KazeoHin
- Sep 7, 2011
Has anyone managed to flash a retail 4GB -> 8GB ?
Im pretty sure someone did on the first page.
tommicn00bie
I was reading on the techpowerup site that people have peen reporting that the 4gig card was actually an 8gig with the bios locked to 4. So I tore my card apart and it was indeed 8gig with the 8 Samsung chips ending in FB as seen on the screenshot attached. I flashed my bios from the one provided on techpowerup and it is working perfectly. Happy days.
I bought the reference 4gig XFX card from Ebuyer.
Sorry in advance if I mentioned sites if I'm not supposed to.
so few responses. i guess not very many [H]ers have been able to get their hands on a sample.
How do we when we can't even buy one ? Sort of wished I had pulled trigger on launch day but waited a bit to see 1060, but I'm leaning towards there being nothing to see there and will stick with 4GB RX480, when I can get one :/.so few responses. i guess not very many [H]ers have been able to get their hands on a sample.
So far liking this 480. Reference design is super quiet on default, almost scarily so for me coming from a the old 7970. Also do they dynamically set the voltages for these things, my card has much lower voltages than the reference design for review samples. Seems the newer batches might be doing better?
yea they do. Are you looking at voltage during desktop usage? did you run GPUz and click sensors and click on the voltage section until it says max in green letters and run a 3dmark firestrike as its pretty intense. GPUz should record the max voltage once the benchmark is done.
rennyf77 Finally got around to playing some Battlefront. Made a quick vid showing the Speeder Chase in Ultra, and plotted the GPU-Z data (last image in album; finally figured out how to use the secondary y-axis in libreoffice).
Dunno what happened today--yesterday I was doing pretty good. lol
Edit: YouTube crapped all over the video when they transcoded it. >_<
Haven't tried overclocking but I put it in a B150/6500 system I built for my daughter and fired up Tomb Raider from 2013 that I got for 4 bucks off GMG, and it is running ultra max with TressFX fully enabled FXAA on at 1080p 55-60 fps according to the built in benchmark. Pretty happy.
Have not heard any fan noise and that is with system is up on the desk with me with the side off while I finish the build even after several hours of gaming.
Messing around a bit with voltages and freqs, managed a solid 1355 while running heaven (and almost 40fps 1440p max settings, 2xAA), then opened wattman again to take a screenshot and it crashed. lol
I had managed to finish the benchmark at 1360, but then I started getting greedy, dropped the voltage more and increased the freq, and it started crashing left and right. Managed to get it somewhat stable again at these settings.
Speaking of which, does anyone know the safe-ish side for boosting the memory voltage? That seems to be my weak link as well but I've been afraid to tweak that voltage.Seems like if you change it from % to "Dynamic" it actually stays at whichever frequency you set for the powerstate it's in, instead of the fluctuations you get with the offset OC. Rather than Dynamic, they should have called it Static, I think.
1375/2250 is pretty impressive, I've only squeezed out 2050 on the memory side, although I did leave that on automatic voltage. I think I'm content with what I got, at least until I put a block on it. 7W idle and 160W load is pretty good at 1355, IMO.
Good luck--did you catch them earlier today? I saw one go in stock earlier, but it was out before I went to the page, don't remember if it was gigabyte or not.unfortunately benchmarks are often unreliable when it comes to oc stability-unless you're testing with furmark. good luck with all of you testing the limits of your polaris cards. i will join you as soon as i can get my grubby mits on a gigabyte aib sample.
lol that firestrike score is funny......maybe it was extreme or ultra test? lol my 280x scores WAY higher...j.k i know that cpu was really holding it back, but i never seen one so bottle necked before lol I think you need to redo that testGood luck--did you catch them earlier today? I saw one go in stock earlier, but it was out before I went to the page, don't remember if it was gigabyte or not.
Here's my Firestrike/Timespy scores (with OC, compared to futuremark's "VR Ready" machine). Please ignore the poor combined score--my A10-6800k is showing it's bad side.
Note that my monitor was set to a virtual resolution of 1440p for both tests, I assume the resolution was changed before the test began, but it's not made clear on the results page. Also, they aren't "valid" results because it fails a time variance test, but nothing looked out of place visually, so take that with a grain of salt.
It's whatever the default is--I haven't paid for the full version.lol that firestrike score is funny......maybe it was extreme or ultra test? lol my 280x scores WAY higher...j.k i know that cpu was really holding it back, but i never seen one so bottle necked before lol I think you need to redo that test
I scored 8 598 in Fire Strikeyou are looking at the overall 3dMark score which as you hinted you know it's badly affected by his CPU score, you have to look at the Graphics score which its 13.292. About ~46% Faster than my last FireStrike Result with a 280X which was 9096, so I think you are reading it wrong the score it's perfectly fine. I jumped early off that card so I really don't know how much optimizations it could have received but that score shouldn't be much more different than any other more recent and actual score from a 280X could you post one recent firestrike score please?.
Dont nock it if it works right?I was having trouble with temperatures so I embarked on this adventure with my Sapphire Nitro+ OC.
Tech Macgyver Cooling with the Sapphire Nitro
