Add shell script to startup in CentOS
Shockey
Hello everyone
I'm trying to get SabNZB to run at startup.
Added it to /etc/init.d/ folder location.
able to use 'service SABNzB to start and stop SabNZB.
Permissions are as follow
-rwxr-xr-x. 1 root root 495 Jan 18 17:22 /etc/init.d/SABNzB
Run level configuration.
chkconfig --list SABNzB
SABNzB 0:eek:ff 1:eek:ff 2:eek:ff 3:eek:n 4:eek:ff 5:eek:n 6:eek:ff
Script being called
#!/bin/sh
#chkconfig: 2345 99 10
#description: NZB download service
case "$1" in
start)
echo "Starting SABnzbd."
/usr/bin/sudo -u scriptexe -H /usr/local/SABnzbd-0.5.0/SABnzbd.py -d -f /home/scriptexe/.sabnzbd/sabnzbd.ini
stop)
echo "Shutting down SABnzbd."
/usr/bin/wget -q --delete-after "http://192.168.10.70:8080/sabnzbd/api?mode=shutdown&ma_username=USER&ma_password=PASSWORD&apikey=SUPER SECRET API KEY"
echo "Usage: $0 {start|stop}"
exit 1
esac
exit 0
I've looked around and it appears everything should be working correctly with this setup but it does not start up.
Anyone have any ideas as to what i need to change to get it to run at start up?
Whats the system's default run level at bootup (check /etc/inittab)?
Your script will only startup if run level is 3, which is the default IIRC, but its good to check.
Does this line work when you manually run it?
Yup.
Welcome to CentOS
Starting udev: [ OK ]
Setting hostname Web_Server.noobcorp.loc: [ OK ]
Setting up Logical Volume Management: 2 logical volume(s) in volume group "vg_webserver" now active
[ OK ]
Checking filesystems
_CentOS-6.3-x86_: clean, 175102/2978400 files, 1599598/11945984 blocks
/dev/sda1: clean, 48/128016 files, 81289/512000 blocks
[ OK ]
Remounting root filesystem in read-write mode: [ OK ]
Mounting local filesystems: [ OK ]
Enabling local filesystem quotas: [ OK ]
Enabling /etc/fstab swaps: [ OK ]
Entering non-interactive startup
Calling the system activity data collector (sadc):
Starting monitoring for VG vg_webserver: 2 logical volume(s) in volume group "vg_webserver" monitored
[ OK ]
iptables: Applying firewall rules: [ OK ]
iptables: Loading additional modules: nf_conntrack_netbios_[ OK ]
Starting auditd: [ OK ]
Starting portreserve: [ OK ]
Starting system logger: [ OK ]
Starting irqbalance: [ OK ]
Starting rpcbind: [ OK ]
Starting kdump: [ OK ]
Starting lldpad: [ OK ]
Starting FCoE initiator service: [ OK ]
Starting system message bus: [ OK ]
Setting network parameters... [ OK ]
Starting NetworkManager daemon: [ OK ]
Starting Avahi daemon... [ OK ]
Starting NFS statd: [ OK ]
Initializing OpenCT smart card terminals: [ OK ]
Starting RPC idmapd: [ OK ]
Starting cups: [ OK ]
Mounting other filesystems: [ OK ]
Starting acpi daemon: [ OK ]
Starting HAL daemon: [ OK ]
Retrigger failed udev events [ OK ]
Starting PC/SC smart card daemon (pcscd): [ OK ]
Loading autofs4: [ OK ]
Starting automount: [ OK ]
Starting sshd: [ OK ]
Starting mysqld: [ OK ]
Starting abrt daemon: [ OK ]
Starting httpd: [ OK ]
Starting crond: [ OK ]
Starting atd: [ OK ]
Starting certmonger: [ OK ]
Starting SABnzbd.
sudo: sorry, you must have a tty to run sudo
last line seem fishy. what tty referring too?
Yup.
That is your problem. You can't use sudo from an non-interactive shell, and you don't need it anyway because you are already root. Use su instead.
