AMD Delays 3950X Launch, says TR3 is coming...
nEo717
AMD previously told us that it's long-awaited Ryzen 9 3950X, a 16-core 32-thread behemoth destined for the mainstream desktop, would arrive in September 2019, but today the company announced it is delaying the release for unspecified reasons until November.
The company did throw us a bone, though, and also announced for the first time that the third-generation Threadripper processors would also release next month, though the graphic clearly states that it will debut with 24 cores instead of the expected 32, or even 64 cores.
https://www.tomshardware.com/news/amd-ryzen-9-3950x-delay-launch-third-gen-threadripper,40442.html
Brian_B
Probably has to do with the lack of capacity. Still supply issues with the 3900X
Reactions: sethk
gigaxtreme1
I doubt it is Fab capacity as it is high demand and spinning out lower binned dies to increase yields as the up binned dies are cherrypicked for the higher margin parts.
nEo717
Do you guys think its AMD holding back to see what Intel launches... perhaps sets the ground work for pricing of next Threadrippers along with gives AMD a bit longer to firm things up to get the max performance out of 3950X?
Lisa Su in my opinion plays a better game than all past AMD leaders - I'm sure yields/binning plays a role for the best parts too in order to meet demand (which makes me wonder if their server parts aren't selling better than they thought too).
Snowdog
No, I think Dan nailed it. Getting enough high end binned parts, either from accumulating a stockpile over time, or waiting for the process to a mature a bit more to produce a higher proportion of top parts (or some combo of both).
gigaxtreme1
This is most likely a problem getting enough quality binned chiplets to meet the demands of the 3900X and 3950X parts.
Shouldn't have a problem getting six out of 8 cores for the 3900x models. Epic is on a tear too. I think it's demand.
NKD
I think it has to do with EPYC. Those orders are likely going to be filled first before consumers. I am sure they are going to save some for consumers and release them in chunks as time goes on. The reason they are starting with threadripper with 24 core model.
Organik
Wait a month no biggie. or month and half and shit.
Dan_D
Extremely [H]
Given that many of these Ryzen 3000 cores can't do 4.2GHz, I'd say getting these things binned is a bit of a problem. Even if it really isn't, the issue comes down to demand for Epyc and Ryzen CPU's.
Algrim
I was hoping they'd have a 12c/24t Threadripper but starting at 24c/48t? Now I'm intrigued. (y)
NKD
That won't make much sense when zen 2 consumer series already tops out at 16 threads.
Rvenger
Yes, exactly. Customers moving data centers over to a faster, cheaper more secure platform is really taking a toll on ZEN 2 chips. Hence the low core TR chip being announced. They are saving all the good dies for Epyc. At the same time, the yields are probably not great.
Algrim
I'm looking at TR not for the cores (I already have 2 12c/24t and one 16c/32t workstations) but for the I/O bandwidth.
Jandor
That is already common knowledge leak.
24c/48t and 32c/64t on TRX40 chipset with 4 channel RAM, and 48c/96t and 64c/128t on TRX 80 and WRX 80 chipset with 8 channel RAM (like Epyc Line).
What is weird is that the 3950X is using 8c/16t chiplets just as 3700X and 3800X do.
Maybe the problem is actually that the 3950X cannot hold the announced performance and keep the 105W TDP.
NKD
I get it but amd is not going to make it because it won't sell much because of other processors being available up to 16 cores. I mean x570 is already damn good with bandwidth and IO. There is not much value proposition there. They wont price a new thread ripper below ryzen with a 12 core.
NKD
No that is not the problem. Keeping a processor under TDP is not rocket science. Look at the base clock, its already lower than 3900x. all they have to do is manage the thing.
That is the least of issues. The real issue is demand and EPYC being priority.
LurkerLito
Wait so the TR3 chips need a new MB? I thought they'd still use the same socket and I could just drop in the new TR3 chip into my rig.
NKD
I think they will unless you want better memory support where most people will go for new board.
