cageymaru
- Apr 10, 2003
Alphacool has announced the release of its Eisblock GPX Plexi Light cooler for the AMD Radeon VII. The cooling block is made of solid copper and is completely nickel-plated. The clear Plexiglas allows owners to view the mesmerizing water flow. The water flow actively cools not only the GPU, but all the important components of the graphics card including the voltage converters, the V-Ram and other components that generate heat. A backplate is included with the cooler that protects the back of the card and contributes to the cooling performance. Strategically positioned heat conducting pads dissipate heat via the backplate.
The connection terminal is unique within the industry as Alphacool doesn't rely on using Plexiglas. Instead, Alphacool uses a much harder, more resistant, transparent nylon to protect against stress cracks caused by over-tightened connections. An alternative terminal that allows for vertical mounting is included for free within the box. Alphacool is particularly proud of its patented locking screws that do not protrude and are flush with the terminal. An addressable digital RGB LED strip spans the entire width of the cooler. Each LED be controlled individually to create beautiful and unique effects and is compatible with various motherboard headers. The manual shows the installation process. Thanks jhatfie !
The Eisblock GPX Plexi Light cooler is a beautiful and an outstanding performing waterblock which will certainly give you a lot of pleasure. Since Alphacool also offers various custom designs, please check the following link to find the right one for your graphics card: http://www.hwconfig.com/waterblock-finder
