DuronBurgerMan
- Mar 13, 2017
Some of you may remember a ranty thread of mine some time back about Agesa 1004, and all the problems it created. Well, Agesa 1006 fixed everything. I'm running the beta BIOS (803) for my Asus X370 Prime, and now my memory is back up to 2800. 2933 *sort of* works.
On the original BIOS 5xx, I was running 2933 at CL 15 (though it always reported 16 in CPUID, for whatever reason). Agesa 1004 came and reduced me to 2400 CL 15, or 2666 with really relaxed timings (I forget what, exactly, but it was really crappy. Wound up reverting to 2400).
Anyway with Agesa 1006, 2800 worked right out of the box with the XMP settings. And 2933 booted, but then behaved... odd. I think I might be able to tweak it a bit and get it stable. But if not, 2800 CL 15 is not bad. I'm running 32GB in two DIMMs, dual rank. So I'm, quite literally, one of the WORST configurations for RAM overclocking on this platform.
Agesa 1006 also benchmarks a bit better. If you remember, my Cinebench and AotS testing had 1004 @ 2400 RAM > Original @ 2933 RAM. Agesa 1006 @ 2800 RAM is now well over 1004 @ 2400 RAM. I'm a good 6% higher than the original, shipped BIOS at the same CPU speed.
Stability is good. Overclocking on the CPU is, so far, basically the same. 4 GHz practical ceiling. It can boot at 4.1 and 4.2, but stability and temps not so good there. I'm running air cooling, so it's possible water cooled folks may see improvement. I don't know.
Given that this is a beta BIOS, it's very good. So far, Agesa 1006 update looks promising. AMD delivered this time.
