Advice wanted on a pre-built 4K gaming rig
Discussion in 'General Hardware' started by Renato, May 8, 2018.
  1. Renato
    Renato n00bie
    31
    May 7, 2018
    Hello,
    I have been lurking on this site for about a month now, reading reviews, and the forums, and I am VERY impressed by the knowledge level of both the staff and the users. I am looking for advice on a pre-built gaming rig. Yes, I know that I can save money by building it myself but I don't have the time, patience, or manual dexterity (car accident) to do it.
    I have decided I want the OmenX. Now here is were it gets very complicated. I called Maingear and they told me HP makes the case and they are sold out of the case. I was told they MIGHT have some at the end of the month. So, I called HP and they said they have cases in stock BUT I must buy the rig from HP. They said shipping date of May 25.
    Now the Maingear rep told me that Maingear offers more options in the build choices, they use major brand name parts, and have a better warrantee. The HP rep said I could get the PC now and if I email him my build config he would get me a "deal"
    So, do I wait for Maingear or do I buy from HP now. This is going to be a 100% gaming rig, my budget is $5,000 (if needed). I play a mixture of FPS, RTS, and TBS games. I will be playing at 4K. One thing I do know is that the CPUs offered by HP are not ideal for gaming, so is that a deal breaker?
    Thanks for any advice!
    My build config on HP
    Win10 Pro
    i7-7820X
    16 GB RAM
    512 GB SSD
    GTX 1080Ti
    750W PSU
    Here are the links to the two versions.
    Maingear version:
    https://www.maingear.com/custom/desktops/omenx/index.php
    HP version:
    http://www8.hp.com/us/en/campaigns/...family/omen-x-desktop-slide-learn-more-button
    HP configurator:
    https://store.hp.com/us/en/Configur...Id=&catEntryId=3074457345618561818&quantity=1
  2. BlueLineSwinger
    BlueLineSwinger Gawd
    550
    Dec 1, 2011
    US (I'm assuming) $5000 is insane for a gaming build. A better target would be $1500-2000 (plus another $200-500 for a monitor if needed). Don't try to buy/build a five+-year system. Better to get a three-year system, then upgrade if/when needed and get a better system, all for close to or even less than what one super system would cost.
    Many cores don't mean much for gaming. The 8 cores (16 threads) of the i7-7820x doesn't really get you anything. An i7-8700k has two fewer cores (four fewer threads), but is a faster chip and ~$200 cheaper. If you're not planning to overlock the i7-8700 (non 'k') is just a hair slower and cheaper still. Mainboards for those (z370 vs x299) are also typically cheaper.
    RAM (8x2 I assume) and SSD look fine. Maybe up the SSD to 1 TB with the money saved by going with the 8700k. SATA SSDs are fine, PCIe/NVMe buys you nothing for gaming and most all real-world desktop app usage.
    GTX-1080ti and even Titans still struggle some at 4k IIRC. Maybe wait for the next-gen? Or consider a 1440p display instead?
    PSU seems reasonable, though a touch more than needed (a quality 600 W unit would be fine). Gold-rated is fine, platinum/titanium-rated units aren't worth the cost premium.
    No mention of CPU cooling. Unless you're looking to squeeze everything out of the CPU via overclocking, water cooling is overrated. A good 120-140mm tower air cooler is more than sufficient, and just as quiet.
    Keljian likes this.
  3. Renato
    Renato n00bie
    31
    May 7, 2018
    Well I just put $5,000 to indicate that price is not an issue. I agree with your recommendations on CPU but if you read my post I am limited in the choices offered with this rig. These are the only options offered i7-7740x i7-7800x i7-7820x i9-7900x i9-7920x. I'm limited on SSD and PSU choices as well. Please look here to see what is offered.
    Both CPU and GPU are water cooled.
  4. BlueLineSwinger
    550
    Dec 1, 2011
    Let the system dictate the case, not vice-versa. You'd be paying a large premium for a huge, overly-ornate case with limited hardware options. What's more important, that the PC perform well or look pretty?
