TrueFree coolers are great for some. Not for the [H]ard, though.
Once again, the answer to your question is in #342. Read it carefully, because they explain why CL16 --> CL12 RAM improves performance, but AGESA 1.0.0.2 --> 1.0.0.4 does not.
I exactly wrote what quote said.if they say :
then How come they get zero performance but "The Stilt" did test on hitman and got 16% more fps? OC3D only tested AIDA.either AMD used an algorithms to show fake numbers or Bench is wrong.Who knows.
Edit : I found one :
https://thetechaltar.com/amd-ryzen-agesa-1-0-0-4-testing/
He doesn't want to talk about Latest AGESA pinnaclePI (1.0.0.2a according to elmor) , only version 1.0.0.2 to 1.0.0.4Juangra. I've updated microcode on my X370 AsRock ITX to the most recent. Before updating I could only hit 2800Mhz, after updating I am now hitting 3600Mhz C16. Hell, this speed isn't even on my motherboards supported list. Edit: Was able to reclock to 3.8Ghz and it is indeed all stable.
The AGESA fix was more of a system stability and unlocking potential for higher clocks mostly on memory, running more aggressive profiles than prior AGESA BIOS settings. Very few boards could do 3200mhz pre update, after the update we got a board to exceed 3600mhz
Read my link :
I did, and the reply to your questions continues being in the post that I mention you again and again.
One reviewer Claimed AMD confirmed it and said Zero performance.One Benched and said average 2.45% more performance in games at least according to Link , Who is right? You still repeat it and I still don't accept.You don't need to reply.
Someone else used a similar argument and I replied him.
We can discuss anything, but not mix things or move the goalpost.
2.45% is within the error margin.
Two changes accompany these BIOS, the first concerns the DRAM Gear Down mode. When active, timed at 2666, some memory timings are released, including commands that switch to 2T instead of 1T. The second is called BankGroupSwap, and beyond the name we have no specific explanation of its role to give you for now.
From what we could see, the BIOS 5704 with which we had our tests Ryzen 7 already had the DRAM Gear Down Mode disabled, explaining the lack of gain. This was not the case for other public BIOS distributed by the motherboard manufacturers, we will come back to it.
Not an arguement. You just seem to try and bash AMD on anything possible. You are diminutive to the company. I own an 8700K PC and an R7 1700, I enjoy them both for their strengths and weaknesses alike. I've got better things to do than to bash a company on every social media platform possible however.
My first post was just a statement, be excited for AMD to support 3600Mhz+! When AMD wins, we all win.
I'll probably pick up one of these given that I need to rebuild my Core 2 Quad era server box! Is the 2700X supposed to be the top of the line this time, or will there be a 2800X? I figure that the 2700X is probably easily worth a few extra bucks over the baseline 2700, given the speed increase alone; iI wonder if it is also binned for better overclocking. I can only hope these Zen+ chips can OC to 4.5ghz at least, on all cores! I'm also curious about the "Wraith Prism" cooler - I am guessing by the name it is the RGB lit variety and probably the highest performance, improved variant for Zen+? I wonder how it compares to high quality after-market air coolers from Scythe, Noctua, and others. Sure, it may not be the absolute winner, but if it is at parity with the top tier air coolers and enables a solid OC as I described above (or at very least 4.3ghz all cores) it may be an even better deal, as those who were not going to liquid may nor need to buy an additional cooler.
I'm looking at picking it up from Amazon and/or Microcenter - don't they both usually have some sort of deal with lower prices especially if you buy a motherboard? Speaking of that, its nice you can pre-order the CPU, but about the motherboards? I assume that X470 will be the new top of the line and if I recall there was some buzz about significant improvements. It looks like Asus has a ROG posting announcement, but it isn't actually visible yet. Hopefully the Crosshair will again be "the" motherboard to pick up especially for OCing and other great features.
Anyone know why 2700X is top of the line this time? Think its going to "stay" as the top chip for Zen+ AM4? I don't know how likely it is for AMD to do so, but I don't want them to launch with the 2700X now and then a few months down the road they push out a 2800X or other chip? Are they getting rid of "Black Edition" branding by the way? Perhaps X takes the place of that.
I'm glad the 4.3 is realistic this go round, but you think 4.5 is going to be that difficult? I know Ryzen doesn't have much OC room, hopefully Zen+ is a bit better, but there's something a tad disheartening about not being able to overclock and get all-core turbo any higher than the default single core turbo value. Granted it won't be a total travesty especially as this will be a secondary/server machine for me, but it would be nice to be able to make a little higher on good air / AIO water, or especially custom-grade water.
