bigstusexy
- Jan 28, 2002
You know sometimes I get confused is it something for the OS section or the network section? I believe that we would have a better answer than the OS section
The problem is I'm get event problems directory service and I know that this one DC isn't replicating changes as it should
Error 1
NTDS (600) NTDSA: The database page read from the file "C:\WINNT\NTDS\ntds.dit" at offset 59621376 (0x00000000038dc000) for 8192 (0x00002000) bytes failed verification due to a page checksum mismatch. The expected checksum was 3965725494 (0xec602b36) and the actual checksum was 100197752 (0x05f8e578). The read operation will fail with error -1018 (0xfffffc06). If this condition persists then please restore the database from a previous backup. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
For more information, see Help and Support Center at
Error 2
Internal event: Active Directory could not update the following object with changes received from the following source domain controller. This is because an error occurred during the application of the changes to Active Directory on the domain controller.
Object:
CN=HSRM6,OU=Computers,OU=HS,DC=130,DC=local
Object GUID:
fb05c44d-6666-4d66-872f-48bf789fb55c
Source domain controller:
07a230d4-b8bd-6666-bf6e-5f5a37cdc2b0._msdcs.130.local
Synchronization of the local domain controller with the source domain controller is blocked until this update problem is corrected.
This operation will be tried again at the next scheduled replication.
User Action
Restart the local domain controller if this condition appears to be related to low system resources (for example, low physical or virtual memory).
Additional Data
Error value:
1127 While accessing the hard disk, a disk operation failed even after retries.
From error 1 I'd believe that I need to somehow just make the server do a full sync with another DC, this I don't know how to do you.
What do you guys think? I'm off to do some research (itsn't it grand I"m worried about this problem and they only pay me minimum wage
Oh BTW did a full disk/FS/Sector scan last nite, seems clean. These severs or POS and we actually have their replacements in boxes ready to be built for replacement (we don't get to do that... poo!)
Error 1
Error 2
Object:
Object GUID:
User Action
Additional Data
Error value:
