AMD Radeon HD 6990 Details Leaked
Discussion in 'AMD Flavor' started by HardOCP News, Mar 1, 2011.
  1. HardOCP News
    HardOCP News [H] News
    0
    Dec 31, 1969
    The Turkish website Donanimhaber has leaked the details of the upcoming Radeon HD 6990. I'm reposting the leaked slides for those of you that can't access the site directly.
  2. yang88she
    yang88she 2[H]4U
    3,894
    Nov 10, 2004
  3. DarkSideA8
    DarkSideA8 Limp Gawd
    254
    Apr 13, 2005
    If those numbers are not just marketing - that's pretty sweet!
  4. rmfa
    rmfa [H]Lite
    123
    Jan 6, 2010
    I can't wait to get mine!!
  5. ObyTwo
    ObyTwo n00bie
    37
    Jul 2, 2009
    *EDIT* nvm, got the two mixed up.
  6. nobody_here
    nobody_here [H]ardForum Junkie
    9,474
    Feb 1, 2006
    it looks impressive if marketing slides are to be believed
    but the AUSUM.....Uber mode...??? really?/??
  7. yang88she
    yang88she 2[H]4U
    3,894
    Nov 10, 2004
    haha, seriously...taking a page from EVGA marketing FtW!!!
  8. TechBoy
    TechBoy 2[H]4U
    2,555
    Oct 1, 2006
    wow those slides at the end are crazy, stating nearly perfect scaling with 2x6990s. If that is true then I might just justify getting 2 of them....
  9. TwistedAegis
    TwistedAegis [H]ardForum Junkie
    8,916
    Oct 7, 2009
    Gotta love the scales on marketing graphs...108% is 3x as tall as 100%! 6990 is 67% faster than gtx580, but 400% taller on the graph! :rolleyes:
  10. zyzeast
    zyzeast Gawd
    939
    Sep 15, 2010
    if 2x 6990 scales that well, doesn't that mean 4x 6970 would scale just as well?
  11. JMccovery
    JMccovery 2[H]4U
    2,434
    Feb 9, 2006
    The HD6990OC version will apparently have 3 PCI-E power connectors: 2 8pin and 1 6-pin, that's the only way I can see getting 450W on a card.
    If the Asus Ares 5970 came loaded with 2 8pin and 1 6pin, then, what would the Ares 6990 come with? 3 8pin? This also makes me wonder how many connectors the Asus Mars GTX590 and EVGA GTX590 FTW cards will come with...
    *67% faster than GTX580, if true, would be amazing, though I wish the stock 6990 could be 67% faster than the GTX580.
    EDIT: I wonder if AMD will release a STREAM version of this card.
  12. TechBoy
    TechBoy 2[H]4U
    2,555
    Oct 1, 2006
    maybe but I dont have room for 4x 6970s in my case or motherboard.
  13. Betaboy1983
    Betaboy1983 [H]ard|Gawd
    1,198
    Dec 31, 2008
    I love to get one. Just let me mortgage my house here, especially since I would need a new PSU too.
  14. AtkinS
    AtkinS Gawd
    815
    Nov 7, 2007
    if those powertune things work like they say, and 20% more airflow, AND the vapor chambers, that could mean its less noisy than 5970, and is actually a better card than 5970 in terms of just working.
    5970 was seriously the first proper dualcard to just work.
    GTX295 is the 2nd on the list.
    then we have HD3870X2.
    Theese cards get mighty advanced in terms of board design, cooler design and power control methods.
  15. Raap
    Raap Gawd
    718
    Jul 12, 2008
    What on earth did they do to be able to claim a near 100% scaling with two of these? Have they magically solved all scaling problems somehow? If true, this is *huge*.
  16. mrpc9886
    mrpc9886 Limp Gawd
    404
    Feb 1, 2008
    I'd like to see a comparo against dual 580's.
  17. Stoly
    Stoly [H]ardness Supreme
    5,448
    Jul 26, 2005
    To be fair, I've seen 100+% scaling before for nvidia, but I think this is a first for AMD.
  18. Raap
    Raap Gawd
    718
    Jul 12, 2008
    No you haven't, not with 4 GPUs. As I said, this could be huge.
  19. BloodyIron
    BloodyIron 2[H]4U
    2,183
    Jul 11, 2005
    Why is this only coming with miniDP to SL DVI instead of DL DVI? UGH.
  20. mrpc9886
    mrpc9886 Limp Gawd
    404
    Feb 1, 2008
    In fact, looking at the cheesy way AMD played with the Y axis on their comparison chart against the 580 it would seem that SLI 580 would smack the 6990 like a little bitch.
  21. BloodyIron
    BloodyIron 2[H]4U
    2,183
    Jul 11, 2005
    They're talking about the same card, if you switch the BIOS toggle from position 2 to position 1 it naturally overclocks it and that is what they are illustrating.
