Hello Forum, Hope someone can point me in the right direction for memory for the system I am going to build. I have currently bought:
3900x
Gigabyte Aorus Master x570
Corsair RM750i
Gigabyte 1660 Super GPU
I need advice on the RAM. I am looking for 64GB RAM for my system. I initially ordered the Corsair CMK32GX4M2D3200C16 Vengeance LPX 32 GB (2 x 16 GB) DDR4 3200 MHz C16 XMP 2.0 High Performance Desktop Memory Kit. The reason behind the purchase was the SKU was on the Gigabyte supported memory in the manual. I ordered 4 sticks. I thought I had dome my homework but I began to read that the Ryzen is picky with RAM and some posts recommended AMD optimized RAM. SO I ordered CORSAIR VENGEANCE LPX 32GB (2 x 16GB) DDR4 3200 (PC4-25600) C16 1.35V AMD Optimized Memory (CMK32GX4M2Z3200C16). This is optimized for AMD (not sure how or why) and it is also more expensive.
I am now in the dilemma of using the CMK32GX4M2D3200C16 that is supported in the Aorus Master manual or the AMD optimized (and more expensive) CMK32GX4M2Z3200C16 part.
I game a little, I do not overclock and use the the RAM and CPU cores for VMs I need for work. I need a stable system for my 3900x. My Intel 2500K was bullet proof for the last 8 years and I need something to replace it. I would really appreciate it if someone could steer me in the right direction. Gut feeling is the the CMK32GX4M2D3200C16 is ok because it is Gigabyte approved.
TIA, xmalxx
3900x
Corsair RM750i
TIA, xmalxx