KATEKATEKATE
sounds like a double whammy of big Epyc demand and binning issues. Judging by how many folks have Zen 2 chips that can barely hit 4500 or even 4300, I'm not surprised to hear the 4700Mhz part has been delayed. I agree it's nothing to do with TDP- from my testing and what I've seen around, Zen 2 doesn't seem like Zen 1 (or Bulldozer, or most CPUs) where one had the option of pushing the power way way way up to reach for that last 5-10% clock. Zen 2 simply hits a wall before that point on the curve. No amount of power will push clocks higher- its just up to how well TMSC's fabs do with AMDs design and so far they haven't been doing stellar and AMD may have been overly-ambitious with their advertised clocks and now they have to live with it.
NKD
not sure what the issue is with clock speeds once again. I am hitting 4625 with my 3900x after latest bios update under light loads and sustained 4500+ average on cinebench single core. Atleast one core is 4500+ at any given time during the test. It boosts 4250-4475 and even spikes to 4500 under games after ABBA update. before it was locked to 4200. How is that bad though that is well 400+ above base clock in games. Cinebench all core is 4100+ mostly between 4150-4200.
So 3950x is obviously going to be higher binned chip and I don't know how many they expect to sell. But I think they will probably be just fine. The issue probably is epyc demand and more then expected demand AMD is seeing for zen 2 chips. We all know they are binning this so its obvious 3950x are going to be top binned and will likely have lower supply. But AMD probably expects more so they are likely building inventory at this point.
Reactions: N4CR
clockdogg
Epyc is taking priority, for sure according to our internal communications.
You've been having 'internal communications' with AMD? Is this some sort of kinky nerd thing...or can I talk to you about 3900X-whispering for me? ;-)
TheRookie
I am surprised AMD hasn't launched Ryzen 9 3900 and Ryzen 3950 in the meanwhile.
These could use lower binned chipets used in the Ryzen 5 3600 and Ryzen 7 3700X, respectively.
They could be discontinued later when Ryzen 9 3900X and Ryzen 9 3950X are available in ample quantity.
tangoseal
My guess is the thermals of the 3900x are already so prohibitive that packing 4 more cores into the same die space and CPU space is just going to be asking too much.
So maybe AMD decided to just keep 16 within HEDT space for obvious reasons. The power of the 3900x is such that it is much faster task to task than my old 2950x. I could only imagine that I am skipping this TR generation to wait for 4th.
mnewxcv
Title made me think a new socket was coming out. Glad that's not the case.
Mav451
+7% perf or 10% reduction in power sounds good to me. How long would it take for that to reach the end-user? 6-9 months? 1 to 2 years?
NKD
from what I read it was 15% reduction in power or +10% performance at same power for 7nm+. It’s supposed to be next year for zen 3 and Navi 2
NKD
you think they are delaying it because of thermals when they are making 64 core chips? It’s just 2 chiplets. At stock you are not going to see any thermal problems out of the box. Overclocking might be different story. What happened is EPYC! Plain and simple, that’s why you are seeing threadripper starting with one 24 core chip and rest later.
gigaxtreme1
Since the process improvement was already available at the end of July, time for the decision to be made, employing the EOL enhancements and 2 months for production, November sounds about right.
ManofGod
It has already been announced that TSMC are having turn around times increase on their 7nm process parts, primarily because of demand. This is not new news, although I appreciate the OP letting us know about the 3950x delays.
RamonGTP
Looks like AMD is trying to figure out how to get that split second boost of 4.7GHz since they can't seem to even get 4.6GHz on the 3900x in most cases. This news makes me glad I didn't wait around for the 3950x
NKD
I am hitting 4600+ after latest bios update and 4500-4600 on cinebench single thread. All core boost during games is also improved.
NKD
I am pretty sure he was referring to 7nm+. Which is next year.
gigaxtreme1
Mav451 was referring to the content of the article posted involving process improvement. While NKD was talking about next year's 7nm+ improvement. The subject is on the current node and I believe 3950x and Threadripper.
Edit. And I believe TSMC talked about lead times being extended, not turn around times.
In other words, new customers have to wait. TSMC is booked out for months on 7nm.
Edit 2. My thesis is that the delay is a transition to a new stepping.
tangoseal
Thermals on tiny amr package. Not huge TR socket.
