It's a good CPU, I found it comparable to the 2600k when gaming at realistic resolutions (native), not the rubbish resolutions that most sites review it at.
please not this again. if you test at completely gpu limited resolutions and usa max AA then you will have no idea how your pc will perform when you upgrade your gpu or want to lower settings to keep the frame rate. in other words if all a cpu can produce is 60 fps average and you want to upgrade your gpu then you still end up with 60 fps average and accomplish nothing. the 2600k and even 2500k are the better overall gaming cpus and will keep up better with the fastest gpus now and when you upgrade. if building from scratch then spending just a little more on Haswell makes much more sense then going with 8350.It's a good CPU, I found it comparable to the 2600k when gaming at realistic resolutions (native), not the rubbish resolutions that most sites review it at. And with the next consoles being based on 8-Core AMD CPUs, you we may start seeing more games optimized for 8-cores. Wouldn't be out of the question for a game ported from next-gen console that utilizes 8-Cores to actually run better on the 8350 than my 3770k. This is a solid deal.
Benchmarks aside Cannondale06, have you ever, PERSONALLY, used an 8320/50 system for gaming? I have always been an avid AMD fan, but buy what is the best performer based on the "benchmarks" the tech scene gives us...
If you look at my system below, you will see I am running a 3770K @ 4.8Ghz..It's a stupid fast cpu, and I love every bit of it..One of my best friends built an 8320 system with a decent 990FX board that came out to be ~$180 less then my 3770K combo (both were purchased @ MicroCenter)..We did a full WC loop and clocked the 8350 to 4.8Ghz as well..
The result with the same gpu installed? Identical from a "seat of the pants" experience in BF3 and MW2 (only two games we had time to put any time into)..On paper, my 3770K should be quite a bit faster in most applications and games..But sitting down, IN FRONT, of the system, I wouldn't be able to tell you which was AMD powered and which was Intel powered...Let's not forget that the combo was $180 less, which paid for the completely custom WC loop and allowed for a better GPU then if he had went the Intel route..
Since I know you love to argue your points like a rabid animal, lets look at some pricing:
Looking at MC's current pricing, the cheapest AMD 8350 and good 990FX MB combo is $257, or you could get the same MB with the nearly identical O/C'ing 8320 for 227!..The cheapest 4770K system with a decent board (which is the cheapest ASRock board) is $384.. That is $127 ($157 for the 8320 combo) you would be "spending a little more on"..
That $127/57 would pay for a nice 120GB+ SSD, a name brand Full Tower case with great air cooling, a high end AIO WC unit, or 65-85% of a nice AMD 7950 GPU (after MIR)...
So tell me again how much GREATER it would be to spend more money on a hot, poorly O/C'ing Mobile CPU in a desktop package??![]()
the 4670k is what I was referring to which is 100 bucks cheaper. and no way would I build an 8350 over a 4670k. the 4670k is faster and sips power compared to the 8350. oc both and the 4670k pulls even farther head while power usage for the 8350 goes through the roof in comparison. then next year when you want a faster gpu that 4670k is going to handle it better. and please not the future games will use more cores excuse. we heard that with the Phenom X6 cpus and they got left in the dust with newer games. so bottom line is yeah the 8350 is a good cpu especially for the money but would not be my choice if building a gaming pc from scratch. I would grab one in a heartbeat if I had a compatible mobo and just wanted a cpu upgrade though.
I can tell you from experience myself, just check out my sig. With identical videocards I don't notice a difference between the 2600k and 8350, when I play games at realistic resolutions. I'm not a fanboi so reviews that review gaming CPUs and gaming GPUs at low resolutions is frankly insulting. I game at high res, if I want to test actual CPU performance then run CPU based tests like Handbrake, and again I found the 8350 and 2600k run close in that.
Does this cpu have a lower fps floor as opposed to 2500k+?
You then said Haswell, and since we are comparing an 8 core AMD CPU, it only seemed proper to compare it against it's 8 core Intel counter part, which would be a 2600/3770/4770K..The 4607K can fall well behind in a number of games/apps due to only have 4 cores, a gulf that is only going to grow, not SHRINK..Even Intel points toward this with their planned release of an 8 core Haswell SKU next year no?
You mean Intel 8-thread CPU's, right? The 2600/3770/4770 are all still 4-core CPU's that are hyperthreaded.
Unless you are playing some old ass, poorly coded DirectX 9 game (even then you should have AMPLE power on tap), then no..Once O/C'd to the same speeds, I would take the extra 4 cores going forward..No matter how "some" may attempt to dice it, the moar cores the better is going to be trend over the next few years..If not you would have seen 2-3 highly clocked cores in the new APUs instead of 8 slower, more efficient cores..
maybe you have not checked out newer game cpu reviews because the 8350 is not getting any better looking for the most part. and the apus are looking quite pitiful compared to 2 cores from Intel.
also you can claim whether you want about your old Phenom X6 cpu but that does change facts. it fell further and further behind Intel quads even in games that used more than 4 cores.
no but it is inferior to the i5 in overall gaming. there are even a couple of games where it cant even maintain 60fps which I think is unacceptable. for the most part though there will be no difference in playable performance if 60 fps is all that someone needs.Did you experience gaming on the 8350 personally? Because I could tell you from personal experience that when I moved my Radeon 7930 to my 8350 machine for CFX and play Crysis 3 or Metro Last Light at max settings, it looks just as pretty and smooth as my GTX670 in SLI on my 3770k. At the price posted here for the 8350 ($170 at the time) I would have no problem recommending it over almost any i5/i7.
at what? facts are facts so fucking deal with it. make up whatever excuse you want to buy the 8350 and that does not change anything I said or can be shown in benchmarks. and I like how you skip right over the parts where I said for the most part there will be no difference when actually playing.Yup. That's because in almost every game the 8350 is enough for 70-100 FPS which is basically more than you ever need anyway. Personally I turn eye candy to max with 30 FPS as my acceptable FPS. Some people like 60 FPs obviously.
Cant believe cannondale is still at it after all these years. Like it's a job.
As for this actual deal, TD charges tax for me, kills it since 8350 is on sale for 180 (without tax) at newegg all the time.
