AMD Radeon R9 295X2 to feature hybrid cooling solution
tobi54
BueweenPC has some exclusive, confidential information about the upcoming Radeon R9 295X2.
According to their story, AMD has showcased the reference model of R9 295X2 behind the closed doors at CeBIT. Only few people had the opportunity to see it.
Dual-Hawaii is called AMD Radeon R9 295X2
The site claims that the official name is Radeon R9 295X2, not R9 290X2 as we previously believed. AMD already has few entry-level cards with a similar 2×5 naming nomenclature, so it is not very surprising. Speaking of 295, the codename does remind us about GeForce GTX 295, which was also a dual-GPU card.
AMD Radeon R9 295X2 is clocked at 1GHz
Official slides, which were shown to the editor of Bouweenpc supposedly confirm the clock speed of R9 295X2. Of course this also brings a lot of speculation whether R9 295X2 is even a full fledged Hawaii-based card or, for instance, it features 2560 SP versions.
AMD Radeon R9 295X2 has a hybrid cooler
AMD Radeon R9 295X2 would arrive with a hybrid cooling solution. The cooler would be equipped with an external 120mm fan, something similar to ASUS ARES II cooler (as shown below). Apparently two AMD partners confirmed that the sample shown at CeBIT was indeed a reference model.
This is a very interesting move from AMD, and probably one of the best ideas for dual-card so far. We all know that Hawaii-based cards do need a proper cooler, unless the owner is deaf.
What surprised me, is that reference cooler (which could’ve been just a prototype) wasn’t even red, instead it was covered in black and gray, but I’m quite sure AMD will paint it into more bloody colors.
AMD Radeon R9 295X2 will compete with GeForce GTX 790
Well, I know, who would’ve expected! The rumor has it that NVIDIA will push forward GTX 790 launch, so we should see both cards in a very short timeframe. AIB partners were officially briefed about the new card this week, so it’s probably a matter of few weeks (if not sooner) till we see first cards on the market.
http://videocardz.com/49964/amd-radeon-r9-295x2-feature-hybrid-cooling-solution
cortexodus
Ares II was the same, so it makes sense that a card with an even higher need for dissipation would have a similar configuration. Makes me wonder if it will be a 240mm cooler for the new card, but I doubt it since 120mm is maximum compatibility.
XViper
That looks like a liquid cooling solution for the Ares. I guess fans don't cut it.
tobi54
I was kindda looking forward to this, but that cooling solution kills it for my setup... lets see what AIB's come up with.
cortexodus
I'm sure fans would work, but it would be big and loud. No-one really likes that.
Mounting an AIO unit is really no different than this "mod", it's just cleaner and OOB. I have a 6870 with a Kuhler unit mounted to it, and used to have 2x 570s in SLI done up the same way. Works great! :D
If you look at the pump units inside the card, they're virtually identical to all the circular style Asetek coolers out there, they're just using direct-in plugs instead of 90 degree ones.
