Alienware R4 freezes after waking from sleep with overwatch
Discussion in 'Mobile Computing' started by Cylocybin, Jun 6, 2018.
  1. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    Any clue as to why my laptop will freeze after about 1-3 minutes from resuming ?
  2. StryderxX
    StryderxX [H]ard|Gawd
    1,091
    Jun 22, 2006
    Did you force the installation of the Windows 10 April Creators Update (1803)? If you did that's your problem. You have to either fall back to the previous version of Windows 10 or downgrade your Nvidia drivers to whatever Dell has on their website.
    Cylocybin likes this.
  3. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    thank you i will look into this later
  4. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    how do i check if i have that particular update installed
  5. pendragon1
    pendragon1 [H]ardForum Junkie
    11,173
    Oct 7, 2000
    start-run-winver will tell you. also make sure everything is up to date, drivers, bios etc make sure theres no overclocking going on too, not sure if those can...
  6. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    Yep it says 1803
  7. pendragon1
    11,173
    Oct 7, 2000
    have you ever tried installing the nvidia drivers instead of the dell ones? you might be able to install them normally or via device manager.
    dell does have a newer nvidia driver from may. oh what gpu btw?! I assumed nv but the had rx570's too.
    edit: I also assumed the 17" r4, oops. but there is a bios update for it too, spectre stuff I think...
  8. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    i have the 17.3" with 1070
  9. pendragon1
    11,173
    Oct 7, 2000
  10. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    thank you i will look into all suggestions soon and report back with results
    pendragon1 likes this.
  11. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    Ok i used the newest video drivers for nvidia from the dell page for my machine and seemed to get a nice performance bump but after sleep it still locks up. It literally froze 3 seconds after clicking on overwatch
    What about the Intel video drivers for onboard graphics?
  12. pendragon1
    11,173
    Oct 7, 2000
    yeah update those too. update anything that's is from may on.
  13. criccio
    criccio Fully Equipped
    11,857
    Mar 26, 2008
    What does overwatch have to do with it? Is the computer going to sleep with the game running?
  14. pendragon1
    11,173
    Oct 7, 2000
    I think that its not firing up the gpu correctly when he starts overwatch after the system has been to sleep.
  15. Cylocybin
    Cylocybin Limp Gawd
    300
    Jun 3, 2018
    using the drivers from nvidia website fixed the issue (not the dell listed drivers)
    thanks all
