Alright, heres a new built computer for a friend, specs as is, core i5 750 2.66ghz stock, ati 5770 stock clocks, WD hdd, and a BFG 550w psu.
Heres the problem, airflow, everything seems fine, the cpu idles at 95*F, goes to 155*F max at loads with the stock intel heatsink fan combo.
the GPU seems fine aswell, its stock, temps are 40*C while idle and unknown while under load cause i've never been able to stress it out yet, but i'm thinking it'll be fine.
I've got two intakes from the front panel, and back. The side is used for exhaust. now I've got some pictures and read online that it might not be the best setup. don't mind the wire mess, will clean that up. the fans that wll be used are going to be 80mm fans with blue leds and also i'll be throwing in a cold cathode neons as well in there.
i just need to know if my current setup is alright and will keep it cool as possible and how will the psu affect the airflow in the uni??
