What kind of monitor, rincewind? The 290 and 290X are digital only. They do not support analog connections. Could indeed be a compatibility issue.
Both monitors are connected straight DVI-DVI - I haven't used a VGA connection since the CRT days.
DVI Digital or Analog?
If it's DVI-A or DVI-I using analog you are not going to get a signal.
So long as your monitor supports DVI-D all you will need is a new cable.
Both monitors support DVI-D and came supplied with DVI cables (as well as a regular D-SUB) which I would assume are digital...but how would I tell, as I've honestly never heard of DVI-A or DVI-I ?
Well I have used 2 290s in CF for half a week now. I got one thing to say, when it works it works well, when it doesnt its a pain in the ass. For my first foray into multi-gpu set ups not quite so smooth. Also the 290s throttle like crazy on stock fan settings. I have to crank it up to 70%+ fan setting it seems to run at 975mhz with out throttling.
if the cables came with the monitors it's possible they are not digital.
I'd thought about going CF if mining works out, but I'd probably be cutting it close on a TX850? The CPU is relatively cool under air (Megahalems push-pull) so I could just WC the 290s, which my setup would easily handle.
So is the problem mostly throttling, or are there quite a few games where you are having CF issues?
Throttling is my biggest issue. The only game I have played with it is BF4. I had a lot of issues earlier with beta 9.2, so I installed the 9.4 and it was better until I flashed one of my 290s to 290X and it went nuts. I had use ATi man uninstaller to uninstall the drivers and reinstall and everything is ok so far. But playing BF4 at stock fan settings I see an avg clock speed of 850mhz. I have to crank it to 80% to have it run at stock clocks without throttling and boy is it loud.
