AMD FX-8150 Multi-GPU Gameplay Performance Review @ [H]
Discussion in 'AMD Processors' started by FrgMstr, Nov 2, 2011.
  1. BababooeyHTJ
    BababooeyHTJ [H]ardness Supreme
    6,947
    Jan 21, 2009
    How exactly do you bench a multi-player game properly? [H] doesn't use the canned benchmarks that you are used to. Go back to toms hardware.
    If you had to make a conclusion based on the rather large list of games in this review......
    I haven't seen a cpu review this well done in years.
  2. SamE
    SamE [H]Lite
    126
    Sep 18, 2010
    Thanks for the review.
    Looks like Bulldozer dug its own hole...and buried itself alive.
  3. Insula Gilliganis
    Insula Gilliganis [H]ard|Gawd
    1,460
    Feb 6, 2007
    [​IMG]
    Zarathustra[H]'s condensed history of AMD's struggle with Intel seems fairly accurate.. although I wouldn't have used the term "inferior" when describing AMD's CPUs.. they just quite weren't as fast as Intel's. Looking at an old issue of boot magazine.. actually the very last boot (July/Aug 1998) before it became MaximumPC.. on pg. 45 there is a comparison between AMD's New K6-2 333MHz vs PII 333MHz.. the PII beats it in most benchmarks (games and synthetic) and the best the K6-2 could do is only tie a couple of times. It should also be noted that only once was an AMD CPU ever used in a boot/MaximumPC "Dream Machine".. the 2005 DM had dual AMD Opterons.. and that is only one out of close to 20 total DMs built. Even though AMD has been competing with Intel since the 1980s, only for a brief 2003-2006 period did AMD produce the clearly superior CPU. We all remember that time so we naturally are under the impression that AMD did it back then, it can do it again.
    Just to give AMD some positive vibes as I finish writing this, this was once written about a new AMD processor core..
    Those words were written by Kyle on November 19, 2007 after he reviewed the Phenom X4 9600. AMD was able to come back fairly well from that bad launch.. let's hope they can do it again.
  4. DooKey
    DooKey [H]ardness Supreme
    8,066
    Apr 25, 2001
    BD is a steaming pile of manure.
    /thread
  5. trick0502
    trick0502 [H]ardness Supreme
    5,141
    Apr 17, 2006
  6. umcpgrad
    umcpgrad 2[H]4U
    2,800
    Apr 2, 2004
    but win8 and bio updates and patches will fix bd
  7. pelo
    pelo 2[H]4U
    2,911
    Apr 23, 2011
    Tom's did a beta run of windows 8 with its improved scheduler and saw a roughly 10% increase in performance, depending on the task. It wasn't nearly enough to bring it up to a level where it's competitive for the current asking price. And then you should also ask yourself why you should buy a chip if you need to pay another $150 and upgrade your OS to see the benefit. Stating that windows 8 will improve performance isn't necessarily a good thing for AMD nor us consumers if you consider what it's implying: The chip doesn't do well right now and might do well with other future operating systems. It performs well with Linux because it's far faster to adapt, but there too it's slacking in IPC (which ultimately also hurts it's multi-threaded performance). Phoronix wasn't impressed either.
    The BIOS updates may fix certain games from crashing. But that's not exactly a silver-lining. They shouldn't be crashing at all.
    The biggest fix to bulldozer would be to dump the architecture and start over. Shorter pipelines, less cache latency, more focus on FP.
  8. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,450
    Sep 13, 2008
    i'm sure it was already asked, but is there any chance of getting comparable crossfire results to see if the actual problem is not the cpu and more of something having to do with the implimentation of SLI on the x990 chipset? not trying to start a conspiracy post or anything i just wonder if theres more to the story then just shitty cpu performance.
  9. jstnomega
    jstnomega [H]ard|Gawd
    1,706
    Oct 4, 2001
    anyone willing to play thru CIV V all the way to some kind of an end game position deserves my undying respect - personally, I'd rather watch paint dry :p
    (ps - FWIW, SMAC/X is always on my machines & still get regular play around here :))
  10. griff30
    griff30 I Lower the Boom!