    More to my point, take a look at the HP Omen in the standard tower form-factor. It's ore sensibly sized, and the case has pretty much all of the same features (even the external 3.5" bays). More importantly, it can be configured with better hardware for gaming (e.g., i7-8700k). I did up a config based on my prior post, and the total came to $2295. The big-box OMGHUGE Omen done up to the OP specs comes to $3260, for a system that's not quite as good for gaming. You save over $1000 after tax. Still pricy, but far better.
    Even better, Dell/Alienware has like-specced systems for $2196 (w/coupon code given on the page). So there's another hundred bucks.
    Also, it looks like the custom water cooling with the GPU(s) in the loop were only in the Maingear offerings. HP's offerings use basic closed-loop water cooling (like those sold by Corsair, Thermaltake, etc.) for the CPU and bog-standard air cooling for the GPU(s). At least that's what the pictures on HP's site indicate.
    Have you checked if there are any reputable local shops that do builds?
    Tych-0 likes this.
  5. Archaea
    Archaea [H]ardForum Junkie
    8,728
    Oct 19, 2004
    Here’s a 16 core, 32 thread, threadripper System with a 10% overclock, 240mm water cooling, evga sc black 1080Ti with ICX cooler, 16GB 3000mhz ram, win 10pro, 250gb ssd (OS drive), 3tb 7200 rpm drive (data drive), 1000 watt gold PSU, nice RGB mouse and nice RGB mechanical keyboard. Case of your choice, etc
    I configured for you as a comparison.
    < $2500
    http://www.cyberpowerpc.com/saved/1KJYB8
    You can customize any aspect from here to your preference!
    You can get a 5% off coupon code for cyberpowerpc from a web search to get price below $2500 shipped.
    When I configured the Omen similarly it would easily be >= $4K. Is the Omen case cosmetic worth $1.5k?
    Realize you can pick the case of your choice with the cyberpower pc.
    Ive ordered four systems from them in the past year and been very pleased with their work and quality.
    You can’t beat beat CyberPowerPC pricing - and being that they don’t use generic OEM products, but rather the same product you would buy at microcenter or newegg and you get to pick out each component individually —- it’s like building your own pc from reputable parts, with it being built for you, and given a collective warranty for nearly free.
    No generic OEM motherboard without options, generic blower GPU, Green boring RAM etc. (that happens with OEM machines).
    Tych-0 likes this.
  6. Archaea
    8,728
    Oct 19, 2004
    Also with the CyberPower PC - you can get custom laser engraving on the window for $9 for text or $29 for a picture. My friend put a picture of his Army Ranger company logo his case Corsair 570x case window that he bought from CyberPowerPC and it looked great with the LED lights inside the case.
    Also - if you know how to install your own operating system, or already have your own operating system you can save $91 off the above config by shipping without an O.S.
    You can buy a grey market Windows 10 Pro key here for $14
    https://www.scdkey.com/microsoft-windows-10-pro-oem-cd-key-global_1227-20.html
    Here is a 5% off coupon for CyberPowerPC on purchase of PC $1000 or above.
    SPRING0410
    Tych-0 likes this.
  7. Renato
    Renato n00bie
    31
    May 7, 2018
    WOW, as I said in my original post I am very impressed with the knowledge level of the users here. Plus you guys did a LOT of research for me, and I really appreciate it! Now you are probably both going to give me a hard time about this but the only reason I mentioned this PC was because I wanted the case, I knew there were other PC makers out there :)
    Xinmosni, Tych-0 and Kyle_Bennett like this.
  8. Archaea
    8,728
    Oct 19, 2004
    can't fault a man who knows the options and knows what he wants.
    If you are going with the HP Omen - Here is my recommendation based on your criteria.
