After years of dutiful service my z5500's are slowly dying. Since there are no comparable computer speakers available I am opting to upgrade to the AV receiver / standalone speaker route.This is the set up I am considering.
Q Acoustics Q7000i
Marantz SR6009
I am looking at the Q Acoustics since they are small form factor and pack a decent punch for their size and good range. The Marantz SR6009 was the cheapest local AV receiver that has analog input connections.
I don't have a lot of experience with AV receivers and speaker systems and would just like to know if the following systems would be compatible with each other and if there are any other specifics I should consider before buying.
Thanks in advance!
Q Acoustics Q7000i
Marantz SR6009
Thanks in advance!
