Alldocube X Neo
emrah_tr
No, I haven't, I use the tablet most of the time with headphones and I'm getting great audio quality with them, specially now that I'm using a usb-c adapter. Magisk is working on crDRom so I suppose that ViperFX should work.
I tried Titanium Backup with crDRom beta2, it did not recognize my sdcard and was not able to restore the most of my apps. You can find similar experiences in TB ratings in the play store.
I have also APTX bluetooth headphones but as i found out, the stock international rom has not support for APTX driver official and need some settings to be modded. This is one of the reasons why i want to have a root and magisk so i can install aptx mods available.
Regarding the speakers, they lack really quality and a bit shame alldocube has put such low quality speaker units in such amazing piece of tablet. I sometimes dont reach my headphones or cant find them and when i put a film or a music on(youtube, vimeo etc), the speakers irritate me straight away. Thanks for the quick responses.
I think that to be able to handle external cards Titanium Backup has to use the document provider storage. And it's recommended to disable Play Protect and "Verify apps over USB" .
taro4
No way, even with document provider storage (which is also my regular setting with Android 10) it did not accept my sdcard. "Verify apps over USB" was disabled, but not Play Protect, thank you, I will try it again on next flash. I use Titianium Backup for more than 10 years if I remember right, great software, but a bit outdated.
emrah_tr
I have finally flashed crdrom (android 11) to my tablet but took my all day to able do this. I will explain "" why "" in my next reply.
DWolvin
Silly question, but after flashing this tablet ends up just being straight Android, correct?
emrah_tr
CrimsonKnight13 taro4 pjrodriguez
Is there a way to pass safety net in magisk? I am on latest crdrom (android 11)
Without it, the device shows uncertified device in google play and some apps cannot be installed.
Another bug, 3.5 mm headphone jack doesn't work on crDRom11 / 2021.04.28, I think i am going back to Android 10/another custom rom.
''setprop persist.sys.overlay.devinputjack true'' didnt work for me. shame, i actually like this rom very much but without wired headphone, i cannot do it
emrah_tr
I flashed crdrom-v306-210428-arm64-bgZ.img.xz (it has the gapps included). By the way I don't flash from TWRP but from a PC using fastboot commands.
Is it possible to try headphones with 3.5 mm jack and check if the 3.5 mm slot is definitely work? Is there any way to fix this issue? Unfortunately i couldn't fix it by setprop command :(
The setprop command has to be run as root in a terminal. It worked for me.
Don't go back to Android 10, if your headphones don't work using the 3,5 slot buy a usb-c adapter.
taro4
Same here, even if this command was executed as root. I am back to QiDroid (with dark mode :)) for the second time.
emrah_tr
I have mix feelings, the experience in crdrom(a11) is really nice, fast and smooth. Much newer platform too of course. Also the dark mode is far better done and built in the rom (better deep blacks)
Maybe i will think about getting usb-c adapter and see the quality and really worth going back to Android 10
emrah_tr
Did you also feel the same, in crdrom , dark mode is much better and has deeper black/ better for oled screens than qidroid?
Have you set any command for 3.5 mm headphones and jack to work in qidroid? Or it worked straight away after flashing the rom?
Thank you
taro4
Did you try the recommendations from the crdRom-thread?
"Also has dynamic SafetyNet helper (but it compatible not with all devices), users have four ways to pass SafetyNet: a. just enable SafetyNet option (recommended) b. disable SafetyNet and enable "Spoof Pixel 5" then reboot c. enable both options and reboot d. mount system as RW and create empty file /system/phh/secure (legacy method) and in the Recovery do Wipe Data."
taro4
Thank you
I don't see a difference. In the design-settings you can choose "darker" dark modes. Headphone works out of the box. Btw., I also see no advantage in smoothness etc. in crDRom compared to qiDroid (used the beta2 of crDRom for a week). No difference in battery drain too.
taro4
emrah_tr Eremitein wrote in the crDRom XDA-thread "Phh settings > Misc > Disable audio effects or Force enable headphone jack". As I'm back on qiDroid, I can't test this, but maybe you can. (Both options are unchecked in qiDroid)
emrah_tr
Unfortunately this morning flashed to qidroid android 10. So far so good, 3.5 mm headphones jack worked straight away
taro4
Once you have flashed a working TWRP, you can make the rest there, no need to flash something with fastboot. Format data is imho only necessary if you want to change encryption on/off. For a clean flash I normally make the standard wipe, flash rom-image, resize file system of system partition (if needed), flash gapps, flash Magisk. Change slot, reboot TWRP and like before for the other slot.
emrah_tr
Interesting fact, between crdrom (A11) and qidroid (A10) there is quite big difference as image size. Wonder what things included do such big difference. Anyone knows? May be only gapps included in different ways?
taro4 pjrodriguez CrimsonKnight13
emrah_tr
I wanted to go back to crdrom (android 11) by fastboot commands but unfortunately the tablet doesnt boot. The alldocube logo appears and about 10-15 seconds later screen goes black and turn itself off.
Any advise? Should I once more try via TWRP by flashing ''crdrom.img'' to both system_a and system_b slots? I didnt try TWRP before because i saw comments that it soft bricked some devices.
