I was looking for something to wrap my AIO tubing with and decided to give the following stuff a try I found on Amazon.
Self Closing Braided Wrap Sleeving It was $10 when I purchased for 10ft.
It was pretty easy to work with. The ends fray when you cut it and little pieces go everywhere, I tried using a lighter to melt the ends together but it never worked. I want to get some white electrical tape to wrap around the ends to make it look more finished, but here are the results. I think with tape on the ends it will look great and is very cheap, I used less than half of what I ordered. I ended up using a little extra on my USB3 and fan cables.
