I have a 24 port cisco 1700 switch, that has 24 10 Base T Ports (1-24), and Two 100 Base T Ports (A,B).
I hooked a piece of straight through cat-5, from the uplink port of a 10/100 HUB to one of the 100 Base T ports on the switch. It works, the PC's still get IPs and can still talk but im just curious if this is acctually doing anything? (Im hoping that this is creating 8 100BaseT ports on the HUB from the single 100BaseT port on the router)
Basically I have 3 PC's that need to transfer files from each other, and 10mbs just aint cutting it.
Is this is a bad idea?
Im also thinking about Hooking up the internet router into the other Base T 100 port so the 3 PC's hooked into the HUB @ 100BaseT will then talk to the router @ 100BaseT, thus having a faster internet connection (Or am I fool to think that 10mbs vs 100mb for the net will be a differance).
