Affordable case with hot swap bays?
Discussion in 'Cases & Case Modding' started by lightsout, May 4, 2018.
  1. lightsout
    lightsout Gawd
    598
    Mar 15, 2014
    I currently use my PC as a do it all, gaming when I feel like it, server for Emby/Plex, etc.
    Got tired of running a server but thinking about going back to it.
    The case I have is a Phanteks Enthoo PRO M. Currently has 3 HDD's and an SSD. Wanting to add one or two more HDDs but it quickly becomes an issue powering them with a cable mess. Molex adapters because all the sata powers don't reach or I don't have enough.
    Anyways I was thinking about something where the drives just plug in and the whole thing is powered in one spot. They don't necessarily have to be swappable. I'm more concerned about powering them in a cleaner fashion.
    This would just be nice but not necessary at all so my real question is can this be done for cheap? Say around $100. THe ability to hold 6 drives would probably be just right.
  2. doubletake
    doubletake Gawd
    518
    Apr 27, 2013
    There's this and this, a bit above your budget at ~$120 and $150.
    drescherjm and lightsout like this.
  3. lightsout
    lightsout Gawd
    598
    Mar 15, 2014
    The first one looks great since I already have plenty of spare atx hardware lying around.
    Thank you I'll put it on my wish list.
  4. BadmAu5
    BadmAu5 [H]Lite
    101
    Oct 10, 2011
  5. lightsout
    lightsout Gawd
    598
    Mar 15, 2014
  6. BadmAu5
    BadmAu5 [H]Lite
    101
    Oct 10, 2011
    Yup, it just plugs into your 5.25 bay. There are also dual 5.25" bay units that take three 3.5" hdds.
    Like this one here:
    https://www.newegg.com/Product/Prod...5242&cm_re=5.25_to_3.5-_-16-215-242-_-Product
    I don't think there are any compatibility issues with most of these. I've been using a single hdd one for awhile now and it's been working quite well.
  7. lightsout
    lightsout Gawd
    598
    Mar 15, 2014
    Thats pretty sweet, I assume without external 5.25 the drives would not be accessible. Which might be a pain.
  8. Ranulfo
    Ranulfo [H]ard|Gawd
    1,271
    Feb 9, 2006
    I'd be wary of the Silverstone cases. My experience with the itx version wasn't great (went back to a node 304 for that build). The hot swap bay/back panel isn't the most robust. I had no problems but others have. The biggest issue is noise and heat. Maybe the ATX version is better with more room but that hot swap bay does not cool the drives well. No top exhaust either. Many have taken to cutting holes in it to help with airflow over the drives.
    I've yet to see a great atx/matx/itx traditional pc case setup with hotswap bays. In most you'll want a big atx case with 6+ 5.25'' bays and buy hot swap bays like linked above or icy dock brand stuff.