    5,384
    Jul 15, 2000
    Nice review. Games up.
  11. sirmonkey1985
    21,450
    Sep 13, 2008
    i've done it but i'm lazy and i cheat to make it faster.. trainer's FTW!!! but i do it in sandbox mode so the only way to win is wiping out all the AI.
  12. Zarathustra[H]
    Zarathustra[H] Official Forum Curmudgeon
    28,315
    Oct 29, 2000
    I've beaten the game several times, on the marathon setting none the less.
    Thus far I've had victories by time, science, domination and culture.
    I love that game. can't get in to anything else quite as well.
    I'ts difficult to find the time though, and it pisses off the wifey when i spend all day on the comuter and none of it with her, so I tend to play FPS games I can join for an hour or so, and quit after a while instead.
    You can always save Civ games and continue later, but often if I don't play through them the same weekend, I lose interest and never pick it back up again.
  13. munkle
    munkle [H]ardForum Junkie
    11,193
    Jan 16, 2005
    what a stinker
  14. Zarathustra[H]
    28,315
    Oct 29, 2000
    "Designing microprocessors is like playing Russian roulette. You put a gun to your head, pull the trigger, and find out four years later if you blew your brains out."
    Robert Palmer, CEO Digital, on the AMD Board.
    Additionally, this CPU was primarily a server design adapted to the desktop.
    At low clocks (which servers usually have) power usage is very good, and it really does seem to be a kickass server CPU.
  15. vengence
    vengence Level capped
    18,471
    Nov 7, 2007
    The biggest thing all this tells me is CPU limiting will be very real again with the next generation of GPUs.
  16. BababooeyHTJ
    6,947
    Jan 21, 2009
    Very true, especially with the resolutions that many of us use or to 3d vision users.
  17. OverVolts
    OverVolts n00b
    2
    Nov 3, 2011
    I think what we have here is an Intel faggot posting fake benchmarks!
    Arma II is a game I play regularly and his review saying the only playable viewable distance is the lowest of 500 with very high detail is total bullshit. I seen another review I would believe over this one.
    http://www.bit-tech.net/hardware/cpus/2011/10/12/amd-fx-8150-review/9
    I have a MSI 990FXA-GD80, with dual GTX 480's and my FX-8150 is on its way from newegg.com. It's expected delivery day is this Monday the 7th.
    When my CPU arrives Monday I will prove it!
  18. vengence
    18,471
    Nov 7, 2007
    It's of INCREDIBLE importance to 3D vision users with them needing 60FPS to maintain an equivelent 30FPS.
  19. vengence
    18,471
    Nov 7, 2007
    Neat, except that's a canned benchmark, which means most of the CPU work is predone.
  20. alienz
    alienz Limp Gawd
    248
    Apr 14, 2002
    I think it will be interesting to see just how well BD as a stepping stone to the future many-many core CPUs plays out.
    Perhaps they will be able to ramp BD to a huge number of a cores much easier than Intel will be able to with their roadmap.
    Of course someone has to come up with a reason to have so many cores in a PC. Something I have yet to come across.
  21. Impulse
    Impulse [H]ardForum Junkie
    10,232
    Apr 5, 2001
    Did you really create an account to troll people as an AMD fanboy? You silly goose, everyone knows that's an endangered species and all current specimens were born around 10 years ago!
  22. mzs_biteme
    mzs_biteme [H]ard|Gawd
    1,595
    Nov 7, 2001
    Details, details, details............... Both reviews do conclude, however, that Bulldozer still loses to i5 in ARMA2.... So, great purchase there buddy...... Enjoy....:rolleyes:
  23. OverVolts
    OverVolts n00b
    2
    Nov 3, 2011
  24. Impulse
    10,232
    Apr 5, 2001
    Very unlikely... A) Intel has more cash to throw at BB to push their systems, not to mention OEMs. They got their wrists slapped over that but the damage is done. B) Joe six pack stopped caring about CPU performance a few years ago, hence the advent of netbooks and other "fast enough" platforms. I hear neophytes talking about computer specs and if anything they mention RAM and HDD size, not CPU speed or cores.
