ACER PREDATOR CG437K monitor, better than ASUS?
bananadude
It seems that this monitor might be the real winner if it has RGB subpixel array, can anybody confirm this?
Here’s the review, but I still can’t find info about that. It looks like it may be what we all wanted from the 43” ASUS monitor
https://www.tomshardware.com/reviews/acer-predator-cg437k-43-4k-hdr1000
It's BGR and it ain't anything special. I picked one up the other week and returned it a few days later. Somewhat better than the Asus, but only marginally. Text is still crap, even with the tweaks you can make, and it's never going to be equal to RGB. For gaming though, yeah, it's fine, but I don't think justifies its price tag given the issues it has. The typical VA flaws are evident. At half the price, it would be OK, but they're just asking way too much for this IMO, hence why I returned it. Best hold out for the LG 48" OLED... may be cheaper than this and will absolutely wipe the floor with it.
dgz
HDMI 2.1 displays later on this year will completely obsolete this monitor at much lower prices.
You forgot to add "hopefully". I agree with your sentiment, though. Now is a terrible time for buying a good monitor/tv.
Because there isn't one... not at the price it's at anyway.... were it half that, there would be a strong argument.
Ok, except maybe the size, I still think 40” is perfect, 43” is good for pc gaming too, but 48” I would like to see if I could handle it without moving my head too much, and the DPI, I don’t know if it may be too low
N4CR
LG 48" gang says 'buying old smearfest crap is a waste of money at this point'.
Glad to see the rehashed, lazy, cheap-ass monitor pushers thrown into the marsh at this point. Good riddance.
I've not upgraded since 2011 because everything has been a huge compromise. Bugger that.
They all have practically the same PPI if you are at the correct distance. You also shouldn't turn your head either.
There is a calculator for this too.
I see absolutely no reason to get this over the 48" LG OLED.
You'll see a reason when you look at text... ClearType works acceptably well (with the right setting) on a BGR sub-pixel structure (as on the CG437K), but not on the LG OLED RGBW. You have to either disable ClearType and use gray-scale font smoothing (which doesn't look great), or you have to put up with serious fringing with ClearType enabled.
N4CR
After the examples earlier in the thread, I don't think its as bad as you make it out and if thats the worst thing, then I would happily compromise there and I do work with text pretty often.
Also it does not preclude microshaft making an update to cleartype to solve this even better than current workarounds.
You are not really going to see fringes at 4k pixel density if the screen is at the correct distance.
bananadude
Text on the 43" models is 100% worse. The argument goes the other way. I've checked out text on my B9 55" OLED and it utterly destroys the 43" XG438Q and CG437K, both of which I've bought and returned for this very reason. I don't know what people are smoking if they think text on these 43" monitors will be better than the OLED because it absolutely WILL NOT. Using Better ClearType Tuner does help vs Windows' inferior tool, but there's still no question I would take OLED over these monitors when it comes to text, and everything else for that matter.
I prefer text on my 32" IPS overall though, but that's a different monitor for a different use case, plus much higher PPI of course.
bigbluefe
Even my old ass B6 55" doesn't look that bad even if you're right on top of it as long as you're running RGB and not some compressed crap.
48" will probably look pretty decent.
It doesn't look right even from a distance. You don't see the detail of the fringes, but you still notice the poor rendering of the fonts. I can't tell if this is something that Microsoft could address some day in ClearType or not. Without being an expert on font rendering and the intricacies of the LG OLED sub-pixel structure, I can't say. At any rate, such support in ClearType isn't there today, and there has been no indication from Microsoft or LG that this situation will change.
You are left without a good solution if you use the display extensively for text. Neither ClearType nor gray-scale smoothing looks good. Whether you are willing to compromise on that for some other benefit of the display is a different question, but people who use the display primarily for text work should be aware of this issue.
bananadude
I'd question the sense of using a 48" OLED screen "primarily for text work"... add the glossy coating into the mix, and it's really far from optimal for this. Each to their own though of course. I imagine anyone doing this is probably doing so more out of protest and sheer frustration with the junk panels LCD monitors offer at inflated prices.
