fightingfi
- Oct 9, 2008
AMD chipset driver revision 1.9.27.1033 is now ava.
Anyone's idle clocks change? Mine appear to be much higher now.
i seem to be running at 3.7-ish idle on my 3700x stock speeds now it runs up to 4.22 at times......i guess thats good. Enermax AIO 120 mm push pull config
A friendly reminder that if you are not using project mercury on your ryzen cpu you might lose up to 20% of your FPS in games
You need to give that project mercury to someone to do a review if it actually works that well. It needs more exposure.
Sven, nobody replied to your post. It was an excellent improvement. Have you shared this with AMD?
Snappier? That's the word all Intel users use when they describe how their CPU is better than AMD. Intel is just snappier. Does this software help make AMD snappier than it was before?Giving it a shot on my 1700 @ 3.8.
Seems to have speed up reaction times? I think is the best way to explain it. Nothing computationally seems to be faster according to benchmarks, but there's a little less lag when doing basic stuff like throwing windows across my multiple screens and such. Hard to quantify.
A quick note that idle clock speed doesn't seem to affect power draw with these CPU's being able to enter sleep states quickly.
Using a watt meter I saw no higher idle power draw using the Ryzen power plan (higher idle clocks, 95% power at idle in power plan) vs the windows power plan (lower idle clocks, 5% power at idle in power plan).
However, the Ryzen plan had higher benchmarks in things like Kraken web benchmark.
with project mercury enable things do feel more responsive. If i turn settings down to 720 there is a noticable increase in frame rates.Running a RX580 at 1080 or 1440 can't tell the differnce card is probably the limiting factor.
I thought that the scheduling problem had been taken care of and the new updates were aimed at intel processor's.
btw if you have nothing better to do you can head over to tom's hardware and read their cooking review.It's amd vs intel. These pepole really need to get a life.