    Intel's and AMD's obscure model numbers didn't help matters either, but that's just a result of the MHz race being over. Besides, laptops outsell anything else these days and AMD is lagging even more there, outside of budget stuff (Llano does destroy Atom, and it's not much more expensive)... Consumes are increasingly more demanding about battery life, and this architecture looks ill suited for any kind of mobile use.
  25. Ozymandias
    Ozymandias [H]ard|Gawd
    1,610
    Jun 21, 2004
    This latest review features multiple GPUs. The review you linked was done with a single 6970. Reading comprehension is a wonderful thing.
  26. Impulse
    10,232
    Apr 5, 2001
    Don't feed the trolls... At least I truly hope he's not for real, maybe I'm just an optimist. :p
  27. unwittingnemesis
    unwittingnemesis n00b
    6
    Nov 3, 2011
    Finally..."hard" evidence that dispels the (baseless) myth that both chips have equal weight in gaming with "modern" games. Is there any chance of having usage (%) graphs added to this review, showing when and where GPU usage isn't locked at 100% (thus clearly revealing CPU limitations [for those who continue to doubt the obvious])? Might there be any chance of running these tests with one 560ti/6950 @ 1080p and lower @ lower settings, so that FX-8150 users can be assured (by an unbiased reviewer) that their chip will frequently limit slightly older (less GPU-intensive) games (e.g. Far Cry 2, which is extremely CPU-intensive) running at lower settings, as well (please pardon me if this was already done...) (they deserve to know the truth)? In my opinion, minimum framerates are the figures that we need to focus on the most...and the difference, as outlined here, is quite startlingly clear.
  28. Blacklash
    Blacklash [H]ard|Gawd
    1,893
    Jun 16, 2004
    Looks like now FX = Flatulence Xtreme.
  29. cold&damp
    cold&damp Limp Gawd
    159
    Aug 13, 2011
    BUT GAIZ, IN DRAGON AGE 2, BETWEEN 156 AND 161 SECONDS, BULLDOZER IS CLEARLY FASTER!!!!ONE!!
    On topic though, All these people who said that a magical software fix is in the works which will increase BD performance by 40%?? I just did a quick tally of the first 2 or 3 pages of tests, and BD is 72% Slower than the 2500K On average. SEVENTY TWO PERCENT.
    So with a software fix, if this improved bulldozers performance by 40%, it would still be a huge amount behind Intel Medium Level Enthusiast chip, cost $100 more, (The same amount as a processor which can REALLY run 8 threads) and use probably 200w more of power.(Numbers taken from [H] Desktop performance review) Which means for every 5 or so hours of gaming, where the CPU is fully loaded, and it doesn't seem to hard to load it up, you will be paying an extra 1KWh of power.
    My Country's average rate for power is about $0.30c per unit. So its going to cost me probably $1.50 a week more to run this thing, were I to get one. $75 a year. Plus the initial cost of ownership, which is around $150 more. I really don't even see how this stacks up to a $600 CPU. let alone a $190 one.
    And I have ignored the additional cooling that would be required (no 212+ here) and the New PSU I would have to buy.
    AMD, if you are listening, and I know you are not, this is how you fail as a company. Anyone Heard from John Fruehe Recently?
    Is AMD Still going to answer those questions we were asked to put forward?
  30. teletran8
    teletran8 2[H]4U
    2,220
    Jan 12, 2011
    Why not do BF3 like this picture. Just show us some comparisons of the built in CPU,GPU renders they have their own chart graphs. Did I ask for MP? Oh you did lol!
