Acer ConceptD CP3271K P – The First 32″ Monitor with 4K and 144Hz!
Discussion in 'Displays' started by Vega, Apr 12, 2019.
  1. Vega
    Vega [H]ardness Supreme
    6,258
    Oct 12, 2004
  2. THUMPer
    THUMPer 2[H]4U
    3,041
    May 6, 2008
    Specs good, stand bad.
  3. MistaSparkul
    MistaSparkul [H]ard|Gawd
    1,028
    Jul 5, 2012
    Edge lit IPS...no thanks. FALD is the only thing that even makes an IPS panel worth using for me. I'll just have to wait for a high refresh version of the Mini LED 32 inch.
  4. cybereality
    cybereality [H]ardness Supreme
    4,688
    Mar 22, 2008
    Great to see high refresh finally coming to 4K.
    There is no perfect monitor, now or probably in the near future, but still progress is being made.
    Personally, I'm happy with my current setup for now.
  5. GoldenTiger
    GoldenTiger [H]ard as it Gets
    18,808
    Dec 2, 2004
  6. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Strange, Anandtech has a somewhat different set of specs for this monitor. Notably they say it will have mini-LED FALD (1152 zones), but is only 60hz. There's also a 27" model which is 144hz but without the FALD, again according to AT. Then again, it says right there on the demo model's screen that it's 144hz, and AT did get the model number wrong (unless there are two different lines with very similar model names? Seems unlikely though), so I'm more inclined to believe TFTcentral's reporting. Surprised they're saying no FALD though - for the $3k price AT is quoting, I would sure hope for something extra.
    Edit: need to read better. There are indeed two distinct products here - the 144hz CP3271K-P, and the 60hz CM7321K w/FALD. Pity they couldn't get everything on one model.
  7. MistaSparkul
    1,028
    Jul 5, 2012
    Well seeing as how the 1152 FALD is already $3000, if they really did combine the two monitors into one giving us 4k 144hz 1152 zone FALD...it would probably cost $5,000 :ROFLMAO:
  8. pippenainteasy
    pippenainteasy Gawd
    605
    May 20, 2016
    No mention of adaptive sync with the FALD display. I'd be perfectly happy gaming on a 4K 60hz adaptive sync display if it had FALD and I would take that over 144hz since you aren't going to get that with AAA games anyway, if you want smooth performance with no wild framerate hitching you will probably have to run the monitor in 85hz mode anyway unless you only play e-sports games.
  9. Vega
    6,258
    Oct 12, 2004
    Bummer, this is actually a 27" monitor. Silly Acer nomenclature. Probably uses the same AUO 27" 4K 144 Hz panel that's used in many screens now. Nothing to see here.
