Axman
VP of Extreme Liberty
- Jul 13, 2005
However organics is the future.
We run at 30Hz, dude.
Idk them nicer boards are getting pretty pricey nowadays.Yes even if many many many years ago, I have accidentally bent CPU pins (heatsink and CPU cemented together when removing lol) never MoBo pins.
I'd also rather replace a MoBo than CPU $ wise
We run at no hz.We run at 30Hz, dude.
Easier to RMA a MoBo than it is a CPU at the very least. Unless it's a Newegg purchase, then its a nightmare regardless of what you are trying to RMA.Idk them nicer boards are getting pretty pricey nowadays.
How recent was your last NewEgg Nightmare™?Unless it's a Newegg purchase, then its a nightmare regardless of what you are trying to RMA.
Pre covid but it was a doozie. The order was refunded after some back and forth with a legal team, they never paid the return shipping, so the 2 pallets after a year on our loading dock went to recycling.How recent was your last NewEgg Nightmare™?
5600x used less than 100w. So, presumably the 7600x will also be similarly lower power. I hope they make one with 3D V-Cache.will this come with low power desktop version? I dont care about those 100+W cpus
Most higher end AMD processors have had a low power "Eco-mode" toggle in the bios that puts them at 60 or 90 watts. I'm guessing it'll be similar for the 7000 series.will this come with low power desktop version? I dont care about those 100+W cpus
Did AMD fix the io die power consumption in the 5000 series? I know at idle it’s usually around 15 watts on my 3900xMost higher end AMD processors have had a low power "Eco-mode" toggle in the bios that puts them at 60 or 90 watts. I'm guessing it'll be similar for the 7000 series.
I hope so, otherwise they are going to have a hell of a time meeting the EU and California requirements for idle power consumption in OEM office equipment.Did AMD fix the io die power consumption in the 5000 series? I know at idle it’s usually around 15 watts on my 3900x
I would take it as a good sign. People are quicker to trash a retailer when they have a issue vs when they don't have one. The GM piece did a lot of damage to their rep and I am sure they are trying hard to rebuild it.Pallets! Dang.
I was just trying figure out if they'd improved their ways since Hardware Jesus visited with them. When I go look at Gamers Nexus channel, seems all the Newegg results are from 5 months ago, so I don't know if anything's changed.
