AMD Radeon RX 480 8GB CrossFire Review @ [H]
Discussion in 'AMD Flavor' started by Kyle_Bennett, Jul 11, 2016.
  1. Nenu
    Nenu Pick your own.....you deserve it.
    17,579
    Apr 28, 2007
    I agree.
    A lot of work is needed to make it viable for me.
  2. toddw
    toddw [H]ard|Gawd
    1,348
    Sep 9, 2004
    Guys, this is what I was trying to get at... and I don't think was clear.
    Brent took frametime stutter into consideration.
    Last few comments makes me wonder if follks understand this. The IQ and the resolutions Brent used in testing, TOOK XFIRE STUTTER INTO CONSIDERATION. The IQ and fps you see in the review already accounted for it.
    I don't mean to say it's not an issue, or to say whether it's worth it or not, just wanted to be clear on that matter for myself and everyone else. Sorry don't mean to rant, done.
  3. Thannatos
    Thannatos n00bie
    11
    Jun 20, 2008
    Looong time lurker (since 2000), so forgive the noobiness but I have a question and this is obviously the best place to ask.
    I see in the reviews and discussion that SLI/X-fire have input delays and stutter. My last build was a pair of gtx 280s to finally max out Crysis (1) at max setting and 1920x1200. Yes it has been a while and only recently have I had time to look at a new build. I am actually leaning 1080 and 1 or 2 based on responses...
    Understand, I am not a competitive gamer, but I enjoy FPS' and I am quite sensitive to stutter and tearing, but I do not have a good feel for how sensitive I am to inout lag. That said, I have found that setting up SLI, and in the control pannel forcing v-sync and 0 prerendered frames always gave me smooth as silk performance with no noticable input lag.
    So, my questions: 1) does V-sync forcing refresh rate to the monitor help with the pacing? 2) Is zero prerendered frames something you guys are using with multicards, snd do you find that it increases or decreases i put lag?
  4. 460cidpower
    460cidpower [H]Lite
    109
    Jul 8, 2004
    Just buy one good 1080 and be done with it. I've sworn I'd never do CF/SLI ever again, each time I do I regret it until I dump it for one good card.
    {NG}Fidel and CSI_PC like this.
  5. viscountalpha
    viscountalpha 2[H]4U
    2,125
    Oct 16, 2011
    It's still not the year for two card solutions. I still just want a single 1070 right now.
  6. CSI_PC
    CSI_PC 2[H]4U
    2,243
    Apr 3, 2016
    I would wait a little longer just for prices to correct for custom AIB models, and also to see which partners release custom BIOS to increase voltage to say 1.5V to under 1.2V.
    The problem is the 1080 is not well priced (same situation with the 980 at launch) and depends how much this affects you in terms of value.
    Also most of us are expecting the Titan/1080ti to really benefit from having more GPC and SM, and this can be more important moving to latest generation games, but that is seen to be at least 4 months away even for the Titan model (and the Ti could be several months later).
    And then the rumours of the 490/490x equivalent releasing probably in Q4 as well.
    But then thinking like that would get into the mindset there is never a good time to buy a card :)
    Comes down to how much value is a concern to you for getting that good performance.
    At a minimum worth waiting another 3-4weeks if you can to get the best 1080 that suits you, and by then we should have a better idea if custom BIOS will be released by partners.
    Asus has released their XOC bios now, but that is designed for good watercooling solution and does not have much flexibility as it is more for the extreme OCer.
    Cheers
  7. vjhawk
    vjhawk n00bie
    17
    Sep 2, 2016
    RX 480 crossfire looks bad. Looks like a single GTX 1080 is the way to go.
    Or you can wait for 1080Ti or RX 490. But looking at performance of the RX 480 ~ 1060 level or slightly less, the best we could hope for is the RX 490 to compete with the 1070.
  8. Archaea
    Archaea [H]ardness Supreme
    7,485
    Oct 19, 2004
    FWIW,
    I love my Fury X crossfire pair. I never have issues in the titles I play. I'm not juggling turning crossfire on and off. It just works well! I'm assuming the real world driver experience should be equally smooth on the RX480.
    The games I've played since getting the crossfire pair:
    Doom
    Shadow of Mordor
    Path of Exile
    Dirt Rally
    Star Wars Battlefront
    Battlefield 1
    Mad Maxx
    Witcher 3
    I've not had to juggle crossfire on and off for any of these. Granted I only started playing with Crossfire around Black Friday of 2016, but my experience has been painless.
    pendragon1 and cageymaru like this.
  9. TheLAWNoob
    TheLAWNoob Limp Gawd
    346
    Jan 10, 2016
    Consider yourself lucky. Crossfire had terrible scaling for NFS 2015 and had to be turned off for CSGO. It worked great in RoTR and Hitman though.
