Got infected by AKM Antivirus 2010 Pro. My PC just went heywire. Nothing worked! This thing popped up all over. All my apps and games reported as infected. This is bogus 100%. It would not terminate, so I used Killbox.exe to delete it. I wanted to re-install OS, but had luck with these:
to remove it, go here: http://www.2-spyware.com/remove-akm-antivirus-2010-pro.html
http://www.computersplace.com/how-to-remove-akm-antivirus-2010-pro-uninstall-guide/othersoftware
