ChingChang
- Mar 27, 2003
Here's what I had before adding drives:
1 WD 74gb raptor
1 16x dvd burner
1 virtual drive
Windows XP Professional
on Friday, around 2pm I installed two 250gb SATA hard drives. Booted up fine, no trouble booting to windows, and both drives formatted easily as I was at class
Got back from class around 7 or something, and saw that the drives appeared to be working, then I installed some program using my DVD drive. Worked fine.
After this I loaded up an image of a game to my virtual drive, and began playing for a bit.
Saturday (around 5-7pm?) I decided to setup an internet connection for my other computer, using crossover cable and this computer. I had to install network drivers from my motherboard driver CD, so I installed those then finished setting up the connection.
I don't recall using either of my optical drives after installing the drivers, although I might have used the virtual drive to play that game once or twice. Can't remember right now. It's possible though.
Then Sunday or maybe even Saturday night I tried playing a game but it kept asking to insert the CD...
So I check My Computer and I see only my floppy drive, and my three hard drives. Virtual drive and DVD Burner are not there.
In the device manager, under DVD/CD-ROM drives, the DVD drive and the virtual drive were both detected, but there was a yellow circle with exclamation mark in the corner, which is usually not a good sign for hardware that once worked...
So I try a few things but nothing is working. I reinstalled the virtual drive several times, and it installs successfully, but the drive does not show up in My Computer, and when I go to change the drive letter for the virtual drive, I just get an error. "Unable to set new drive letter" and after reinstalling the yellow circle is gone.
After I mess around with the virtual drive, I just right clicked the DVD drive and clicked uninstall. Then I restart computer and it detected new hardware, which was the DVD drive. It said it installed successfully, but drive does not show up in My Computer. It does not have the yellow circle in Device Manager anymore either.
Right now I'm out of ideas... I am not going to reformat. I want to at least try to fix the problem before I start over.
1 WD 74gb raptor
1 16x dvd burner
1 virtual drive