    Operating System - Windows 10 Pro. +$40 (
    CPU - I7-7800X - 3.5Ghz Hexa Core or 7820x Octa Core. -- 6 or 8 cores is becoming mainstream. It matches what current gen consoles have - you don't want less than that on a new machine - because games are typically designed for consoles - you'll want at least that same spec of cores. (of course that 7800x or 7820x is much faster than the console gen - but the core count is what I'm referring to). Anything above the Octacore is overkill for gaming for the forseeable future - and with the decrease in Mhz speed - worse for gaming. The quad would be the absolute fastest in most benchmarks, because of its Mhz, but because it is only quad core - and DX12 can take advantage of multiple cores - it's the wrong choice for any future proofing (to whatever degree that's worth)
    Memory - 16GB DDR4 is PERFECTLY fine for gaming - no advantage to more RAM.
    Hard-drive - 256GB SSD + 2TB HD Storage is perfectly functional. They'll put your OS on the SSD, and you can use the 2TB for games --- I personally recommend a SSHD for a games drive - A Seagate Firecuda specifically is what I always recommend - so you might consider swapping that out, or adding one yourself. No reason to buy the offered 512GB SSD - you'll not need that much space for your OS drive and it isn't big enough to fit many games (some games these days or 70 or 80GB each?!?!). If your HP contact will allow you to build in a 2TB SSHD on top of the 256GB O.S. drive - do that - or exchange perhaps ask if he'll let you upgrade from the single 512 GB SSD to a 1TB SSD or 2TB SSD and only have a single drive in the system.
    GPU: 1080TI - no question
    Power Supply - 750 watt power supply is double the max draw you'll pull with this setup -- so perfectly acceptable.
    Looks like that puts you at the $3k range with a 6 core I7-7800X and a 1080TI. Call your rep and see what kind of further discount he can offer you.
    Makes me cringe a bit to say go for it when the CyberPower PC build I put together above is so much better for less money (better .... everything).
    BUT you'll not get that Omen X case through normal channels - so if it's all about that Omen X Case's look --- then you have your build!!! There are many things in life that command extra value for cosmetics - so if this is one for you - have at it!
    P.S. - custom watercooling isn't appreciably any more useful than all in one prebuilt water coolers - aside from cosmetics - so if that's the main thing the Maingear system is offering over the HP built one --- then you'll have to determine if the extra expense is worth the cosmetic wow factor - and based on your statement about the Omen X case - then it may very well be!
  9. Fix Me
    Fix Me Gawd
    620
    Mar 20, 2007
    I'm still very wary of CyberPower, that's the only reason I wouldn't recommend it. They've earned their reputation for a reason.
  10. Archaea
    8,728
    Oct 19, 2004
    vocal minority I suspect. Not discounting your experience - just lending an observation.
    I know four people who have ordered from them in the last year personally.
    I ordered 4 machines there in the last year - no problem
    My friend Nick ordered 2 machines there in the last year - no problem
    My cousin Brett ordered 5 machines there in the last year - no problem
    My co-worker Michael ordered 1 machine there in the last year - his order was cancelled without telling him it was cancelled because something on his payment info was wrong. He waited two weeks or so for the ship date - when it didn't ship he called up and they told him his order was cancelled. He was mad because they didn't tell him it was cancelled and the site wasn't updated. He spoke with a manager who he re-ordered with, they expedited his order for free. He says he wouldn't order from them again because they didn't tell him his order was cancelled and there was no update on his order page - and he was mad about the two weeks he lost. But in regards to the actual machine he received - he said everything was in order, and that the machine was surprisingly nice. He, like myself, and my friend, and my cousin all wondered how they operate their business on such small margins?
    Anyway that's a dozen machines ordered by people I personally know in the last year. Only one had an order issue, that ended up being resolved. Small sample size, but it's what I have. I'd order there again, personally, without reservation, and as such recommend them. I guess until I personally encounter an issue - that's all I can do.
    (Personally, I've had a way worse experience ordering a half dozen things from Dell.com in the last year - one order was delayed > 5 months!!!!!!! -- another two orders were delayed over a month, a couple more orders were delayed > a week from original shipping date.).
