hi all, so I've done a lot of reading on the swiftworld article, did some searching through this thread, and over at overclock.net.
It seems like the QC of the Crossover is not the best right now with some people's units dying pretty quickly, yet the response to the Shimians seem to be pretty strong still.
So, I was going to go for a Shimian QH270-LITE. I'm trying to figure out who to buy it from and want to make sure I *don't* get the tempered glass version. Also, I live in the United States so I was wondering if I need to get the 110~240V Power Brick and Plug adapter.
For example, I see this one for sale from dream-seller:
http://www.ebay.com/itm/ACHIEVA-Shi...er_Monitors&hash=item4ab90f1888#ht_8586wt_944
It doesn't mention anything about the power brick.
Then I see these two from bigclothcraft who seems to get very good feedback on the forums:
http://www.ebay.com/itm/New-ACHIEVA...r_Monitors&hash=item231b6f5aaa#ht_14635wt_944
http://www.ebay.com/itm/New-ACHIEVA...r_Monitors&hash=item231d863860#ht_15159wt_944
The first one from bigclothcraft doesn't seem to include the 110~240V Power Brick and Plug adapter, but the latter does. My concern is that at the bottom of both listings there is "QH270-IPSB" which I think is the tempered glass version, but the title of the auction seems to just be for the "LITE" version.
Finally... has anyone had any luck with the SquareTrade 3-year additional warranty? I really don't like the idea of having to ship this thing back to Korea, and I don't like the idea of having 0 warranty.
Thanks a bunch.
From what I heard they'll only cover pixel perfect versions.
great! Thanks for the heads up. Does anyone know the deal with the power bricks that I mentioned?
The power bricks that have come with the korean monitors seem to work fine for most people, however, if you want, you could go to ebay to pick up a spare powerbrick for under $25.
Just got my monitor delivered about an hour ago. This thing is awesome! Crossover 270P. Arrived in 5 days from AW. That is some FAST shipping from Korea.
Could you display a white screen on your monitor and check if the white is pretty much even across the screen, or if there's "yellower"/warmer areas?
nice review. can't decide if I want one of these or a 120hz 23". I know I can't play bf3 maxed at 1440p with my current card. is there any issue if I run 1080p on one of these koreans?
You will need to output at 2560×1440 using a dual-link DVI cable via your dual-link DVI output port at your graphics card to drive these monitors. People have reported to be successful in using certain active DP/mini-DP to dual-link DVI converters to aid in the compatibility of a multi-monitor setup and outputting using a laptop. Some people have also reported that they are able to output using a PS3 set at 720p. Do note that the content will not be scaled up due to the lack of a scaler. This also means that you cannot output 1080p/i. The monitors with multiple inputs do however have a scaler and will accept all signals.
Yes, your GPU will happily scale the resolution for you. However, Image quality will be higher at 1440p High settings with minor AA compared to 1080p Upscaled to 1440p Ultra settings higher AA. For what that is worth.
Gabe3 asked earlier if he could run one of these monitors at 1080p since he didn't think his setup would max out BF3 at 1440p. The response was yes, he could since his GPU will scale it for him (there is a button in the Nvidia Control Panel "use GPU scaling" or similar, AMD has the same as well).
This would be achieved by setting the in-game resolution to 1920x1080. The GPU will render the image at 1920x1080, then upscale on the fly to 2560x1440 before outputting to the monitor. This is similar to what your computer does when watching 720p youtube videos on a 1080p screen, etc. However, there is some cost to the upscaling (minor, but it is there), as well as some image quality loss (3:4 upscaling is obviously not perfect). Note that this must all be done on the GPU since these monitors cannot scale themselves (Assuming we are not talking the more expensive multi-input versions)
So my point was, after image quality loss and cost of upscaling, Gabe3 would probably have a better image at similar Framerates if he chose to not upscale and instead turn down AA or some other graphical settings while keeping the game at native 1440p resolution.
Just pulled the trigger on
CROSSOVER 2720MDP GOLD LED​ PIVOT Perfect Pixel
Funny thing is that the seller (accessorieswhole) says that this particular batch has A+ rated panels from LG. I know that this runs contrary to the wisdom of buying these monitors from Ebay.
The seller has 99.9% positive feedback and I'm hoping that I do get a unit with an A+ panel. It may be impossible to tell. I am paying a premium for it $649 for a unit that is multi input (including optical out) , has a scaler and pivots to portrait mode which were high priority items for me.
http://www.ebay.com/itm/11089270322...:IT&_trksid=p3984.m1497.l2649#ht_18663wt_1054
When I get mine I'll post some impressions. I don't have calibration/testing hardware so it will be compared to my Asus PA266Q.
I just ordered from this seller and I am inclined to believe it, since I haven't found a single flaw (other than the blue tint) on the panel itself.
Was yours advertised as an A+ panel ? If so I should think that a blue tint would be unacceptable.
No I do not believe any of the Korean panels are A+ panels. They're slighly lower grade, like A or A-
He tries his best to explicitly say that these are indeed a+ panels.
CrossOver authorize 100% perfect pixel A+ graded monitors only receive its perfect pixel label.
CrossOver guaranteed perfect pixel monitors are exclusively offered by AccessoriesWhole.
Solely limited quantity of A+ graded perfect pixel monitors from the manufacturing process, not judged by seller/dealer’s inspection.
I had not seen this before so that's why I bought. I hope he's not full of BS.
Here's the 'blue dot' problem I mentioned earlier. Top left of the image. Sorry for terrible cell phone pictures, but it's hard to take a good picture of a black screen. Monitor is a Crossover 2720 MDP.
Any idea what caused those blue dots? I don't see them in anything but dark colors so it makes me think it's a problem with pixels displaying dark colors only. I can't see the dots at all on white.
Here's the whole album: http://imgur.com/a/XgLNb
Received my Crossover from bigclothcraft today. Ordered 6/24, received 7/2
Im super impressed with the communications from bigclothcraft. Arrived very well packaged, fired up nicely. LOVE it!
Got it for $359 before the slight bump to current pricing of $379
NO dead pixels thus far, no issues period. Replaced a very aged and beat Westy 37" wow.. what a difference!!!
So grateful to have learned about these rocking deals from [H]... would have loved a U3011.. but only 3" less for a savings of $800.. just cant beat the ROI on these Korean deals! These truly are amazing!
I'm looking at hour cellphone pic with my cell phone and those don't look like stuck pixels to me. Looks like a blob of green hazy shit to me.
lol, it's top and a bit left of center. 3 blue blobs.
27" New Crossover 27Q LED 2560x1440 WQHD Quad HD Monitor #140743009298which crossover did you get?
