AMD 64-core EPYC clock speeds leaked - The power of ROME
Discussion in 'HardForum Tech News' started by juanrga, May 21, 2019.
  1. juanrga
    juanrga Pro-Intel / Anti-AMD Just FYI
    2,493
    Feb 22, 2017
    Red Falcon likes this.
  2. boushidosan
    boushidosan Gawd
    547
    Dec 19, 2010
  3. Rockenrooster
    Rockenrooster Limp Gawd
    217
    Apr 11, 2017
    Dat base clock...............
    Higher than previous 32 core flagship
    N4CR likes this.
  4. cdabc123
    cdabc123 2[H]4U
    2,215
    Jun 21, 2016
    very impressive my 72 core xeon phis only hit 1.7ghz on 245w
  5. Grimlaking
    Grimlaking 2[H]4U
    2,767
    May 9, 2006
    That is actually WAY better than I expected. I was expecting 2ghz maybe 2.5. with boost. Color me impressed.
    NovaCloud likes this.
  6. Rockenrooster
    217
    Apr 11, 2017
    How does your Xeon phi compare to a epyc 7601 in like cinebench or some other widely used software? encoding, etc...
  7. defaultluser
    defaultluser [H]ardForum Junkie
    12,256
    Jan 14, 2006
    But the TDP jumped from 180w to 240w. So not as big an efficiency gain as you're implying.
    If you take into account TDP vs core count, the efficiency gains are only 30%.
  8. Teenk9
    Teenk9 Gawd
    973
    Jul 22, 2011
    What?! With double the cores?!
  9. defaultluser
    12,256
    Jan 14, 2006
    Yes, there is an efficiency improvement, but it's not DOUBLE.
    You have double the cores for 3/4 the TDP of the old architecture. It's 1/3 lower power consumption, not 1/2 the power consumption. This was expected, given the process node.
    This is the reason I wasn't expecting AMD to launch Zen 2 mainstream with more than 12 cores - it would mean a totally new class of TDP above 105w. But with the 7nm refresh next year, they could find the extra efficiency in the tweaked process.
  10. Teenk9
    Teenk9 Gawd
    973
    Jul 22, 2011
    But the clocks also went up. Expecting same TDP while doubling core count and upping the base clocks is asking way too much. Off the top of your head, what's the last cpu that released like that?
  11. ryan_975
    ryan_975 [H]ardForum Junkie
    13,999
    Feb 6, 2006
    Depends on the clocks.
  12. defaultluser
    12,256
    Jan 14, 2006
    The boost clocks are identical, so base clocks is not as important as you might think, as long as the cooling is adequate, it will never run at base clocks (this is a server we're talking about, with oversized cooling and VRMs). The latest-generation boost system is a lot more aggressive than that.
    Also, we're talking 2.35 vs 2.2 base clocks, which is only 5% difference. It's lost in the noise.
    Stop making such a big deal out of tiny advancements of paper specs. They're really not that impressive.
  13. defaultluser
    12,256
    Jan 14, 2006
    Using the 30% reduction in TDP at the same clocks as Zen+ a a guide, that means 8 cores Zen 2 at the same clocks as 2700x is approximately 80w TDP.
    That's 120w for 12 cores at the same clocks speeds, or 160w for 16 cores.
    If you bump it the expected 10% faster clocks (small voltage bump required, so it's a 15% change), that jumps to 135w for 12 cores (acceptable) , and 185w for 16 cores. That's getting 16-cores dangerously close to FX 9000-series land.
    The power consumption of double the cores is only acceptable at lower clock speeds, and that would never sell for the mainstream platform. AMD is going to have to wait for a tweaked 7nm node next year, or take the 9900K power consumption hit, and have it today.
    But of note: the Zen 2 would deliver twice the number of cores at the same power consumption as the 9900k, with almost identical per-core performance. That's pretty embarrassing. Just saying, a whole new line of high power motherboards would be harder for fans to swallow.
    Legendary Gamer likes this.
  14. N4CR
    N4CR 2[H]4U
    3,623
    Oct 17, 2011
    You mean like the 9999°K? That thing don't give a fuck about the '125W' or whatever bullshit TDP rating it has when it doubles it routinely under its sanctioned turbo limits. I don't think any of the reviewers do either until AMD increases their TDP rating, then it's literally dead pandas and no icebergs because AMD sucks.
    I'd gladly take a 160W TDP for 16 fast cores though. Reckon they'll try keep the 12 core 'within existing realms' and the 16 core as a HEDT-lite/enthusiast part will push higher.
  15. juanrga
    2,493
    Feb 22, 2017
    2.35GHz Base and 3.2GHz Boost has been just confirmed by Demerjian
  16. NWRMidnight
    NWRMidnight Limp Gawd
    237
    Oct 23, 2010
    You are incorrect on all your points because electricity, heat, etc, which all falls under basic physics/ohms law etc. and does not work the way you are implying, as it IS NOT LINEAR. . The only way your argument(s) would be correct, is if you where comparing identical chips, identical core count, and identical technology other than node/die shrinkage. But we are not, we are talking about double the core count with with improved/different technology. That difference alone completely shatters your 1 to 1 LINEAR comparison because physics/electricity/ohms law, resistance, etc, does not work that way.
    If nothing changed, and AMD just doubled the core count (no die shrinkage, no technology improvements, nothing) all on the same chip, It would be IMPOSSIBLE to do with with even double the TDP (360w) and keep the same clock speeds as as it is not Linear. In fact, they would have a difficult time Achieving even 50% of the clock speeds (if even that) and keep it under 360w much less being able to keep the heat output under control and manageable because the IF they ran those 64 cores at the same speeds, the power draws, and heat output would multiply exponentially.. What this means is your .05% clock speed increase is exponentially much larger, and your 30% TWD decrease is also exponentially much larger when you realize that it is not a linear comparison.
  17. Teenk9
    Teenk9 Gawd
    973
    Jul 22, 2011
    So you can't give an example of what you're insisting AMD should do with Zen2. Got it.
    pendragon1 likes this.
  18. Lakados
    Lakados [H]ard|Gawd
    1,441
    Feb 3, 2014
    With the chips named Rome, I would expect a number of marketing campaigns about Legions of cores, if not it is a lost opportunity.
  19. Rockenrooster
    217
    Apr 11, 2017
    Lol defaultluser.....
    A more accurate comparason would be to measure the power diff between Epyc 7601 and Rome with the same 32 cores and clock config..... Then you have IPC to take into account, then doubled AVX..................
    I'll bet it's more than 33% more power efficient...............................................
    but then you already got owned by the people above me....
  20. rgMekanic
    rgMekanic [H]ard|News Staff Member
    3,749
    May 13, 2013
    WANT!
    Lisa Su... if you're reading this... hook me up.
    ssnyder28 likes this.
  21. cdabc123
    cdabc123 2[H]4U
    2,215
    Jun 21, 2016
    getting widely used software to work on the phis is pretty difficult by itself. they are also pretty much limited to linux as windows cant handle 272 threads effectively. The most direct comparison I can find is for mining monero where a EPYC 7601 gets ~ 1750h/s and a xeon phi 7250 gets ~2100h/s but this isnt that great of a comperison as monero benifits from a high memory bandwidth and the 16gb MCDRAM on the phis blows ddr4 out of the water.
    I did manage to get passmark to atleast run on one of them but it wasnt effectively utilizing the chip. Ill attach the screenshot for that below
Tags:
