Sadly, this is why I'm happy staying 1-3 generations behind in upgrades. Rapid progress to beat out competitors leading to issues like this. Of course this is not unique to the computer industry, a failing in all new release products.
The sad thing is that this has been known about on the 400 series chipset in 2019. This isn't a new thing, they just don't seem to care.
People have been gimping their system by reverting to PCIe 3.0 in the bios, which seems to be legit workaround. A couple of people said that: "AGESA 1.2.0.0 fixes the problem" ( ie. they can go back to using PCIe 4.0 ).
What's really sad is reading about: people selling their AMD systems and "going back to Intel", or spending 30 hours to figure out that the solution was to revert to PCIe 3.0, or RMAing all kinds of things that didn't need RMAing.
I have to pick up a 5900x in 8 hours from Canada Computers because they last time I built an AMD was the Athlon 64 x2 4400... 15 years ago and the heat generation was so nuts that I decided that would be the first and last AMD build ( ie. never again ).
And here we are... 15 years later and people are still talking about AMD shitbox graphics drivers.
I dunno how people can be OK with running companies where the public reputation and legacy is for making shitbox drivers? One would have thought that this kind of thing would have been hammered out over the span of 15 years but I guess not... add some fucking QA QC already?
I "upgraded" from an entry-level x370 to an entry-level 570x last week. In addition to this potential USB issue, I've found nothing but detractions from the 4 year-old x370 I was using previously. Slightly lower overclocking headroom (on my 3600), slightly less stable memory timings, and worse, multiple cost-cut features. All for 30% more in price.Good thing I have a B350 motherboard. Hurr Hurr Hurr!
Noticed that my X470 / 3700X system recently has very bad USB write speeds -- down to 4-5MB/s on what should be a fast drive. No such problems on my other rigs. Could be one of the later BIOS changes. This is too bad, since this may have coincided with the faster POST times I've been getting with the latest AGESA.
+1No issues so far with my MSI X570 unify or my Gigabyte X570 Ultra elite.
I used a riser cable for awhile and still had no issues til I upgraded to a 3080 and those were gpu related issues when running at 4.0. everything worked fine when I switched it too 3.0. I have since removed the riser cable tho.Outside of some usb 2.0 issues in uefi first few month of initial 300/570x release, I've had no problems. Using 3900x, x570 aorus master and rx 6800 on pcie 4.0. Still not convinced this isn't pebkac or something stupid like pcie risee cables.
I've had my fair share of issues with the B350 but those issues were solved. ASRock AB350 Pro was a total pain in the ass since I had no way to alter the voltage on the NB to fix memory issues. ASRock did release a bios update 2 years later that allowed me to do this. My MSI B350 Tomahawk is kinda amazing since I've owned this. This PC is probably my most stable PC I've ever owned. Rock solid for over a year and I've not restarted it for months.I "upgraded" from an entry-level x370 to an entry-level 570x last week. In addition to this potential USB issue, I've found nothing but detractions from the 4 year-old x370 I was using previously. Slightly lower overclocking headroom (on my 3600), slightly less stable memory timings, and worse, multiple cost-cut features. All for 30% more in price.
I won't likely until I do my next set of upgrades see any of the PCI-E bandwidth improvements, at which point, I'll probably upgrade my mobo again. The only thing the 500-series gets me is a path to Zen 3 (although I'm hearing x370s may support Zen 3 shortly). Largely, moving to 500-series was a waste for me.
You managed to score a 5000 series and one of the new GPU’s you lucky bastard!I havent had a single usb issue on my x370 or x570...
Some of the topics I've read about this have been fairly sensational, giving you the impression that this affects every user. I've been using X570 + 3900X for a year and a half or so now and I have not had any USB issues.
Not not a 500 series, not running PCIE4, not using USB 2.0. So none of the issues applies to you.Asus B450-F has gone from a Ryzen 2600 --> 3600X --> 5800X over the past, what? 3 years now? I run KB/Mouse thru the monitor, there's a webcam, printer/scanner, headset dongle, headset charge cable, half dozen USB sticks in and out of it...
I've literally traded out almost every single piece of hardware that surrounds this mainboard since I bought it. Case, power supply, ram, video cards, monitors, CPU cooling, the cpu's of course, etc.
Never ever noticed an issue USB wise.
Now you know how Intel users feel every time a minor issue gets sensationalized by the internet.Some of the topics I've read about this have been fairly sensational, giving you the impression that this affects every user. I've been using X570 + 3900X for a year and a half or so now and I have not had any USB issues.
Everyone reporting no issues: great, but it is already known it affects a small percentage of users. Just because only 1/10 people have an issue doesn't mean there isn't an issue and that it's no big deal just because you don't have the problem others do
X570 also has bugged sata ports on a hardware level, you can look it up. It makes for slower performance when using ssd's intermittently over sata, the problem was never fixed and has been brought up many times.I "upgraded" from an entry-level x370 to an entry-level 570x last week. In addition to this potential USB issue, I've found nothing but detractions from the 4 year-old x370 I was using previously. Slightly lower overclocking headroom (on my 3600), slightly less stable memory timings, and worse, multiple cost-cut features. All for 30% more in price.
I read the entire Reddit thread. Summary:
It's a lot of users, the X570 only does 4 SATA ports, any ports beyond that are handled by additional chips usually an ASM1061, and the performance off that is garbage, especially random read/writes. There is almost no documentation on which boards are using what chips nor which ports are controlled by the X570 or the add-ons. And it certainly isn't just limited to the budget boards the most expensive board that I know of using the ASM1061's is the MSI Godlike and I know at least one person who was pretty choked to find that out the hard way.Eh? Hadn't heard that one. Does that affect only a subset of users or "everyone"?
..... Well I am not reading through that whole thing but AMD is specifically looking into the interaction between USB 2.0 when operating the PCIE at 4.0 speeds, dropping it back down to 3.0 manually in the BIOS is a confirmed workaround. I do recall instability being one of the LONG list of reasons that AMD was not enabling PCIE4 on the 400 series, but I didn't pay too much attention to that. AMD has a pretty good list of issues with the 400 series but none as outright annoying as the USB issue on the X570's that I know of.According to Mr Read the entire reddit thread it does?
But we're not talking about a few variable components: it's many of them, as well as removed or downgraded features, across brands on the same entry-level board lines. An Asus x570 pro, Giga Gaming X, MSI Gaming has less quality components, and missing features compared what its 3 year-old (and 4 year-old) direct predecessors had. Downgrading VRMs and audio hardware so I can have PCI-E 4.0 is stealing from Peter so I can pay Paul -- and still charging more for it to boot.You bought a budget motherboard that performs like a budget motherboard and decided to blame the chipset. The chipset doesn't determine what VRMs your motherboard uses, or the quality of the DIMM sockets, or the traces on the motherboard connecting the DIMM sockets to the memory controller. The fact that you had decent results with a budget motherboard in the past is certainly no guarantee that you will have good results with budget motherboards in the future, regardless of the chipset used.
So then why did you buy it if it had inferior components? I don't buy a new mobo just because it has a newer chipset if my cpu will still work fine on my current board. Why downgrade on VRMs, then complain that it doesn't OC as well?But we're not talking about a few variable components: it's many of them, as well as removed or downgraded features, across brands on the same entry-level board lines. An Asus x570 pro, Giga Gaming X, MSI Gaming has less quality components, and missing features compared what its 3 year-old (and 4 year-old) direct predecessors had. Downgrading VRMs and audio hardware so I can have PCI-E 4.0 is stealing from Peter so I can pay Paul -- and still charging more for it to boot.
