DreamstrikeR
- Aug 23, 2016
Hello and thank you for a great place to post builds. I hope you guys/girls like the build and enjoy seeing peoples brain flashes come a live as much as I do. This was one fun build for me and I enjoyed doing it, but its not done yet (lot more to come). I bought the new Alienware case to start a new build and I really do not like the new case as much as I like this one. It's not made no where near the same quality as this case is. If you have not seen or felt one of these you need to. They are a tank of a case and hard to believe Dell built it. I have it listed on ebay right now. I think I am going to pull it down and sale the other case after a lot of looking. I will list the parts I used then I will post pictures and at the end I will list the upcoming mods I plan on doing next. My plan is to keep this post updating through out the rest of the build. I hope you enjoy. Thanks again and looking forward to comments and suggestions.
This was the mod and test fitting for the 360x120 rad I put in the top along with 3 of the PCIe fans I ordered from ebay.
This is the complete built as it is right now.
Some spec to look at.
Up coming plans and my not be in this order.
- Alienware Area 51 ALX Case with 1000 watt OEM PSU
- Alienware keyboard
- Asrock Fatal1ty Z170 Professional Gaming i7 motherboard
- Intel i7 6700k
- 16 GB G.Skill TridentZ DDR4 3200 CL 14 timing memory
- Nvidia Geforce GTX 980
- Samsung SM951 256G M.2 drive
- Seagate 1TB 7200 RPM HHD ST1000DM003
- Asus Blu-ray writer BW-12B1ST
- Koolance RP452x2 dual bay reservoir
- D5 PMW pump
- XSPC waterblock for the GTX 980
- XSPC CPU water block
- XSPC 320x120 radiator with 3x Alienware 150 CFM fans (all controlled from BIOs)
- Primochill Black PETG rigid tubing with Revolver fittings
- Windows 10 pro 64 bit
- I plan to add a EVGA 1000-1200w PSU
- I plan to paint the inside case black
- I am going to add flow indicator to loop
- I am going to add temp gauge in the loop
- I am going to hide and re-run the wire plus add wire loom to wires you see at the time I add the PSU mod
- Add the second pump in single loop
- add second GTX 980 in Sli
