AMD RX 5700 XT card is better than a GTX 1080 at ray tracing in new Crytek demo
Discussion in 'Video Cards' started by kac77, Nov 13, 2019.
  1. Auer
    Auer Gawd
    1,004
    Nov 2, 2018
    I would imagine the 1650 Super making some difference in the sub $200 market tho.
    https://www.evga.com/products/product.aspx?pn=04G-P4-1357-KR
    noko likes this.
  2. Auer
    Auer Gawd
    1,004
    Nov 2, 2018
    I gave it a chance, but stopped when he claimed you can't tell the difference with RTX on or off in SOTTR.
    You absolutely can. Or at least I can.
    But then I don't have a Youtube presence that requires an agenda to get clicks and all that.
    (Also Mr. Coreteks really needs to hire a narrator. That shit makes you dizzy)
  3. Kardonxt
    Kardonxt 2[H]4U
    3,027
    Apr 13, 2009
  4. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    Feel free to find a review that makes this point clear. No one makes this distinction.
    noko likes this.
  5. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    That's a far cry from saying it isn't useful. That was my contention. Never said it wasn't useful.
    But here you are comparing rasterization with single ray traced objects.
  6. noko
    noko [H]ardness Supreme
    4,418
    Apr 14, 2010
    Yes I know looking at a video can be a far cry to actual game experience in front of a monitor. Still I think he has very pertinent points, over a year and only 6 titles with RTX and nothing that just stands out. If you have to look for it, it probably is not that important. Performance impact where you just can't turn everything up is means it won't be used. Plus long term wise RTX may not even be in developers window to use meaning those RT cores may just be dead space for more titles than not. To me so far RTX looks like it is heading to be Nvidia's biggest failure. Now I did find it interesting that Nvidia actually does have MCM GPU's, at least testing -> Nvidia first to using multi-GPU's and or separate chips for like RT and graphics? Nvidia may have some very big surprises for us, which I hope happens, if Ampere is just another version of Turing and pricing I don't think they will fare well.
    Auer likes this.
  7. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    12,408
    Jun 13, 2003
    Which you support with what?
    See above.
    Extremely unlikely that they'll put RT on separate dies from rasterization. Far more likely that they'll have dies with mixes of compute units. This would be like using a separate chiplet for FP units on a CPU.
    With chiplets GPU manufacturers can scale performance while keeping price under control, similar to how AMD has done with CPU chiplets. But do expect Ampere to be based on Turing. It'll be a die shrink, a few architectural tweaks all around, and perhaps the introduction of a chiplet arrangement, if history is to be a guide.
  8. noko
    4,418
    Apr 14, 2010
    Linked video for one.
    As for Nvidia and MCM for gaming, only Nvidia would know if and when. RT is a perfect application for a dedicated fixed function separate chip, all it has to pass to the GPU for rasterization are light maps, shadow maps, speculative maps, refraction . . . etc. Could use un-tessellated geometry parsing - bandwidth would be minimal. No clue and was only a thought. Getting yields high enough on a new small process node at Samsung and make enough chips for demand etc. makes MCM look rather desirable is my thought. I do hope Nvidia has some very big surprises for us. AMD may go a totally different route by not using fixed function hardware, which is totally opposite what I once thought. So Nvidia and/or AMD can really surprise us in the end for 2020.
    IdiotInCharge likes this.
  9. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    Because right now the RTX cores are separate. The 2080 series does have upgrades over the 1080. But the RT cores from what I remember are separate.
    So unless Nvidia does as you say and merge the capabilities between the two there will be a cap based on manufacturing node.
    It comes down to what Nvidia does with ampere. It's anyone's guess at this point.
  10. IdiotInCharge
    12,408
    Jun 13, 2003
    I can see how this might work, but the latency penalty involved for any deviation of RT usage kind of kills it in my mind, at least so long as a flexible 'hybrid' ray tracing implementation is needed.
    It's working quite well for AMD -- they've staked their entire CPU product lineup on it!
    They're separate in that they're not 'in line' with the raster cores, but they are distributed around the GPU die and they share extremely low-latency access to the same resources. Splitting them up would kill a lot of that.
    noko likes this.
  11. noko
    4,418
    Apr 14, 2010
    Just thinking here, with a separate RT chip, Nvidia could pack in a huge amount of RT cores 4x + over what Turing have, standardize RT performance between the different levels of GPU's where RT does indeed just works with minimal to no performance loss making it a turn on feature whenever possible.