  22. InfernalMachine
    InfernalMachine Limp Gawd
    418
    Jan 8, 2004
    Mmmm, I *Just* bought a 6950...I wonder if I can fit one of these in my case...=D
  23. Elsie
    Elsie Limp Gawd
    170
    Feb 1, 2009
    I want some phase change TIM, it sounds like the worst idea ever
  24. samuelmorris
    samuelmorris [H]ardness Supreme
    5,489
    Dec 20, 2010
    I like it, and believe it, except for 'Antilles Unlock Switch for Uber Mode' - That is completely out of character with anything AMD have ever marketed before. I'm suspicious, very suspicious.
    However, the rest of it seems very plausible.
    Look at the size of those VRMs!
  25. tory
    tory Limp Gawd
    172
    Jan 31, 2011
    Most likely But i would rather pay ~599 - 699 for a dual card than 1000-1200 for 2 580s or 1000+ for a 590
    but i do agree the graphs are bad
  26. Kardonxt
    Kardonxt 2[H]4U
    2,474
    Apr 13, 2009
    Sigh so would I need an second active display port adapter to replace a 5970? Cause that tacks on another $100.
    I wonder if they actually did something to get 100% scaling or if its just a load of BS or just works in 1 benchmark. If its a driver update I'll just buy another 5970.
  27. Yakk
    Yakk [H]ardness Supreme
    5,816
    Nov 5, 2010
    Impressive!
    That is a lot of juice going into 1 pcb!
    Great marketing too, at a rez. of 7680 x 1600 I'd wager the 580, even in SLI just simply run out of memory. Looking at the 3gig model minimum. Though if your in the market for a 6990, I'd say multi-monitor is a priority and that is certainly a possible target resolution for you.
    The quad scaling is truely awe-inspirering if correct.
    Y.
  28. Tak Ne
    Tak Ne [H]ard|Gawd
    1,087
    Jan 28, 2008
    Antilles Wonderful Extension Switch for Overclocking Mode Enhancement would have been better.
  29. weebling1
    weebling1 2[H]4U
    2,238
    Aug 31, 2002
    Imagine that. I came to [H] today wondering when we'd hear specs on it. Touche'
  30. Lord_Exodia
    Lord_Exodia [H]ardness Supreme
    6,998
    Sep 29, 2005
    AMD appears to be bringing it. I mean anything you could ever dream to imagine for this card is here. Amazing cooling, quieter than previous dual chip operation, Exceptional scaling, dual bios mode, 2gb x 2 vram etc..
    Nvidia has their work cut out for them. I'm not gonna count GTX 590 out yet. But it's looking like another AMD win and my gut also tells me price will be in their favor too. :)
  31. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    49,526
    May 18, 1997
    That stole the page from the BFG Tech book.....
  32. Ultima99
    Ultima99 [H]ardness Supreme
    4,596
    Jul 31, 2004
    Looks good, but would still rather have Vega's rig. :)
  33. Lorien
    Lorien [H]ardness Supreme
    4,896
    Aug 19, 2004
    Thanks! March is shaping up to be a fun month. HD6990, GTX590, and quite possibly Bulldozer performance figures. Can't wait.
  34. amdgamer
    amdgamer [H]ardness Supreme
    4,920
    Oct 27, 2004
    I am skeptical about this, but optimistic at the same time. If this ends up being true, then I am speechless. If this ends up being true, then I think those of you who were hoping that Antilles was going to be a bargain just had your hopes dashed. This is going to be one incredibly expensive video card.
  35. QuothTheRaven
    QuothTheRaven [H]Lite
    120
    Dec 30, 2008
    No, Active DislayPort adapters are less than $30 now.
  36. Flyinfinni
    Flyinfinni [H]ard|Gawd
    1,313
    Nov 24, 2009
    only for active DP - single link DVI- not dual link.
  37. kllrnohj
    kllrnohj [H]ardness Supreme
    6,848
    Apr 1, 2003
    Why would you? It comes with all the adapters you need for 3 monitors. If you already have an adapter, you'll end up with a spare.
  38. BobDaMann
    BobDaMann n00bie
    13
    Feb 9, 2011
    All right, perhaps someone can clear this up for me.
    In the slides it mentions PowerTune which is optimized for gaming rather than non-gaming benchmarks, is this similar to TurboBoost on current Intel chips?
    Does this means that during a particular taxing moment in game it will boost your cards power until it reaches the TDP ceiling or am I way off?
    Sorry if this is common knowledge!
    Thanks!
  39. Flyinfinni
    1,313
    Nov 24, 2009
    only if you keep the resolution for each monitor at 1920x1080 or lower.
  40. QuothTheRaven
    120
    Dec 30, 2008
    Oh, good catch. My monitors are 1920x1080, so I tend to forget about these distinctions.