Right, so an OLED TV isn't really a substitute for an LCD monitor unless you use it mostly for things other than text.
bananadude
If you spend your days in Word documents, Powerpoint and browsing the web (what I would define as "primarily text work") then no, it really isn't. An IPS RGB matte screen would be better, probably no bigger than 32" depending on your sitting distance, 4K preferable if you have good vision. If your use case ALSO involves a variety of media including videos, film and games however, then it very much is.
chimera991
With a price drop to $1199, is this monitor worth it?
I want a 43" 4k that will do 120hz and this is it.
It's just crazy that my 55" oled was $1k shipped.
The setup will be within 3-4 feet from each other.
Sky15
I had no idea this was available, and I've been looking to replace my 4 year old Predator X34. That Price seems really good too.
sethk
What about the horrible motion blur on the Asus - is this Acer any better in that sense?
Wiz33
Picked one up last week. decided not to bother with the 144hz OC with 2 DP cables and went the single DP 120hz route. It's setup at the office at the moment as I'm building a new PC to go with it but I'm only there 2 days out of week with the virus lock down. I should be moving it home this week so if you have any questions that was not covered by the reviews up online and on Youtube. Feel free to drop me a note and I can see if I can answer it. Ran Armored Warfare at 4K with pretty much everything maxed and getting about 90fps using a 2080. Will pickup a 2080 Super or Ti next month (waiting for the new Intel CPU and mobo) and see what I can get.
bananadude
Why wait for Intel? At 4K just go AMD and save money. There will be ZERO benefit to going Intel at that resolution.
toxnox
It would be nice if you could test if the black smearing is as bad as some have reportet. In the viedos shown on youtube i can not notice it at all. It would be nice if someone could confirm if this is really as bad as some testers say.
AngryLobster
Clueless
Yes it's as bad as people say. Doesn't matter the overdrive setting you use but more importantly, it's much more smeary with VRR enabled when you're in the 70-90FPS range.
I found the text quality better than the XG438Q which is unexplainable to me since they use the same panel.
I can't stress enough how massive a difference there is between one of these and a decent IPS monitor in motion. You can't see jack shit when turning the camera on this monitor.
Wiz33
Unfortunately! No one makes a 40"-43" IPS HDR panel that goes over 60hz. Even for a VA panel, there is only one source so it's not like you really have a choice. But then again, I have not had any problem using a older tech 40" VA 4K for the last 3 years so I must not be seeing what you're seeing. Now, if I'm doing a lot of office work. Word, excel, etc. I'll probably switch back to my current 32" 4K IPS but for browsing, light gaming, watching videos. I much prefer the more vibrant color and deeper black from a 10bit or 8bit+FRC VA panel.
Wiz33
Have a link to the video?
Wiz33
A lot of people seems to be really concern about text quality on a BGR VA panel. Sure, they're not as crisp as a IPS but I've used them for a few years without problem. I have 3 of them right now and I find all three quite usable. I just shot the follow 3 videos to show what I mean. They are shot with a DJI Osmo Pocket gimbal camera at 4K@60. Don't know how well it will come across but here it goes (all image are darker than what I actually see as they are dimmed by the camera since they're quite bright). The first one is my current home monitor. A 2015 Samsung 40JU7500 that have long since been eclipsed by new and brighter VA but back in early 2016 (when I got it). It was surprising decent.
Next up is the Vizio M437 Go. Rated by Rtings as the best 43" 4K at 7.7 (until this week when it was replaced by the Samsung Q60T with a lower 7.1 rating). It's getting hard to find since it's a 2019 model but damn, it looks really good if you just need a 43" 4K monitor. Colors are vibrant, texts are sharp, not really bright as far as HDR goes but better than most IPS monitor and at $379 if you can still find one. It's a steal. I'll be using this at the office (with the current Acer B326HK as a 2nd screen for serious office work).
