darth Kyrie and mikeo like this.
  18. BoiseTech
    BoiseTech Limp Gawd
    320
    Mar 15, 2018
    So the TDP of the 3950X is 105 watts. I'm gunna throw a dark rock pro 4 on it. You think that'll be sufficient? It'll be in an in-win A1 plus. It seems to be a decently cooled case. I'm okay with 80ish degree temps. Little of my time is spent maxxing out the CPU.
  19. Nobu
    Nobu 2[H]4U
    3,125
    Jun 7, 2007
    A 250w cooler should be plenty at stock. If you want to take advantage of xfr, a better cooler will help, but it may be enough for a decent boost.
    BoiseTech likes this.
  20. Dan_D
    54,206
    Feb 9, 2002
    I'll bet that thing isn't 105w under PB2 or PBO, much less manually overclocked.
  21. BoiseTech
    BoiseTech Limp Gawd
    320
    Mar 15, 2018
    Ya, I figured - was hoping 250 watt dissipation of the DRP4 would give me some decent boost. I never overclock though. At most I'll be running some VM's, encoding here and there, and gaming.
  22. juanrga
    2,540
    Feb 22, 2017
    What I am saying is that the records are far from impressive when one takes them in context. Next quarters will be very funny because I will be watching how people begin looking for excuses when the product is reviewed and far from the current hype.
  23. juanrga
    2,540
    Feb 22, 2017
    I am not arguing. It is a fact that $749 isn't mainstream.
  24. N4CR
    N4CR 2[H]4U
    3,783
    Oct 17, 2011
    When ol' shinjuan is that salty you know it's good.
    Darth Kyrie and OrangeKhrush like this.
  25. Derangel
    17,610
    Jan 31, 2008
    Go bitch at Intel about it. They're the ones that defined the different platforms (mainsteam and HEDT). High end X570/Z-series boards are far outside of "mainstream" prices as well, but they're still built on the mainstream platform.
    Dan_D likes this.
  26. OrangeKhrush
    OrangeKhrush [H]ard|Gawd
    1,499
    Dec 15, 2016
    The ol "triggerometer" is off the charts
    Darth Kyrie and N4CR like this.
  27. juanrga
    2,540
    Feb 22, 2017
    Show me a thread with Intel fanboys pretending that $700--800 Intel chip is mainstream and I will post in that thread the same that I am posting here: that $749 isn't mainstream.
  28. BrotherMichigan
    115
    Apr 8, 2016
    What context would that be? To me the context appears to be that those were the highest scores ever obtained in those benchmarks and the 3950X was able to break those records. Seems pretty simple to me.
    Hey, at least there will be products to criticize!
    Darth Kyrie likes this.
  29. Derangel
    17,610
    Jan 31, 2008
    You're intentionally ignoring the naming scheme, defined by Intel. I'd argue no CPU over $250 really counts as "mainstream" but the PLATFORM is defined (by Intel) as the "Mainstream Platform". The higher-end platform is defined (again, by Intel) as HEDT. Intel could release a $5,000 CPU that runs on LGA 1151 and it would still be a CPU that runs on their mainstream PLATFORM despite the high cost.
  30. Rockenrooster
    301
    Apr 11, 2017
    I think you are confusing what we call "mainstream" and what Intel and AMD have defined as "mainstream platform" and "HEDT platform".
    No freaking duh $749 isn't mainstream, we aren't talking about the same thing here....
    mikeo likes this.
  31. mikeo
    mikeo Limp Gawd
    422
    May 17, 2006
    I wouldn't consider a 9900k mainstream either.
  32. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,291
    Jun 13, 2003
    "high-end consumer" maybe?
    mikeo likes this.
  33. OrangeKhrush
    1,499
    Dec 15, 2016
    the point where TDP doesn't matter.
  34. juanrga
    2,540
    Feb 22, 2017
    The context is that two records are on Cinebench, which is a very favorable benchmark for AMD RyZen, and the third record is on a toy bench, where the 3950X beats by only 7% a CPU released in 2017.
    I am not using companies scheme. If you are bound to their schemes you can arrive to funny consequences like that this 'mainstream' AMD processor is nearly twice more expensive than some 'HEDT' low core model from Intel.
    I don't care what the companies say.
  35. BrotherMichigan
    115
    Apr 8, 2016
    So world records only matter if Intel holds them. Got it. (Also, what has Intel been doing since 2017? No performance gains at all? That kind of sucks, doesn't it?)
    Darth Kyrie and TurboGLH like this.
  36. KonaKona040
    KonaKona040 n00b
    19
    Feb 6, 2019
    Or or or, we could all chill out and wait for launch and real reviews with real overclocking numbers instead of angry typing on the internet?
    Hahaha just kidding.
    (Also why would you argue with someone whose profile says they're Anti-AMD, just ignore it lol)
  37. juanrga
    2,540
    Feb 22, 2017
    Obviously that wasn't my point.
  38. Thunderdolt
    Thunderdolt Limp Gawd
    223
    Oct 23, 2018
    Everything you say is wrong. Also, your mom watches TV with motion smoothing turned on.
    OH SNAP.
    jfreund likes this.
  39. BrotherMichigan
    115
    Apr 8, 2016
    Sure, but it makes as much sense as the point you're trying to make so we'll just go with it.
  40. Rockenrooster
    301
    Apr 11, 2017
    At least you acknowledge the difference lol
    You also have to acknowledge that this thread is about a "mainstream platform" CPU. Whether the price is mainstream or not is irrevelant.
    In the end price is the ultimate factor as far as buying something but again we are talking about "mainstream platform" here. Keyword, Platform.
    AMD's mainstream platform allowing CPUs to enroach on HEDT territory in performance is welcomed by people such as us. Upgrade path for days...
    Now if we talk about AMD's HEDT platform vs Intel's HEDT, AMD has them beat overall and will probably outright be faster in everything once Threadripper 3 hits, I mean even the 3950x is competing with Intel's HEDT on some levels.
    About the HEDT low core model from Intel, are you talking about the 7740x by chance??? If so, then that CPU is a HEDT CPU without the benefits that the HEDT platform features lol!
Thread Status:
