Yeah... everything is gone before I actually had time to get around to testing it (holidays plus planning on a big move). If anyone has them, please provide a cloud link!Is there a glitch in the matrix or why have all posts from Allexbast disappeared? Same at 4pda forum thread. I hope you saved the files.![]()
More advanced users definitely want GSI. You've reacted to those that don't fully understand it all. Totally nuking your accounts & posts seems quite a knee jerk reaction. I would like the files in order to test & update the guide with acknowledgement of your hard work.Guys, why do you need these files. You end up returning to stock firmware anyway. The same is on 4PDA. It is better not to flash the tablet with gsi firmware at all, in order to avoid problems. I can say that even the stock is not optimized, but the developer has long abandoned updating the firmware
Flash the stock chinese firmware via qfilI think I bricked the tablet after the 6GB expansion...
If anyone can make a backup/restore QCN file from a stock firmware & share it, I'd greatly appreciate it. Partition restoration is the only way to go from that type failure...
Everything flashes fine but remains in 9008 mode.Flash the stock chinese firmware via qfil
Try to flash the stock European firmware first and start the tablet, and then flash the Chinese firmware via qfil. Perhaps this is due to revisions, the tablet behaves differently.Everything flashes fine but remains in 9008 mode.
I'll give that a try later. Thanks.Perhaps something from this will help
https://forum.xda-developers.com/t/guide-qdloader-9008-fix-edl-mode-fix.3980165/
Is your tablet charging in this state?I'll give that a try later. Thanks.
I haven't explored it in-depth this week. I'll look into it by the weekend since there's no rush for me.Is your tablet charging in this state?
Check how the tablet reacts to a combination of buttons. To bootloader and recovery.
I'll give you a qsn backup, only later
Good luck recovering your tablet.I haven't explored it in-depth this week. I'll look into it by the weekend since there's no rush for me.
Also... I do know how to work my way around Android devices.![]()
Thanks. I'll try but it seems ALLDOCUBE & many other Chinese tablet manufacturers cut way too many corners. Usually hit walls when tinkering with them. I think I'm done buying the cheap "premium" tablets that wind up burning my money & giving me headaches.Good luck recovering your tablet.
While digging around in the batch files provided by that firmware package, using rawprogram0.xml fixes the EDL bootloop. I should have it back up & running to test out your wonderful 6GB fix soon enough.Perhaps something from this will help
Yeah...Great! Just to avoid similar bootloops at my device in the future, don't you mean rawprogram0.xml?
You managed to recover your tablet?Yeah...fixed now
Yep & restored it to the modified global image without the 6GB fix. I'll do more testing soon.You managed to recover your tablet?
mount -o remount,rw /
mv /bin/resetprop /bin/phh-resetprop
phh-securize.sh
First install magisk 23 via twrp, then go to aosp12 settings phh -misc - securize and remove phh rootNewest phh AOSP 12 build plus Magisk don't seem to boot. I wonder if its a conflict with the built-in superuser binaries. I'll have to hunt for a fix or a different ROM.
Edit: I forgot about this method
Bash:mount -o remount,rw / mv /bin/resetprop /bin/phh-resetprop phh-securize.sh
Won't boot for me at all with the newest Magisk. I'll have to securize it through adb shell via TWRP first.First install magisk 23 via twrp, then go to aosp12 settings phh -misc - securize and remove phh root
You could try running the normal Treble config with a smaller GSI img w/o the 6GB mod (using the original xml file from the global ROM) & see how it goes. There's a possibility that the kernel is having issues with the larger space & altered partition table.I had to reinstall the stock firmware mod 6gb due to the hang of any gsi build, it freezes several times a day. The reason is not clear. Apparently for this reason, everyone is switching back to stock.
Stock mod 6gb works stablyYou could try running the normal Treble config with a smaller GSI img w/o the 6GB mod (using the original xml file from the global ROM) & see how it goes. There's a possibility that the kernel is having issues with the larger space & altered partition table.
Maybe a possible vendor image mismatch with the kernel since your mod uses the global vendor image & Chinese kernel (correct?).Stock mod 6gb works stably
No. In TWRP which I ported the kernel from the global firmwareMaybe a possible vendor image mismatch with the kernel since your mod uses the global vendor image & Chinese kernel (correct?).
Not really. I'm familiar with compiling kernels but never really dug into Android kernel & vendor images much.In windows, you can unpack vmlinux with the 7z archiver. You did not look at the difference between Chinese and global firmware?
Did you format data? Afaik there is still an incompatibility depending encryption at A12 and TWRP. Going from A11 to A12 my phone did not boot without formatting data .Newest phh AOSP 12 build plus Magisk don't seem to boot. I wonder if its a conflict with the built-in superuser binaries. I'll have to hunt for a fix or a different ROM.
