Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Hey all,
I happen to have a Supermicro Mini-ITX motherboard that has a free mini-PCIe slot.
I'm usually vehemently pro wired Ethernet, but in this particular application I just can't find a way to wire things to make it work, so I am considering sticking an Intel 7260 WLAN card in the slot, and using that instead.
The one thing I can't seem to figure out is, what do I use as an antenna? I've only ever used mini WLAN cards in Laptops and all-in-one mini-PC's before, where they come with preinstalled antenna wires that use those tiny little connectors.
I have searched eBay/Amazon/Newegg for 2.4/5.8Ghz wifi antennas, but all of them have the larger BNC type connectors on them, not the tiny little ones that the mini WLAN cards need.
Is anyone familiar with any mini WLAN connector headers or anything like that? Essentially, those BNC-type connectors on one end with a little retention ring, so I can just drill a hole in the case, and tighten them in and connect an external antenna, and those tiny little plugs on the other end.
Or is there another way of accomplishing what I need to do?
Much obliged,
Matt
Much obliged,
Matt
