Well I blame the AGESA 1006 change log for saying "including support for 4000MHz RAM", now people are treating it as gospel whether its AMD TR certified or not.
The one thing I really need is a few more PCI-E lanes... Not sure the higher cost/power consumption is worth it for these chips though.
It's not behaving that well with 4 either from what I've seen, if you want fast RAM, you need to run 2 sticks, just like Ryzen it seems...but you lose out on QC smh.
Power draw really?I'm interested in the 1900x because I want an ECC based system and the 1950X is too rich for me, price and power draw.
Power draw really?
For someone that wants a system that is on 24/7 am concerned that the idle power draw of TR is too much. This is the main reason why I want the to use a 1700 for my linux based pvr / file server (that never powers down).
More rumor mongering, do you own a threadripper?
I have ZERO problems running at full xmp profile speed using quad channel.
As far as thermals... I am using an EK block and I'll try an Xspc once I can get one. With proper radiator setup and a good pump and good fans and good TIM application you can see temps in the 50s max with all cores running. I get hotter temps if I isolate to just 8 cores using thread management software. But if I load shed between all 16 cores my temps drop more because the heat is more uniformly dispersed.
Anyways I'm loving all the negative feedback and reviews we get on these forums from people that do not even own the setups.
No I do not own TR but I have helped to set up a few builds for clients, if you had bothered to read all my post in this thread, you would see I was meaning RAM speeds ABOVE 3600MHz with 4 DIMM's that people are having trouble with.
Meanwhile, your paltry 3000MHz is nothing to write home about. I love how people automatically assume that a person who doesn't own a particular piece of hardware, happen to absolutely know nothing about it. Adding to the fact that people who do own a certain piece of hardware proclaim themselves as experts in that area and refuse to hear any input on it from non-owners of said hardware.
Excuse me for relaying my hands on experience with hardware I do not own on a public hardware forum.
ok maybe I was little too quick to snap judgment but you are coming here in telling folks not to buy something simply because of a sky high expectation. There was NEVER any hope, except maybe misinformed false hope, that 128GB of 3600 would ever stick on any platform. There is just too many points of stability across the whole spectrum of RAM to IMC to power delivery to bit stability etc... when discussing that high of an overclock with that much ram density.
Most servers that are running LARGE volumes of ram run at JDEC speed ratings and nothing more which in most cases tops out at 2400 mhz in almost all large volume cases. Our technology system and market wide is not there yet to allow such high volume overclocking.