  12. noko
    4,418
    Apr 14, 2010
    The thing about light maps are they don't change that much from frame to frame when you have a whole scene calculated as in all applicable objects. Only dynamic lights or changing positions as in shadows which could be many. Still a hell of a complex problem to work out but Nvidia already did that with Turing. Not sure what bandwidth internally the RT cores have to the rest of the GPU or if anyone tested or could test. I can't believe Nvidia left themselves no options to dramatically increase RT performance to level where it is just an all the time turn on feature for all games using it. So very hopeful they pull a new hardware revolution or be first at it. Fixed dedicated hardware can always do a fixed task faster, RT would definitely fit the bill faster than a software or more flexible processor method.
  13. IdiotInCharge
    12,408
    Jun 13, 2003
    That's the issue: essentially, every light needs to be 'dynamic' due to the possibilities of user interaction. You need to do the whole scene every frame, at least until a 'light source culling' algorithm can be put to use like what is used for z-culling to eliminate geometry and pixels that would otherwise be drawn over.
    They're making the largest processors ever made -- literally running up against a hard transistor budget. Adding more RT cores or adding flexibility to other cores in order to be able to perform RT calculations would eat into other transistor budgets and thus reduce performance elsewhere.
    They had to pick a point to balance it, and generally speaking have done well enough.
    Also remember that RT isn't just 'on' or 'off'; implementations and intensities vary, so just as Nvidia must increase RT performance alongside raster performance in Ampere, so must developers get better at using RT resources effectively.
    Which I think we'll see as essentially every game coming out for the next generation of consoles is going to want to claim to use ray tracing.
    Maddness and GoldenTiger like this.
  14. noko
    4,418
    Apr 14, 2010
    Ideally only changes have to updated and not whole light maps, add a flash light and movement -> only changes that that motion has will be updated. This is no different then current implementation from what I understand.
    I don't see the 12nm to 7nm EUV node giving much in order of chipsize decrease for adding allot more transistors while having good enough yields -> something has to give. Just shrinking down Big Turing would be around a 500mm squared chip with minimal performance increase yet probably terrible yields, at least initially. Unless midsize chips are release first for desktop with performance around a 2080Ti which would not be moving the needle for RT or overall performance - maybe just a cheaper price for that performance.
  15. IdiotInCharge
    12,408
    Jun 13, 2003
    You're making the assumption that all lights need to be static now, and that they need to stay static, outside of say a flashlight.
    I can think of many scenarios where this would be true, but I can also think of many scenarios where it isn't -- and I wouldn't want to be limited to the former.
  16. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    With Turing is already fixed. The problem is manufacturing nodes dictate how big that section of cores can be.
    If you did a multi programmable / unified core you'll be able to fit more of them. People forget the RTX chip is at the maximum for the node.
    When you do ray tracing on the card TDP increases beyond what any non Ray tracing game will do. There's another thing that increases. The draw calls increase. This means that what formally would be fine on the six core now requires an 8-core. 2080 is at 18 billion transistors, 5700 xt at 10 billion.
    Edit: if by fixed you mean the same number of cores regardless of model I doubt Nvidia would do that.
  17. noko
    4,418
    Apr 14, 2010
    Basically you only make changes, even if whole light maps over what ever bus you have - basic compression - other more advance compression techniques to limit latency can be used. Less data needed to be sent would tend to give less latency. Not every frame would need to be updated, some interpretation could also be used on the GPU.
    My thoughts: Vega 10 to Vega 20 with a minimal amount of transistor increase due to FP32 units gave roughly a 1.47 or 68% of the size of Vega 10. If Ampere performance per shader is roughly the same as turning you would need to shrink down TU 102 from 756mm^2 to roughly 500mm^2 for same to better performance - that would be a massive chip for a new node. If high clock speed and other improvements maybe a 400-450mm^2. If not then you have a less performing chip then your previous generation with a much higher cost to fabricate. Would make no sense. Ampere other improvements will most likely need more transistors to benefit as well. MCM seem to solve many of these issues, give you better yields, allow for much more performance, standardize fixed function features etc. Does not mean Nvidia can or will with Ampere, I just see it coming. Unless Nvidia just dumps RT cores and Tensor cores and modifies the shaders for RT or combines them in, I only see a more radical change will get Nvidia the next level.
  18. IdiotInCharge
    12,408
    Jun 13, 2003
    At this point I'm pretty much expecting them to do it.
