Acer G257HU 25", WQHD, DVI/HDMI/DP $280
Discussion in 'Displays' started by TechLarry, Feb 6, 2015.
  1. TechLarry
    TechLarry Can't find the G Spot
    29,710
    Aug 9, 2005
    Didn't see anything posted about this one yet.
    I'm a bit out of the whole "What monitor is best" thing, but I've been wanting to replace the three 23" Asus Monitors on my iRacing rig for something a bit bigger and WHQD res.
    Would this work out?
    Technical Information
    Number of Screens 1
    Screen Size 25"
    Screen Mode WQHD
    Response Time 4 ms
    Aspect Ratio 16:9
    Backlight Technology LED
    Panel Technology In-plane Switching (IPS) Technology
    Tilt Angle -5°to15°
    Swivel Angle No
    Maximum Adjustable Height No
    Video
    Maximum Resolution 2560 x 1440
    Color Supported 16.7 Million Colors
    Contrast Ratio 100,000,000:1
    Brightness 350 Nit
    Audio
    Speakers Yes
    Interfaces/Ports
    DVI Yes
    HDMI Yes
    Power Description
    Operating Power Consumption (Energy Star) 36 W
    Standby Power Consumption 450 mW
    Off-Mode Power Consumption 450 mW
    Physical Characteristics
    Color Black
    Height 13.5"
    Width 22.4"
    Depth 1.6"
    Height with Stand 16.54"
    Width with Stand 22.44"
    Depth with Stand 7.28"
    Weight (Approximate) 7.05 lb
    Weight with Stand (Approximate) 7.72 lb
    Miscellaneous
    Package Contents
    G257HU Widescreen LCD Monitor
    DVI Cable
    1 x HDMI Cable
    Power Cord
    Green Compliance Certificate/Authority MPR II
    Warranty
    Warranty Limited Warranty agreement applies.
  2. Nicholars
    Nicholars Gawd
    788
    Jan 10, 2012
    Acer are really going crazy with monitor releases recently
  3. NCX
    NCX [H]ardness Supreme
    6,227
    Jan 9, 2010
    Acer's tend to suffer from really obvious overshoot ghosting and do not have overdrive controls. Best to wait for reviews or buy the Dell variant since newer Dells have overdrive controls.
  4. stop!theradio
    stop!theradio 2[H]4U
    3,534
    Jul 13, 2007
    Not sure if you're still looking for information on the monitor - but I just got one from Amazon a week ago, and it is absolutely incredible. It replaced my 23" Acer monitor as well (X233H, 1920x1080) and the difference is beyond night and day. It may not be a 1ms "gaming" monitor, but even so the response time is a huge upgrade from the old monitor. The colors are amazing (I need it as my main monitor for graphics work), the contrast is amazing, and it absolutely DOES have overdrive control options in the OSD. You can also adjust CMYK values in addition to the standard RGB, as well as the gamma level and pixel mapping. It's got DisplayPort, HDMI and DL DVI connections and has built in speakers (which are crappy as all hell, but we don't buy flat panel displays for their speakers now do we? lol).
    If you're still up in the air about this monitor - come back down - get this thing, I couldn't be happier with it.
    NOTE: It's an IPS panel - so while it gives amazing colors that don't shift when you change your viewing angle, you do see some "IPS glow". If you're unsure about what that is, go ahead and look it up. This was my first IPS panel, so I was a little scared at first, but now that the dust has settled, I'd take an IPS panel over a TN panel any day.
  5. geok1ng
    geok1ng 2[H]4U
    2,080
    Oct 28, 2007
    price is $249 at amazon. The U2515H is still $359.
    it is not simple to decide between them:
    the U2515H comes with a pivoting stand and has MST DP-out for triple monitor setup.
    The acer has DVI, so for the very rare users that have video cards ONLY with DVI, it is the solution. On the other hand, it is much more complex to build triple monitors setups at this resolution whithout acess to displayport
  6. stop!theradio
    3,534
    Jul 13, 2007
    Also, you can snag the refurbished Acer G257HU for $229 on Amazon. That $229 is the grand total, too, shipping is free and everything. I'm not one to buy refurbished items, but I decided to try my luck with the factory refurbished model - and I'm I'm extremely glad I did. It's essentially the same as brand new - visually and functionally indistinguishable. It comes packaged like a new monitor, comes with all the cables and protective materials...plus all the potential kinks are worked out ;)
    I'm just really happy with this purchase, and since I couldn't find a whole lot of info on it before I bought it, I figured I'd share for others who might be curious.
