So I am having this very strange issue.
I'm running on an Asus p8z68-v pro motherboard, on the back there are two USB 3.0 ports.
I have been using one to plug in my main USB hub (which has its own power adapter that plugs into an outlet).
I recently got a USB 3.0 active repeater cable so I could plug up my new external blu ray player into the other room and have it plugged up to the other usb 3.0 that's beside that one.
Everything works fine while my computer is on. However when I restart my pc My usb hub will not work, it simply refuses to allow any devices connected to it to work (the light showing power to it lights up, but the lights that show a device is plugged into it does not work).
However, if I unplug the usb active repeater cable that's beside where my hub is plugged in, it works. All of my devices will power on and everything works. Then I can replug the active repeater cable in and both of them will work just fine.
I can not for the life of me figure out why this is happening, anyone have any ideas what could be causing this? It's really really annoying having to go behind my pc to unplug/replug in the cable every single time I restart my pc.