  19. noko
    4,418
    Apr 14, 2010
    Tensor and RT cores on Turing are fix function blocks and are separate from the rest of the GPU so you have to have dedicated circuitry to hook them up. Separating those fixed function blocks and other fixed function blocks such as encoding/decoding video to a separate die would make no difference for the GPU just that they will still need to be hooked up but by a different means. Once you can separate the fixed function common in your GPU's like video encoding/decoding, RT, Tensor cores and other stuff which could be more broadly standardized between GPU versions - you can really start packing in the Cuda cores, cache etc. on a dedicated die and still make smaller chips for better yields. I just don't know if Nvidia is able to do that - are they more advance and capable hardware designer for MCM then AMD? Frankly they have a hell a lot more money to dedicate to something like that. Still maybe not Ampere but I see it coming.
    kac77 likes this.
  20. MangoSeed
    MangoSeed Gawd
    579
    Oct 15, 2014
    First you claim Nvidia is misleading people and now you’re saying it’s reviewers’ fault that people are confused. What exactly do you think reviewers should be saying that they aren’t?
    For anyone that’s interested there’s a lot of info out there that describes how current raytracing implementations work.
    GoldenTiger likes this.
  21. noko
    4,418
    Apr 14, 2010
    I find Nvidia misleading with RTX, they do show demo wise more raytraced lighting but in reality in games no lighting is really done. Really what Nvidia and I am sure AMD, Sony and Microsoft is not real time ray tracing from a technical point of view it is enhanced rasterization, by using limited raytrace calculations to better map out lighting effects. It is very limited and the scenes shown as real time raytracing is mostly pre-rendered lighting, likely by huge render farms that can take days to render the complex lighting for light maps etc. and not RTX at all.
    That is why some just don't see much difference between RTX on and off because it is very much limited. To have that high quality lighting actually done in real time you would need 100 samples/rays plus per pixel (for low quality) RTX is not even close to deliver the number of samples per pixel to effectively light up a typical game of around 1 sample per pixel. It falls so short of actual ray tracing I am not sure what to think. I do not see reviewers accurately describing what actually RTX is doing. It has sure potential but misleading, Nvidia showing beatifully rendered scenes where RTX is doing virtually nothing since it was already pre-rendered lightwise knowing many will just suck it up. For like VRay, RTX gives about a 40% faster rate when turned on but not real time render rates, that is it, not even close to realtime raytracing with the limits of VRay GPU (CPU VRay has more capability). If a reviewer showed RTX rendering fully a VRay setup scene to show what real ray tracing is and how hard it really is -> That may get the point across.
    kac77 likes this.
  22. MangoSeed
    MangoSeed Gawd
    579
    Oct 15, 2014
    The RT cores are embedded in the SM. Which means the shader core has very high bandwidth and low latency access to RT results. It’s certainly not the same as moving it to a separate chip. RT cores are essentially at the same level as texture units. You wouldn’t move those off chip would you?
  23. MangoSeed
    MangoSeed Gawd
    579
    Oct 15, 2014
    What pre-rendered demos are Nvidia passing off as raytracing? The Star Wars thing?
    Raytracing is simply sending a ray into a geometry data structure and returning the hit results. What do you mean by “real” raytracing. If you mean that the entire scene has to be raytraced then I’m sure you would agree that’s a pretty silly thing to say in 2019.
  24. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    Yup. You've also stated something I've been worried about before. I think I mentioned it earlier. The problem is because Nvidia isn't doing RT games justice this leaves wide latitude for someone else to come along and increase rasterization fidelity to give the illusion of a RT scene when in reality neither is doing it justice. This is the problem with letting demos and old games with updated textures and lighting go without stopping and dissecting how much of the product is ray traced and to what extent versus what's currently possible via rasterization.
  25. MangoSeed
    MangoSeed Gawd
    579
    Oct 15, 2014
    I really can’t wait for AMD to support DXR so you guys can stop equating raytracing with Nvidia as if they invented it.
    Maddness, GoldenTiger, kac77 and 2 others like this.
  26. Auer
    Auer Gawd
    1,004
    Nov 2, 2018
    Nvidia took the initiative here, and later all will benefit including AMD.
    Maddness, GoldenTiger, amenx and 3 others like this.
  27. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    Microsoft took the initiative. But the implemention matters.
  28. Stoly
    Stoly [H]ardness Supreme
    6,416
    Jul 26, 2005
    They invented the acceleration technology. so there's that. :D:D
  29. Stoly
    6,416
    Jul 26, 2005
    From a technical standpoint it is hybrid rendering and it can render RT effects in realtime (shadows, refletions, lighting, etc). Not full scene realtime raytracing. The scenes in the demos are real time rendered, no prebaked lightmaps, no prerendered RT effects.
    It is indeed capable of full ratracing and is orders of magnitude faster than previous solutions. As evidenced in many professional rendering applications with RTX support like blender.
