Acer B6 B296CLbmiidprz - 29" for $429
NCX
Just another stupid "frame-less" 21:9 iteration. Blacks will look grayish compared to the extremely dark inner black bezel vs. a monitor with a proper bezel in normal lighting, even when using proper brightness settings (100-140cdm/2).
The AOC does not use LED PWM Dimming,, nor does the PB298Q (PRAD) which both have very low lag has fast pixel response times. The Dell versions doesn't use PWM but has high lag and slow pixel response times for an IPS panel. Only the NEC version has a proper bezel but uses PWM and has higher lag vs. the AOC and Asus.
Cloudy
Any more feedback on this monitor? I'd like to hear some feedback from an owner if possible!
