Additional chipset cooling for ASUS P5K Deluxe
Discussion in 'Overclocking & Cooling' started by ecktt, Jun 9, 2007.
  1. ecktt
    ecktt Limp Gawd
    415
    Oct 22, 2004
    I have a Asus P5K Deluxe with a Intel 4300 being cooled by a Thermalright Ultra 120 eXtreme and a Panaflow 120mm 114 cfm fan. The processor is 33 idle and 44 under load. My problem is that the chipset which is a whooping 45C idle and 60 under load. Any cool suggestion that will install neatly and not void my mobo warranty?
  2. calebb
    calebb 1337 liek JeffK
    7,763
    Mar 26, 2000
    I'm using one of these: http://www.antec.com/us/productDetails.php?ProdID=75060
    You can disconnect the fan from the metal slot piece to reverse the direction - I oriented it so that the cool air blows down onto the chipset. It lowered my temps quite a bit, but I'm still planning to buy the optional chipset cooler.
  3. bitgod
    bitgod Gawd
    995
    Feb 20, 2003
    What would be a good overclocked chipset under load temp?