    Maddness and IdiotInCharge like this.
  30. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    So are all DX12 cards and CPUs. Nvidia implementation is faster than what currently available. You can say that but it's not doing anything new. Nvidia didn't invent ray tracing.
  31. IdiotInCharge
    12,408
    Jun 13, 2003
    To split the middle: they do appear to have been the first to put a viable real-time solution together with a mix of dedicated hardware and a hybrid process that uses ray tracing for lighting but relies on rasterization for the rest of the rendering.
    GoldenTiger, noko and kac77 like this.
  32. DogsofJune
    DogsofJune 2[H]4U
    2,934
    Nov 7, 2008
    I still have my AIW 9700 Pro. Loved that card
  33. Stoly
    6,416
    Jul 26, 2005
    And who the hell said they did?
  34. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    Ever reviewer ever. The statement goes like this.. " if you want Ray tracing the only way to get it is with Nvidia." While it's technically true in a very limited scope, the truth is it's not.
    There's a massive performance hit. Everyone knows this, but instead of reviewers saying you're not going to get full scene ray tracing, and what you do have is at a far lower fidelity than what Ray tracing is capable of, instead they are saying things like, "Take a look at the quake demo," which leads everyone to believe that A) the entire demo is ray traced, when it's not and B) the only card capable of delivering those level of graphics is the Nvidia card which isn't the case.
    This is the area where it's deceitful. I'm glad Nvidia is pushing it but everyone should know exactly what is and isn't happening.
    noko likes this.
  35. kac77
    kac77 2[H]4U
    2,291
    Dec 13, 2008
    I have absolutely no problem with this statement. It's accurate.
    Basically all I want is for the topics to be discussed with enough honesty that people who read and listen to reviews come out smarter in the end. I really don't care which company it is. I have AMD and Intel systems and no AMD GPU cards because I run a virtual gaming box on my Ivy server.
    Here's the guide I did it's got my hardware there. It's still used today but the hardware is the same... Intel and Nvidia.
    Guide: GPU Passthrough Using KVM + LVM2 + Ubuntu Gnome - From Beginning to End
  36. Stoly
    6,416
    Jul 26, 2005
    Nvidia IS the only brand capable of that level of graphics. At least till next year.
    GoldenTiger and IdiotInCharge like this.
  37. MangoSeed
    MangoSeed Gawd
    579
    Oct 15, 2014
    That would be a pretty pointless thing to say. Here are a few other pointless things reviewers don’t say.
    “This desktop CPU is really fast but it’s not as fast as that supercomputer over there!”
    “This is the only card that can achieve 60fps at 4K. But I want to remind you that it can’t do 60fps at 8K. Buyer beware!”
    “This game has some of the highest resolution textures we’ve ever seen. Sadly, they’re not as high as they could be if we had 100x more memory.”
    Seriously though you would need to be pretty clueless to think Nvidia cards can do full scene raytracing in real-time.
  38. IdiotInCharge
    12,408
    Jun 13, 2003
    Of course there's a performance hit -- but it's not unplayable by a long shot.
    Further, there's plenty of ignorance out there, and you're absolutely right to call it out. Nvidia's ray tracing hardware does 'just work', but making it work well with rasterization and modern game engines is going to take a lot of work, work that's just starting.
    With respect to the Quake II RTX demo, it's not that the whole game is rendered through ray tracing -- it's that the lighting is. The rest is rasterized.
    And yes, currently Nvidia hardware is the only hardware capable of delivering such visuals. But that's just AMD running along at their average two year follow distance -- it's not like RT hardware is hard.
  39. noko
    4,418
    Apr 14, 2010
    Yes it is capable but the results are rather horrendous at times with a lot of noise and those demo's are still hybrid I do believe. Typical of low photon/sample rates per pixel. True hardware capability for real raytracing, VRay 2080Ti without using RT vs with gives a 40% boost in speed, not 200% or 3000%, just 40%, that is all what the hardware can give for real Raytracing. My Vega FEd can render sorta nice quality raytraced images rather quick in Blender or Modo, two of those will probably beat the 2080Ti using RT for real raytracing. How presented, knowing the folks not really understanding and calling it real time ray tracing to me is an utter farse.
    kac77 and IdiotInCharge like this.
  40. IdiotInCharge
    12,408
    Jun 13, 2003
    So do an apples to apples? I'm pretty curious myself. Maybe see if they'll let you publish on FPSReview as a news article.
    Well, it's using ray tracing, and it's real time, but I agree that it should be made clear that the hybrid rendering being done isn't 'real-time full-scene ray tracing'.
    kac77 and noko like this.