Last one is the Acer CG437K. at over 3 times the price of the Vizio (although I paid less). It's expensive, but still cheaper than what I paid for my first LCD monitor, a Viewsonic 20" at almost $2000 back in the days and also less than what I paid for the Samsung 40JU7500. While rated at 1000 nits vs the Vzio's 450. It's wasn't really noticeable unless you're watching HDR contents). The color is not as vibrant and the black doesn't seems to be as dark as the Vizio but still pretty good (that maybe also be due to different default factory settings). Compared to the Vizio, It's a lot more to pay just to get over 60hz refresh so you have to decide if it's worth it.
toxnox
Here is one of the Videos
It would be nice if you could make a video ingame with some motion 👍
I want to decide if it is a problem for me. I come from an 43“ VA TV and have no Problem with the VA Panel at all. So chancen are that a litte smearing is nothing i would worry about if it is not to bad.
AngryLobster
Clueless
The text quality issues with this and the Asus is not just because it's BGR. They are doing something strange (dithering) to the output that causes issues. I've also never had that big a problem with traditional BGR displays.
You can see this for yourself by enabling the "shadow boost" or whatever in the monitors menu and text clarity drastically improves while also elevated blacks and making the monitor unusable.
TCL TV's use a similar type of spatial dithering to improve viewing angles and I'm pretty confident that's what Asus/Acer have opted for here over text clarity due to the panels atrocious native viewing angles.
AngryLobster
Clueless
60hz Samsung VA smearing is no where near as bad as this.
Wiz33
You really can't depend on the a Youtube video shot at 720p at unknown frame rate. The Vizio and Acer is located at the office and I'll try to shoot some game footage with the Osmo Pocket @4K60 on a tripod next time I go in (only once or twice a week with the quarantine).
Wiz33
O.k.that would be nice! 👍
Ended up having to go to office to receive a package so I just uploaded the following videos, both were filmed while playing this Youtube clip starting at the 4:00 mark:
Here's the once from the Vizio M437. even in the office with overhead lights. The camera still dimmed the image a bit and the Vizio have a more reflective screen with makes for some focus pluseing from the camera. There's also a shaded window behind the the filming position so you see the tall rectangle outline on the center of the screen.
This one is from the Acer CG437K in the same office be there's not window facing the screen and the Acer also have a less reflective screen so focusing is a bit better.
The Acer video is still uploading as I type this so it'll take another hour before you can see the 4K rendered version
Also for reference. This is the kind of low light footage you can normally expect from the Osmo Pocket in 4K
AngryLobster
Clueless
Like I mentioned in the other thread, the Acer's lack of backlight control and peak brightness (1200nits) are a terrible combination. You're video demonstrates that although the Vizio is dimmer, it preserves dark areas as they are intended instead of blowing the entire screen out.
What's sad is they basically have the same zone count but $900 separates them.
Wiz33
Have you try different setting at all. I didn't stay long at the office so all I did was film the video and left. I believe the Acer brightness and backlight are set to 100% and both can probably come down a bit. I'll give that a try next time I'm in office and see if I can bring it down without crushing the black. I'll also take my PS4P to the office and and shoot some footage with the calibrated in game HDR setting.
I think the Vizio came across really well considering the price and the QLED (which I don't believe the Acer has) definitely helps giving a slightly more vibrant picture but I felt that the color palette seems a bit too artificial/vibrant. More like what you see in stores when they put all the TV in demo mode, Especially the Red. will have to play with that also.
toxnox
Thank you for the Videos! :) I think for my usecase the Monitor is o.k. I don´t play fast Shooters so it will be fine.
Wiz33
If you don't need more than 60hz and you have room for a larger monitor. You'll probably be better off getting a 49" Samsung Q70R or Q80T. Not only do they cost less, they look spectacular.
