Exactly. Hell, even at 50% that fan is too damn loud. And 40-42C at load? That's VERY unusual. Most people can't even achieve that with aftermarket coolers. Your case must be ridiculously well cooled/ventilated, along with a cool room.
Wow, that's great. And the good news is that there is no game out there which will tax your 6970 to the extent that Furmark does. So you're probably looking at high 60s during gaming. Can't really ask for more than that. I'm a bit surprised you can get that much cooling with your fans topping out at 2,000 RPM. My stock 6970 fan can hit 6,000RPM and still won't cool that well.
- How long had you been running Furmark at that point?
- Where'd you order the twin turbo II from, and how much was it?
- Did you have any issues removing the shroud, or any issues installing the fan?
That's if you use the fans that come with the aftermarket solution. I'd like to point out that the stock "dual 92mm" combination fan/shroud on the Twin Turbo II un-clips from the cooler, allowing you to mount dual 120mm fans of your choice.I thought I'd point out - in the majority of cases, stock coolers will actually perform better than any aftermarket cooler at 100% fan speed. The much lower maximum fan speed of aftermarket coolers means that while they usually do their job better at low speed/noise, they can't reach the levels of performance the stock coolers can.
The aftermarket heatsink, you mean?I'm sure it would, but it'd probably cool slightly better too.
The stock cooler at 6000 is pretty powerful, i've not managed to get load temps much over 40-42C with it.
Just ran furmark with fans at 100%, both cards maxed out at 61C. That's with an ambient room temperature of about 25-26C. Under normal load and on cooler days they're usually a fair bit lower than that. Today's been quite a warm one
When I was testing the DOA (unstable) 4GB 5970 with the modified accelero cooler (2500rpm) on it, I recall it topping out around 68-69C, in a 21C room, though while that was a dual-GPU card, it was not in crossfire, so experienced much better airflow.
So you're just stating the obvious? That's not an argument...I'm sure you will see better temps with uprated fans on your cooler, but that doesn't really say anything. My initial argument was that aftermarket coolers, while better heatsinks, use slower fans, and thus, can't achieve the same cooling potential as the stock cooler at 100%. If the fans were more powerful, they would. It's pretty straightforward.
implying that typical aftermarket coolers can reach levels of cooling that stock coolers can't, which is not often the case unless you retrofit them with bigger fans.Most people can't even achieve that with aftermarket coolers.
Huh? Most of the aftermarket heatsinks I've seen don't interfere with crossfire/SLI at all (they don't extend past the edge of the PCB, so the normal crossfire/SLi bridge still fits fine). There are some insane ones like the Shaman, but that's more the exception than the rule.I'm well aware of the limitations of the stock heatsink design, but given the issues that arise in crossfire/SLI with other types, they are still clearly the best design for manufacturers to fit.
Again, not sure what you're on about.That's not the issue - when placing two of the cards in crossfire, the top card is starved of airflow in many cases unless it uses the standard rear-blower design. It's a commonly reported issue.
Using a ridiculously loud fan to push a ridiculous amount of air through a tiny stock heatsink can yield cooler temperatures than using a quiet fan pushing a small amount of air through a large aftermarket heatsink...
It's going to come down to the two coolers and fans you're comparing, really.I really doubt even these statements are true.
I saw temperatures in that range on my HD 6970 before switching to an aftermarket heatsink... and the aftermarket heatsink improved the situation drastically.There's probably something seriously wrong with your case airflow if you're getting temps in the 80s with 100% fan speed on a 6970.
Though what we said was true, it's possible for a small heatsink with a lot of air being forced through it to keep a component cooler than a large heatsink with very little air being pushed through it. You'll always be able to put a better fan on the latter heatsink and improve its abilities, though.
If my airflow were bad, then adding the aftermarket heatsink would have been detrimental to my cooling, since all the heat from the graphics card is now being dumped into the case rather than out the back.
My airflow is obviously just fine, the stock heatsink simply didn't seem to work very well.
Then it must have been faulty. At 100% fan speed the HD4850s ran reasonably cool, the problem AMD had was that the default profiles let the cards get very hot because they did not force the fan speed up enough. There's probably something seriously wrong with your case airflow if you're getting temps in the 80s with 100% fan speed on a 6970.
If you had taken the time to look up the fan ramp on the HD 6970, you'd know it will automatically run the fan at 100% if the card reaches 102c. This is a BIOS override; the card will blast up to 100% fan speed if it hits 102c even if you've forced a lower speed in CCC.Even in crossfire I only see temps in the 80s on auto, which appears to set the fan speed no higher than 45% or so.
A telling review is right under your nose, mate...Check the wide spectrum of reviews for the 6970, both by itself and in crossfire, and try and find one example where they get anywhere near those temperatures. I can't think of one.
I had to go with the Accelero Twin Turbo II due to space constraints. I have cards below my HD 6970 that prevent me from using the Shaman, and my drive cage prevents me from using longer coolers like the Accelero EXTREME Plus II.Hey Unknown, which accelero model is supposed to be the best (for the 6970)? Assuming you have no issues with space (I only have the one 6970)...
I had tentatively decided on the Shaman. I was under the impression that it cools slightly better than the accelero series and is cheaper than the $52 you paid for yours, but I'm wondering if I compared the Shaman to an accelero model that wasn't top of the line...
[H]'s own review shows the HD 6970 reaching 90c, with a single card, in [H]'s well-cooled test bench.
In a normal case with a second graphics card just below the HD 6970 (like the GTX 260 sitting below mine), a 10c increase sounds easily doable.