    We could easily tell which one spikes higher the Intel or the BD. Fyrthermore that game is the most futuristic, as far as how the game is rendered. That's all I care about seeing right now, well that and the Metro 2033 (1 Chart) was the only graph I looked at in that entire review.
    [​IMG]
  31. AntiSocialMunky
    AntiSocialMunky Gawd
    589
    Nov 4, 2006
    Are you sure you quotes the right thing?
  32. Impulse
    10,232
    Apr 5, 2001
    Fixed, thanks... ;) That's what I get for browsing the boards so much from may phone. Post was meant as rebuttal for:
  33. cageymaru
    cageymaru [H]ard as it Gets
    19,810
    Apr 10, 2003
  34. Cobalt35
    Cobalt35 [H]ard|Gawd
    1,158
    May 15, 2008
    So why would anyone buy Bulldozer? Anyone?
  35. mzs_biteme
    1,595
    Nov 7, 2001
    For an awesome BOX!!!!! :D
  36. Brackle
    Brackle Old Timer
    7,224
    Jun 19, 2003
    They own AMD stock!
  37. sirmonkey1985
    21,450
    Sep 13, 2008
    because i don't use multi-gpu and i never will so this has little effect on my gaming.
  38. billcat479
    billcat479 n00b
    1
    Nov 4, 2011
    Is the cpu's role more int. or FPU related?
    Which games use mult threads..... or ???
    It's not too good but using older games for this cpu is not going to work well. It's been pretty much established that this is a pretty much multi tasking or multithreading cpu design with a so so FPU so how did you really think the cpu would work on older games.
    Not very well, no supprises here, The cpu's should also have been run at their native speeds.
    With a supposed longer pipeline the BZ is clocked higher to make up for part of this right? Clocking them the same really isn't fair in this case. Test them as they come out of the box for real world data results if you want people to see what they can expect of it.
    And even then the design is future minded for better optimized software that can make use of it's new (not old) design. You might as well have used a 6 core AMD cpu as well as this is more represented to current and older programs. This is been pretty much the accepted status of the BZ cpu. It's way to new of a design to be compared this way. This is how AMD thought out it's future, they sure didn't design this for past software even though it would be nice for it to run older single threaded software better it is what it is.
    I really think the benchmarks should wait a few months for either new software including either patch's for win7 or for win8 to come out and newer software that can make better use of the design of the new cpu. It's so different that there has to be programs that have this design in mind for them to give a more realistic view of it's true performance levels if they are there to be coaxed out of this cpu. It's too soon to be running benchmarks on it I think.
    It may be bad timing by AMD putting it out before windows 8, or they want it out so software designers have more of a chance to work with it so when win8 or a patched win7 and better software will really start to show up for it.
    This is my view on this cpu anyway. AMD must have known how it would perform and has better info. on what direction future software is going to ask of it's hardware and designed it to take this into account. I doubt they would be that dumb not to know these things or it's design would be much different.
    Also with their plans to go with APU's they may have designed it for this future to use the video part to offset the FPU workloads so they knew they didn't have to design a better one that it has on it but that is just guessing. Makes a little sense but only time will tell with this cpu. It's too early to know.
    From programs that have been optimized for this cpu it can perform very well. I will not write this cpu off on current software.
  39. Brackle
    Brackle Old Timer
    7,224
    Jun 19, 2003
    So....with a processor thats about $60 (2500K) cheaper, and is faster then bulldozer, you would still pick up bulldozer?
  40. sirmonkey1985
    21,450
    Sep 13, 2008
    i agree on all parts. until theres an apples to apples between the AMD cfx and SLI its kind of hard to say if the problem really is the processor its self. for all we know the SLI drivers are broken as hell for the 990 chipset(and honestly i wouldn't doubt that from Nvidia). all we got was half the cookie, now we need the rest of it, without it the review doesn't really tell us as customers/readers anything.
    sure the processor may be cheaper but the entire platform sure as hell isn't. yet people seem to love ignoring that fact.
