Josephson_Junction
- Oct 21, 2012
Alright, in a nutshell I work at a relatively new, small medical billing business as the primary IT person. We're moving into a larger building along with additional staff in the next two months, and I'm tasked with setting up infrastructure.
With that bit of exposition out of the way, the motherboard that will be used in the six new PCs to be built is Intel's DQ77MK, which has an mPCIe slot onboard. This opens up the option of putting in an unlocked mobile broadband card from a manufacturer such as Option or U-Blox that supports GPS (or even a GPS-only card like the U-Blox B39 PCI-5). For the record, the cellular provider we're using is Verizon.
Assuming that the card is successfully connected to the provider and has GPS enabled, would we be able to track its location in real time with the minimum requirement that the system is on? If that's the case, what software do you believe would be best for doing so? Plus, would there be a method for setting up the software to poll for the GPS signal, and then send an alert when the signal appears?
For those asking why, this was a decision from the top. Additionally, it seems that software solutions require an active internet connection as opposed to the system simply being turned on. For those asking if this is overkill, it almost certainly is.
Cheers.
Cheers.
