Great news guy! If you offset the AM3 Bracket with you AIO cooler you might be able to mount you new cooler.
I have an Artic 240 AIO that I was desperate to mount on my new AM4 board. I figured out you can just use 2 post and cant it 15 degrees or so and you can tighten 2 nuts. I add the other two to be sure it is stable. I does require you to move 1 post in at the top a very small amount less than 1/8 inch.
This works on the x370 prime and the Biostar x370 GT7.
The TIM spread is really good.
