EDIT// Also, I'm not familiar with companies that sell ATI cards, is there one or two in particular that are especially reputable (like evga is to nvidia) ?
Anyone else notice how the GTX 260 gets better minimum framerate figures, particularly in Crysis? What's the issue?
Looks like these are going to be wildly popular (I have already sold 4 in yet to be built systems and I havent even laid hands on one to play with. ). I have found posts where existing aftermarket cooling was modified to work but it was a bit of a kludge.
How about an quick article on the availability of existing (none probably) and upcoming 3rd party cooling solutions, a couple of phone calls would do it I bet. And my most pressing question which is 'what is the options/dimensions/hole sizes around the cpu area?' if any, and what existing waterblocks could be fitted.
Just a thought, off now to see if anyone has already done this work up.
Would I see a good benefit going from a 8800GTX to a 4850 or 4870? Is the 8800GT on the chart a good point for comparison for me?
A 620HX might be okay with 2 4870's. The fella in the general video card section said he was running 2 of em in CF on a 620HX so maybe ask him how his power usage is. Either way, I have a 620HX and its a damned fine power supply. Been running 3 HD's (including a Raptor X) with a P35, OC'd Q6600 and OC'd 8800Ultra and I draw 320 at the wall at load so maybe 260 total at PSU assuming 80% efficiency. I can't see the 4870 drawing that much more power than the 8800Ultra and another one in there you might be near the sweet spot of 50-60% of full PSU ability at load.
Slower "PPD" than the CUDA cards, because those were optimized for speed rather than stability... Check the F@H forums.How does it fold?
what's better the 4870 or 2 3870's setup as crossfire?
All I can say is my faith has been well placed. Finally price, performance, and more user-centric business practices are found in one product from one company. And my faith in [H] as well, in delivering a fair review. To all the [H] staff, I apologize for maligning you over the last year.
Who gives bigger bags of cash: AMD, nvidia or Intel?
Awesome, welcome back AMD, we missed you.
I read a bunch of reviews and I'm still confused on this 7.1 audio support. Does this mean it is basically a sound card too? If I have onboard sound will this automatically take over? How do I connect it to my receiver? Can I use both the DVI outputs at the same time? One would go to the monitor and another to the receiver via HDMI adapter?
They don't - they just route it via the PCI-E interface I believe. You do have to enable it via your OS but it's very simple to enable and disable.
It attacked issues such as power consumption (a legitimate issue, but a foible that Nvidia quickly reproduced, to [H]'s silence), and the entirely trivial 'fan noise'. Really, what enthusiast gives a whit about fan noise in relation to performance?
Who cares about noise? I'm not sure if I should take this seriously or not...
wow those charts are horrible also why is the settings / res different for each card when your comparing them .........wtf?
