TheRapture
- May 31, 2000
OK, I have been out of H2O cooling for a bit. I am fixing to order some parts to cool my Mobile chip, running at 2.4ghz currently on a Thermaltake Silent Boost.
The radiator I have already set, a custom copper unit I had made by a local shop. The only question is really about the pump, I was wanting the Hydor L25 (185gph) from Dangerden due to size... http://www.dangerden.com/mall/Pumps/Pump_hydor.asp
Will this be sufficient? This is going into a mid tower case so pumping distance is rather short and is only cooling the cpu.
