Just updated to windows 10 x64 pro from win 7 x64 ultimate-n. Ive been having nothing but problems with win 10, its showing my cpu is running between 2.2ghz-2.81 and keeps changing actively. Also its showing in both the task manager and in cpuz, as 4 cores opposed to 8 and its showing a lower l1 and l2 cashe than what the cpu has. Everything is taking a month to load, much longer than windows 7 did in every way. From boot times to opening any system process; sound/gpu options/disc cleanup/HDD properties/task manager/etc. It also wont load allot of things on my computer. Frequent crashes in gaming, as well. Ive had to deactivate my crossfire on several games in order for it to run, which it does in the slowest way possible. Only reason i upgraded to 10 was because of dx12 support and rumors that it will increase performance spreading operations to all cores of my cpu and better utilizing a multi-gpu system. Ive had nothing but problems. First things first though. How do i get my cpu to register as an 8 core cpu opposed to a quad core? i disabled all my overclocking that i had set on windows 7. Have also adjusted the power plan to default thinking this may be a compatibility problem with the OS.
System specs.
Amd fx8350
Asus Sabertooth R2.0 FX990
32gb DDR3 1800 crucial balistix udimms
2x msi 7870's crossfired
watercooling blocks on cpu gpu and northbridge stable @5.2ghz OC'd at 32C.
all overclocking is completely disabled right now, everything is running at stock speeds.
System specs.
Amd fx8350