Ah, so its on par with Hyper 212 EVO? That's pretty good then, for air, if I recall. I wonder if replacing the fan could give it even better performance. Given the pre-order page, it seems that only the 2700X comes with the Wraith Prism, where the others use Spire+RGB, Spire, or Stealth. Is the Prism a new design for Zen+ (or perhaps a revamped version at least) or is it the same as the original Ryzen coolers? Think it will handle that 4.3/4.4 ghz OC suitably at least? Kind of too bad they don't offer an OEM version for a little cheaper without the cooler.
I went ahead and pre-ordered the 2700x, should give a nice boost from my 1700. I'm hoping the XFR2 and precision boost curves can be modified ala p-state overclocking, would be cool if we could just ramp everything up 200mhz with added cooling instead of just going all core and gaining nothing in lower threaded apps.
3200 vs 3600.Why do they do this? surprising this one :
2700X is slower than 1600 in DX12 bench.How come?
ASUS already went ahead of you and added that to the ROG Crosshair VI Hero
Looking good! IF I hadn't build an 8700k box recently, I'd be springing for this instead.
So the difference between X470 and X370 is insignificant, just as CPCHardware and others said.
Actually we all figured that and said that, only you were inferring that the x470 was needed for full performance and features of the new Zen chips. What we said was using the A series chipset was stupid in that review.
A320 supports XFR 2. This is in the slides that were leaked days ago.
Some sites as videocardz are having trouble with the math of percentages. 175% is only a 8% faster than 161%, not 14% faster. The graph is correct.
You cannot do 175% - 161%, you have to do 175/161
The new Precission boost overdrive requires 400 series mobos. But what have been I saying since past year? What full performance would be only possible on new 400-series mobos? Funny that some people tried to crush me for saying that!
In any case overclocking in france esitmates a X470 mobo would add only 1--2% performance to Canard review results.
Ce qui implique que les CPU en question avaient leur Precision Boost désactivé, cette technologie n’étant que sur les cartes série 400. Cela ne change pas beaucoup les performances, 1 à 2% grand maximum, et ne change pas le ratio perf/conso en demi-teinte.
CPC Hardware explained before publication why are using A320 instead X370/X470: To avoid the omnipresent cheats in the X370/X470's BIOS ("Pour éviter les cheats à la con omniprésents dans les BIOS des X370/X470").
The overclockingmadeinfrance magazine also mentions that using a 400-series mobo wouldn't really change the performance or efficiency results, performance would change only 1 or 2% top maximum ("Cela ne change pas beaucoup les performances, 1 à 2% grand maximum").
Overclocking is a non-issue because CPC hardware tested all chips on stock settings.
300-series motherboards support both XFR 2 and Precision Boost 2. The only feature wasn't activated during the review was the new overdrive/enhancement boost, because that requires a 400-series motherboard. But as mentioned before
"They claimed that X470 is practically identical to X370 except for a few cosmetic changes." There is a rumor that X470 is simply a rebranded X370 with an improved BIOS. I will ask about it
According to CPCHardware and Overclocking made in france, replacing the A320 mobo by X470 only brings 1% or 2% moar performance. That is no "crippling" by any bit of imagination.
So mentioning that AMD refutes what techradar says about XFR2, mentioning that CPC review agrees with internal tests made by AMD, and asking if the GB mobo is 4+3 is... "attempting to bring AMD down"?
And don't forget that all what I wrote to Linus was correct.
I don't think what you imagine. It is obvious to me that they didn't got the hardware from AMD.
No one said that there is "no difference between a A320 and X470". You are just making up things again, instead reading what was written in this thread. I even posted the measured performance variation between A320 and X470. Go figure!
XFR is an automatic overclock feature that pushes clocks above the stock TDP, when there are extra cooling installed. Also your 1700 at stock isn't a 65W chip. The real TDP is 90W.
They don't theorize. They benchmarked performance in different boards, including X470. It is all in page 5 of this thread.
About NDA violations:
Ohh my. I had no idea the Ryzen 2 and new X470 motherboards were releasing this soon. I had to sell my Ryzen 7 1700 system back during the holidays, and I've been itching to buy a complete new system.
Looks like I'll be getting the 2700X & Asus X470 CH7. But what memory should I go with? I want an RGB kit with 16G.