  11. Fix Me
    Fix Me Gawd
    620
    Mar 20, 2007
  12. Renato
    Renato n00bie
    31
    May 7, 2018
    BIG NEWS!
    As I did more research on the HP Omen X I found out that I can actually BUY the case! Yup, the complete empty case with a few accessories is sold separately! So I decided to build it myself! Well, actually since I live in Chicago I found a company that will build PCs from parts so I hired them to build it for me :)
    Here is what I am using, all in stock with bundle discounts from a local Microcenter
    Intel Core i7-8700K
    ASUS ROG STRIX Z370-G GAMING 1151 mATX
    Crucial Ballistix Elite 16GB 2 x 8GB DDR4-2666
    Samsung 970 EVO 500GB TLC NAND M.2 2280 PCIe NVMe
    EVGA SuperNOVA NEX750G G2 750 Watt 80 Plus Gold ATX
    Corsair Hydro H60 Water Cooling Kit
    Microsoft Windows 10 Pro 64-bit
    Even more good news, I have a friend that is going out of the country for a job for nine months so he is letting me use his Titan Xp.
    What do you think of this build?
    Thanks
    Chikia12187 likes this.
  13. Archaea
    8,728
    Oct 19, 2004
  14. Renato
    Renato n00bie
    31
    May 7, 2018
    WITHOUT Win10 and WITHOUT taxes $1,009.94
    $150 to build the system
    Fix Me and Chikia12187 like this.
  15. Archaea
    8,728
    Oct 19, 2004
    Sounds great
  16. Chikia12187
    Chikia12187 [H]Lite
    122
    May 3, 2018
    They are trying to bend you over! Don’t fall for it
  17. Chikia12187
    Chikia12187 [H]Lite
    122
    May 3, 2018
    Much better lol
  18. Chikia12187
    Chikia12187 [H]Lite
    122
    May 3, 2018
    Might wanna go 3200 at least with the ram tho
  19. Renato
    Renato n00bie
    31
    May 7, 2018
    Here is my final list with everything included, all in stock at my local Micro Center. Any last minute thoughts?
    PC Hound Part List
    CPU: Intel Intel Core i7-8700K ($299.99)
    Motherboard: ASUS ROG STRIX Z370-G Gaming (WI-FI AC) ($144.99)
    Memory: G.Skill Trident Z RGB 16GB 2 x 8GB DDR4-3200 (209.99)
    Video Card: Nvidia Titan XP (Free)
    Power Supply: SeaSonic 650W FOCUS Plus 650 Gold SSR-650FX ($59.99)
    Storage: SAMSUNG 500GB 970 EVO MZ-V7E500BW ($199.99)
    Case: HP Omen X ($262.65)
    CPU Cooler: CORSAIR Hydro Series H60 (CW-9060007-WW/RF) ($79.99)
    Mouse: Corsair Dark Core RGB SE ($89.99)
    Keyboard: Corsair K95 RGB PLATINUM ($179.99)
    Mouse Pad: Corsair MM1000 Qi Wireless Charging Gaming Mouse Pad ($79.99)
    Total: $1,607.56
  20. mvmiller12
    mvmiller12 Gawd
    513
    Aug 7, 2011
    You know what would make that perfect? A Ryzen R7 2700X and Crosshair VII mainboard... You wouldn't even need to overclock it, it'd take care of itself :)
  21. hititnquitit
    hititnquitit Limp Gawd
    328
    Apr 16, 2018
    thats a much better build than the one you initially posted. enjoy the new rig!
  22. Renato
    Renato n00bie
    31
    May 7, 2018
    Thanks guys! I'll tell you how it goes! I will also take another look at the Ryzen :)
  23. AP514
    AP514 Limp Gawd
    378
    Feb 15, 2006
    got to love Microcenters........
  24. tiraides
    tiraides [H]ardForum Junkie
    11,069
    Jan 8, 2004
    If you plan on overclocking your i7-8700K, swap out the Corsair H60 for the H100i (or one of the 280mm AIO coolers).
