- May 18, 1997
AMD has not shared a die shot of it upcoming Vega GPU. You can see the 8 blocks that each hold 8 Next Generation Compute Units which each have 64 stream processors. This gives us a total of 4,096 32-bit floating point units. The blocks you see on bottom are two HMB2 stacks. No comment on die size however, but it is rumored to be over 500mm2. Thanks to Ken for the picture.
So the story, not a real die shot, but a real marketing slide from AMD as we thought, that actually should in fact represent a real die shot...maybe?
